I am trying to run a simulation that I worked on one of the benchmarks. I am getting an error like this.
Why are the described properties not used? Also, I used the generate structured mesh utility of OGS6.
But the error says, “element not found in the input range; Required mesh with name MICP.vtu is not found. My geometry is a 1D line element with a 0.5 m length. The number of mesh is 50.
What I am missing?
Here is the mesh creation command that I inspired:
And here is the error:
You can also find my simulation files. Thank you for your help.
MICP_v2.zip (6.5 KB)
