Hi everyone,
can anybody tell me which value needs to be entered into the source term file under "$DIS_TYPE" for 1D darcy flow, process type LIQUID_FLOW? Is it the volumetric flow rate, or the darcy velocity?
Background: I tried to conduct a quick benchmark, and got the correct results for the pressure drop over the model domain when using darcy velocity. However, the pressure drop changes when I change the radius of my tube ($GEOMETRY_AREA in the mmp file). This should only be the case when the volumetric flow rate is used.
Daniel
Daniel Müller
Sec. 4.1 - Reservoir Technologies
International Centre for Geothermal Research ICGR
Tel +49 331 288-1567
Helmholtz-Zentrum Potsdam
**Deutsches GeoForschungsZentrum GFZ**
Stiftung des öff. Rechts Land Brandenburg
Telegrafenberg, 14473 Potsdam
daniel.mueller@gfz-potsdam.de
hi, you are right. that is volumetric flux for 1d meshes, as the mesh doesn't define a diameter of the tube.
best,
nori
On 10 March 2015 23:38:55 GMT+09:00, "Daniel Müller" <daniel.mueller@gfz-potsdam.de> wrote:
Hi everyone,
term
of
Daniel
*Daniel Müller*
For 1D CONSTANT type is the right choice for "$DIS_TYPE", which defines the volumetric flow rate or velocity if the area in .mmp is set to one.
On 03/10/2015 03:38 PM, Daniel Müller wrote:
Hi everyone,
Daniel
*Daniel Müller*
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com <mailto:ogs-users+unsubscribe@googlegroups.com>.
OK, it’s clear now. I somehow thought that GEOMETRY_AREA defines the tube radius in 1d. Thanks!
Am 11.03.2015 um 10:39 schrieb Wenqing Wang:
-- You received this message because you are subscribed to the Google Groups "ogs-users" group. To unsubscribe from this group and stop receiving emails from it, send an email to . For more options, visit .
Daniel Müller
Hi everyone,
Daniel
Daniel Müller
