Hi there,
trying to run the Unconfined Aquifer benchmark using the latest version of OGS 6 I run into the following error:
C:\Users\Andrea\Documents\Flow\OpenGeoSys\ogs-master\ogs-master\Tests\Data\Parabolic\LiquidFlow\Unconfined_Aquifer\BC_BC>ogs TestSet_01.prj
info: This is OpenGeoSys-6 version 6.4.3-16-g9a7564950.
info: OGS started on 2022-10-26 17:09:28+0200.
info: Reading project file C:\Users\Andrea\Documents\Flow\OpenGeoSys\ogs-master\ogs-master\Tests\Data\Parabolic\LiquidFlow\Unconfined_Aquifer\BC_BC\TestSet_01.prj.
info: ConstantParameter: p0
info: ConstantParameter: p_bc0
info: ConstantParameter: p_bc1
info: ConstantParameter: constant_porosity_parameter
info: ConstantParameter: kappa1
info: No source terms for process variable ‘pressure’ found.
critical: E:/builds/4WZM6MEb/0/ogs/ogs/BaseLib/ConfigTree.cpp:233 BaseLib::ConfigTree::onerror()
error: ConfigTree: In file TestSet_01.prj' at path <processes/process>: Key <linear> has been read 1 time(s) less than it was present in the configuration tree. info: Initialize processes. error: ConfigTree: There have been errors when parsing the configuration file(s): error: ConfigTree: In file
TestSet_01.prj’ at path <processes/process>: Key has been read 1 time(s) less than it was present in the configuration tree.
critical: E:/builds/4WZM6MEb/0/ogs/ogs/BaseLib/ConfigTree.cpp:258 BaseLib::ConfigTree::assertNoSwallowedErrors()
error: There have been errors when parsing the configuration file(s).
info: OGS terminated on 2022-10-26 17:09:28+0200.
does anyone know how to fix it?
Thanks for any suggestions!
Andrea
all input files are taken from the test folder: Tests/Data/Parabolic/LiquidFlow/Unconfined_Aquifer/BC_BC · master · ogs / ogs · GitLab
