you are right. It is working if I use it without MPI. I just noticed this. Unfortunately OGS is making strange things if I try it with MPI.
I am working on that.
Thanks a lot for your help and your time.
2013/3/20 Graupner Bastian Bastian.Graupner@ensi.ch
The code in the trunk version looks very different to the code I got from Marcs rf_bc.cpp. I will check if it works.
Bastian
Von:
ogs-users@googlegroups.com [mailto:ogs-users@googlegroups.com] Im Auftrag von jens-olaf Delfs
Gesendet: Mittwoch, 20. März 2013 13:15
An: ogs-users@googlegroups.com
Betreff: Re: AW: [ogs-users] Defining z-dependend pressure boundary condition
Please go with the debuger and your example through the function
void CBoundaryConditionsGroup::Set(CRFProcess* pcs, int ShiftInNodeVector,
const std::string& this_pv_name)
Search for FiniteElement::GRADIENT and the comment // 6/2012 JOD
I am not sure if current implementation works or not, because there are many brackets.
Thanks
Jens
Hi Jens-Olaf, hi Marc
Thanks a lot for your help.
Unfortunately I can not use the trunk version because the mpi is currently not working. That’s why I switched to 5.3.07. Marc send me an email with the code for surfaces. Is there also an bug that I should fix? Did you fix the bug in the trunk version already?
Bastian
Von:
Gesendet: Mittwoch, 20. März 2013 09:48
thanks for the credits . GRADIENT is the right way. Can you switch to the trunk version? I saw that it’s already implemented for surfaces, but there is a bug . We haven’t tested it for the surface yet.
If you prefer to stick to your version, you can use WWs well-tested
$DIS_TYPE
DIRECT filename.tex
Bad think is, that you have to know the node numbers and calculate the values for a file:
nodenr1 value1
nodenr2 value3
nodenr3 value3
2013/3/19 Marc Walther marc.walther@tu-dresden.de
Hi Sebastian,
we were both right… in the trunk, there is no gradient option. But, Jens-Olaf once included that in a version and this is why it worked for me! Attached is rf_bc_new.* for comparison…
Marc
PS: All credits go to JOD
On 19.03.2013 17:12, Graupner Bastian wrote:
Hi Marc,
unfortunately GRADIENT is only implemented for Polylines but not for surfaces.
Thanks,
Bastian
Von:
ogs-users@googlegroups.com [mailto:ogs-users@googlegroups.com] Im Auftrag von Marc Walther
Gesendet: Dienstag, 19. März 2013 17:06
Betreff: Re: [ogs-users] Defining z-dependend pressure boundary condition
Hej Sebastian,
I’m not sure, but maybe you can use gradient instead of linear.
Marc
On 19 Mar 2013 16:18, “Mauro Cacace” cacace@gfz-potsdam.de wrote:
Am 19/03/2013 16:00, schrieb Graupner Bastian:
Hi everyone,
I am using OGS 64bit on Windows, ver 5.3.7 JOD .
I would like to define a pressure boundary condition on the sites of a cube depending on the z-coordinate. Therefore I am going to use the distribution type LINEAR.
Bc-file:
#BOUNDARY_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
SURFACE SURF_Left
$DIS_TYPE
LINEAR 4 ; Pa Den Knoten der Fläche werden linear die Druckdifferenzen zugeordnet
3 978480.0
4 978480.0
8 821520.0
7 821520.0
The gli-file contains:
#POLYLINE
$NAME
PLY_Left -> the PLY_Left is used to define the SURF_Left
$POINTS
3
4
8
7
3
#SURFACE
$NAME
SURF_Left
$POLYLINES
PLY_Left
$MAT_GROUP
0
$TYPE
0
Unfortunately the result of the pressure distribution for the first time step looks a little strange. I got heterogeneous pressure definitions at the side and obviously no pressure definition at the corners of the surface. What should I do to get a proper pressure distribution as boundary condition?
Bastian
Bastian Graupner
Dr.
Safety Analyst
Swiss Federal Nuclear Safety Inspectorate ENSI
Secton Disposal & Analyses
Industriestrasse 19
CH-5200 Brugg
Tel.: +41 56 460 85 52
Fax: +41 56 460 84 99
http://www.ensi.ch/en
For more options, visit
https://groups.google.com/groups/opt_out.
Are you using a plane for the interpolation? If yes, try to set a relevant espilon for the interpolation. If not, try to export a tin of the boundary.
Dr. Mauro Cacace
_________________________________________
Helmholtz-Zentrum Potsdam
Deutsches GeoForschungsZentrum GFZ
(German Research Centre for Geosciences)
- Sect. 4.4: Basin Analysis -
Telegrafenberg
Haus C4 Raum 30/1.08
D-14473 Potsdam
Germany
Tel. : +49 (0)331 288 1783
Fax : +49 (0)331 288 1349
e-mail: cacace@gfz-potsdam.de
Dipl.-Hydrol. Marc Walther
Wissenschaftlicher Mitarbeiter
Technische Universität Dresden
Fakultät Umweltwissenschaften
Fachrichtung Hydrowissenschaften
Institut für Grundwasserwirtschaft
01062 Dresden
Besucheradresse
Bergstr. 66, 01069 Dresden
Neubau Chemie 2. Bauabschnitt, CHE-BA2, Raum E59
[http://www.tu-dresden.de/fghhigw](http://www.tu-dresden.de/fghhigw)
Tel +49 351 463 425 56
Fax +49 351 463 425 52
Mobil +49 178 334 18 19
For more options, visit [
https://groups.google.com/groups/opt_out](https://groups.google.com/groups/opt_out).
For more options, visit [https://groups.google.com/groups/opt_out](https://groups.google.com/groups/opt_out).
</details>
