Hi All,
I am checking the effect of number of elements on the simulation time. The geometry of soil column: width=0.1 m & Height = 1.0 m. Machine configuration= HP Z840 Workstation, Intel ® Xeon ® CPU E5-2623 V4 2.60 GHz (RAM 16GB)
Type Nodes Element Simulation Time for one day
H2 (Elastic) H2M (Elastic)
TRI 59 76 330 sec 420 sec
63 80 327 433
QUAD 102 50 335 526
1002 500 9768
For QUAD element, I also want to check for 500, & 5000 elements. But, time consumption (for 500 elements) is too high (9768 sec). It will increase exponentially with the increase of elements number. Height =1.0 m, element # =500, unit height = 1.0/500=0.002. For H2M case, when requested output for left line, it is calculating along the height, every unit height location. Is there any way to take output at 0.2 unit height interval than 0.002? I attached out put files. POINT is one solution.
Thanks in advance.
L-Q_ply_left_t2.tec (1.14 MB)
L-Q_ply_left_t3_DEFORMATION.tec (1.06 MB)
I suggest you check which part, e.g. linear solve or nolinear solve, needs the long calculation time for the QUAD case. If linear solve is the one, you can try with another linear solver setting or with another linear solver library.
Regarding the output issue, unfortunately there is no way to change the interval. At the moment, a user has to do it in post-process. Maybe you can easily do it with Line filter in ParaView.
nori
On 06/10/2017 05:55 AM, Mohammad Islam wrote:
Hi All,
I am checking the effect of number of elements on the simulation time. The geometry of soil column: width=0.1 m & Height = 1.0 m. Machine configuration= HP Z840 Workstation, Intel (R) Xeon (R) CPU E5-2623 V4 2.60 GHz (RAM 16GB)
63 80 327 433
QUAD 102 50 335 526
1002 500 9768
Thanks in advance.
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com <mailto:ogs-users+unsubscribe@googlegroups.com>.
Dear Nori,
Thank you for your advise. I will check with solver issue.
On Sunday, 11 June 2017 17:15:45 UTC-4, Norihiro Watanabe wrote:
nori
Hi All,
2.60 GHz (RAM 16GB)
Time for one day
TRI 59 76 330
sec 420 sec
63 80
327 433
QUAD 102 50
335 526
1002
500 9768
Thanks in advance.
Groups “ogs-users” group.
an email to ogs-users+...@googlegroups.com
mailto:ogs-users+...@googlegroups.com.
