Hi guys,
Just have a quick sit to print out material(i.e., permeability) or fluid properties (i.e., viscosity, density) of elements(or nodes) in the output file. Anybody has an example configured for this or should I code to do it?
Chan-Hee
Hej Chan-Hee,
I think, you can use Tecplot output and give Viscosity and fluid density in element out. Norbert implemented some of this output some time ago. Maybe you can use these parts of the code for permeability out…
Cheers
Marc
On 29 Mar 2013 01:29, “Chan-Hee Park” nbeyond@gmail.com wrote:
Hi guys,
Chan-Hee
For more options, visit https://groups.google.com/groups/opt_out.
Hoi,
permeability output in vtk legacy files is supported:
$ELE_VALUES
PERMEABILITY
Other properties need probably modifications of the source code.
Greetings, Georg
Am Freitag, 29. März 2013 01:29:35 UTC+1 schrieb Chan-Hee Park:
Hi guys,
Chan-Hee
Thanks Marc and Georg,
I have tried permeability output in vtk with the latest trunk. It works with VTK output as Georg mentioned. I didn’t work with VISOCITY as an ELE_VALUES though. Meanwhile, “PVD” output did not work with PERMEABILITY, either. Currently, VTK works only for PERMEABILITY by the following lines.
// PRINT CHANGING (OR CONSTANT) PERMEABILITY TENSOR? // JTARON 2010
else if (_cellArrayNames[k].compare("PERMEABILITY") == 0)
vtk_file << "VECTORS permeability double " << "\n";
for (int j = 0l; j < (long) _mesh->ele_vector.size(); j++)
MeshLib::CElem* ele = _mesh->ele_vector[j];
CMediumProperties* MediaProp =
mmp_vector[ele->GetPatchIndex()];
for (size_t i = 0; i < 3; i++)
vtk_file <<
MediaProp->PermeabilityTensor(j)[i * 3 + i] << " ";
vtk_file << "\n";
As for VISCOSITY, I guess this is a good starting point how I revise the code. First, I have to choose whether I put it as node or element value. Thanks.
On Friday, March 29, 2013 6:01:29 PM UTC+9, Georg Kosakowski wrote:
Hoi,
$ELE_VALUES
PERMEABILITY
Greetings, Georg
Hi guys,
Chan-Hee
Chan-Hee,
Attached is my ad-hoc version of PVD output supporting some MMP and MFP properties as element data (evaluated at the 1st gauss point). you cannot compile it as it is because some MMP functions exist only in my branch. but you can simply remove lines to fix errors. Viscosity is not supported but you can easily add it.
best,
nori
vtk.cpp (39.4 KB)
with VTK output as Georg mentioned. I didn't work with VISOCITY as an
ELE_VALUES though. Meanwhile, "PVD" output did not work with
following lines.
vtk_file <<
vtk_file << "\n";
Thanks.
Hoi,
$ELE_VALUES
PERMEABILITY
Greetings, Georg
Am Freitag, 29. M�rz 2013 01:29:35 UTC+1 schrieb Chan-Hee Park:
Hi guys,
Chan-Hee
Groups "ogs-users" group.
Dr.-Ing. Norihiro Watanabe
Wissenschaftler
Helmholtz-Zentrum f�r Umweltforschung GmbH - UFZ
Permoserstra�e 15 / 04318 Leipzig / Germany
Telefon +49 341 235 1806
Wissenschaftlicher Gesch�ftsf�hrer: Prof. Dr. Georg Teutsch
Administrativer Gesch�ftsf�hrer: Dr. Heike Gra�mann
Thanks Nori for your customized file. I could make the compiler happy after revising the following.
in fem_ele_std.h
public:
void Config();
in vtk.cpp
/* PCH Comment out just for compilation
case 3:
mat_value = mmp->FractureAperture(i_e);
break;
case 4:
mat_value = mmp->FractureContactAreaRatio(i_e);
break;
And with Georg suggestion of permeability and PVD output option as you suggested.
in .out file
$ELE_VALUES
PERMEABILITY
That does not make it work. It prints all zero instead of 1.e-11 I have assigned. Just for your info and thanks. In fact, I prefer the PVD option as you may notice it from our conversation here in the google group.
Chan-Hee
On Monday, April 1, 2013 7:52:08 PM UTC+9, Norihiro Watanabe wrote:
Chan-Hee,
best,
nori
following lines.
vtk_file <<
vtk_file << "\n";
Thanks.
Hoi,
$ELE_VALUES
PERMEABILITY
Greetings, Georg
Hi guys,
Chan-Hee
an email to ogs-users+...@googlegroups.com.
Wissenschaftler
norihiro...@ufz.de / http://www.ufz.de
The PVD output works differently from the VTK output. PVD checks $MMP_VALUES and $MFP_VALUES. For example, you need to add the followings lines in OUT files:
$MMP_VALUES
PERMEABILITY
$MFP_VALUES
DENSITY
best,
nori
in fem_ele_std.h
public:
void Config();
in vtk.cpp
case 3:
break;
case 4:
break;
suggested.
in .out file
$ELE_VALUES
PERMEABILITY
Chan-Hee
Chan-Hee,
best,
nori
works
as an
by the
> following lines.
JTARON 2010
> vtk_file <<
> vtk_file << "\n";
revise the
value.
> Thanks.
> Hoi,
> $ELE_VALUES
> PERMEABILITY
code.
> Greetings, Georg
> Am Freitag, 29. M�rz 2013 01:29:35 UTC+1 schrieb Chan-Hee > Park:
> Hi guys,
permeability)
elements(or
configured for
> Cheers,
> Chan-Hee
send
> an email to ogs-users+...@googlegroups.com <javascript:>.
<https://groups.google.com/groups/opt_out>.
Wissenschaftler
norihiro...@ufz.de <javascript:> / http://www.ufz.de
Wissenschaftler
Thanks Nori. It works beautiful with the following revision.
In the .out file,
$MMP_VALUES
PERMEABILITY
$MFP_VALUES
DENSITY
VISCOSITY
$GEO_TYPE
DOMAIN
$DAT_TYPE
PVD
In vtk.cpp that Nori provided in this conversation.
struct ELEMENT_MFP_VALUES
static double getValue(CFluidProperties* mfp, int mfp_id) {
double mat_value = .0;
switch (mfp_id)
case 0:
mat_value = mfp->Density();
break;
case 1:
mat_value = mfp->Viscosity();
break;
default:
cout << “CVTK::WriteElementValues: no MFP values specified” << endl;
break;
return mat_value;
static int getMFPIndex(const std::string &mfp_name) {
int mfp_id = -1;
if (mfp_name.compare(“DENSITY”) == 0) {
mfp_id = 0;
} else if (mfp_name.compare(“VISCOSITY”) == 0) {
** mfp_id = 1;**
} else {
cout << "CVTK::WriteElementValues: no valid MFP values specified. " << mfp_name << endl;
return mfp_id;
and some more revision that I have made to have viscosity as a function of temperature, now I can print out viscosity change due to temperature effect. Once again, thanks everybody.
Chan-Hee
lines in OUT files:
$MMP_VALUES
PERMEABILITY
$MFP_VALUES
DENSITY
best,
nori
in fem_ele_std.h
public:
void Config();
in vtk.cpp
case 3:
break;
case 4:
break;
suggested.
in .out file
$ELE_VALUES
PERMEABILITY
Chan-Hee
Chan-Hee,
best,
nori
works
as an
by the
> following lines.
JTARON 2010
> vtk_file <<
> vtk_file << "\n";
revise the
value.
> Thanks.
> Hoi,
> $ELE_VALUES
> PERMEABILITY
code.
> Greetings, Georg
> Am Freitag, 29. M�rz 2013 01:29:35 UTC+1 schrieb Chan-Hee > > Park:
> Hi guys,
permeability)
elements(or
configured for
> Cheers,
> Chan-Hee
send
> For more options, visit [https://groups.google.com/groups/opt_out](https://groups.google.com/groups/opt_out)
<[https://groups.google.com/groups/opt_out](https://groups.google.com/groups/opt_out)>.
