Just for repetition, the initial state will be included in the prj-file by lines like
251 <parameter>
252 <name>initial_p</name>
253 <type>MeshNode</type>
254 <field_name>pressure</field_name>
255 <mesh>results_equilibrium_ts_10_t_315360000000.000000</mesh>
256 </parameter>
311 <initial_condition>initial_p</initial_condition>
for details about stress I would refer to the code documentation (search in the examples of MeshNode for sigma or stress).
Anyway your questions seems to be how to set up a vtu-file (domain mesh) with the initial values, which obviously are not results from a previous OGS run.
So my recommendation is to add point- or cell-data to this mesh by python code like that
import numpy as np # for operations and data types
from scipy.interpolate import RegularGridInterpolator # for 3D interpolation
import meshio # read/write meshes
inputfile="mwe_input.vtu" # generateStructuredMesh -e hex --lx 10 --ly 10 --lz 10 --nx 20 --ny 20 --nz 20 -o mwe_input.vtu
outputfile="mwe_output.vtu"
nnn = np.array([25, 25, 25]) # divisions of data mesh (to be appended to input mesh) in x-, y-, z-direction
xyz = np.array([0,10, 0,10, 0,10]) # start end (x0,x1, y0,y1, z0,z1)
my_data = np.random.standard_normal(size=(nnn[0], nnn[1], nnn[2])) # generate some data
# data in domain: [X1R,X2R] [Y1R,Y2R] [ZBAS,Z2R]
NXW = nnn[0]
NYW = nnn[1]
NZW = nnn[2]
x = np.linspace(0.0, xyz[1]-xyz[0], NXW) # shifted to x=0 as mesh does
y = np.linspace(0.0, xyz[3]-xyz[2], NYW) # shifted to y=0 as mesh does
z = np.linspace(0.0, xyz[5]-xyz[4], NZW) # shifted to z=0 as mesh does
print("Data grid nxw, nyw, nzw: ", NXW, NYW, NZW)
print("Data grid x1,x2, y1,y2, zb,zr: ", xyz)
# read input mesh
mesh = meshio.read(inputfile)
print(f'Input mesh: {len(mesh.points)} points') # array
print(f'Input mesh: {len(mesh.cells[0].data)} cells') # dictionary
#print(mesh)
# interpolated data to input mesh ([0,LX] [0,LY] [0,LZ])
interpolating_function = RegularGridInterpolator((x, y, z),
my_data[0:NXW, 0:NYW, 0:NZW],
method='nearest',
bounds_error=False,
fill_value=None) # method='nearest', 'linear'
# TODO there may be multiple data on multiple cell blocks
cells_count = len(mesh.cells[0].data) # MeshIO < 5.0 cells_count = len(mesh.cells[0][1])
centerpoints=np.zeros((cells_count, 3)) # evaluate interpolation at center points
for cell_index, cellblock_cell in enumerate(mesh.cells[0].data): # MeshIO < 5.0 for cell_index, cellblock_cell in enumerate(mesh.cells[0][1]):
centerpoints[cell_index] = np.sum(mesh.points[cellblock_cell], axis=0) / len(cellblock_cell)
my_data_interpolation = interpolating_function(centerpoints)
my_data_min = np.min(my_data_interpolation)
my_data_max = np.max(my_data_interpolation)
print("Data appended to input mesh are within range {}...{}".format(my_data_min, my_data_max))
mesh.cell_data['my_data'] = [np.array(my_data_interpolation)] # append data
# write to file
meshio.write(outputfile, mesh)
Without the interpolation stuff the script may be easier, but I do not know what kind of data you have and where they come from.
