I would like to get the temperature in the problem.cpp for each node. There are 2 cases: a) there is a heat flux process and b) there is a constant temperature defined.
Maybe someone of you could provide me an example how to do this in the current trunk version.
Thanks a lot for your help.
Bastian
Hi Bastian,
you can use the reaction interface object :
In the (optional) *.rei input file introduced with V5.5.0, the Keywords
$PRESSURE
CONSTANT 1.0 ; bar ; VARIABLE
$TEMPERATURE
CONSTANT 298.15 ; Kelvin ; VARIABLE
can be used to set constant pressure or temperature values throughout the model domain in the REI, which can be used as input values for the reaction routine, e.g. without the need to define a heat transport process in the simulation. Calls to the functions
double REACTINT::GetPressure (long node)
double REACTINT::GetTemperature (long node)
will then return the respective values defined with the keywords behind the option CONSTANT in units of bar and Kelvin. Instead, the option VARIABLE (without any specified value) will return local node pressures from the flow or heat transport model (if defined).
#REACTION_INTERFACE
$TEMPERATURE
VARIABLE
;CONSTANT 300.15 ; K
See also the example in benchmark:
\benchmarks\TCR\Temperature_BacGrowth
Cheers, Christof
Am 27.02.2014 16:31, schrieb Graupner Bastian:
Bastian
*Bastian Graupner*
Dr.
Safety Analyst
Swiss Federal Nuclear Safety Inspectorate ENSI
Secton Disposal & Analyses
Industriestrasse 19
CH-5200 Brugg
Tel.: +41 56 460 85 52
Fax: +41 56 460 84 99
Bastian.Graupner@ensi.ch <mailto:Bastian.Graupner@ensi.ch>__
Swiss Federal Nuclear Safety Inspectorate ENSI » ENSI
Groups "ogs-users" group.
an email to ogs-users+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out\.
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: christof.beyer@gpi.uni-kiel.de
