Initial conditions-3D HTM model
Dear Users and Developers,
I am running a 3 model for HTM processes. I have completed the HT models and seem to be working well; however, when I implemented the third effect (M); I am not getting any solution at all. I have assigned the initial conditions as they are showed in the benchmarks, for example:
GINA - Initial Condition
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 453.15
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 9810.00
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_XX
$GEO_TYPE
DOMAIN
$DIS_TYPE
FUNCTION -1.854e06+14.513e03*z
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
FUNCTION -1.176e06+22.491e03*z
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_ZZ
$GEO_TYPE
DOMAIN
$DIS_TYPE
FUNCTION 0.3e06+25.60e03*z
Since my calculations are at 4km depth, I was wondering what is the correct sign (+/-) for stresses that OGS recognizes. Is it (-) for compression and (+) for tension liek in convetional mechanics of materials. Or is it (+) for compression and negative for tension. Furthermore, what are the implications when using equations; is the depth(z) taken with the sign I modeled the geometry e.g. -4000m? I assume that all the units need to be transformed into Pascals like the pressures for the Hydraulic simulation.
Please let me know your opinions and advice. I will be very glad.
Jhonny Encalada
* The sign of stress or strain takes the conventional solid mechanics' one, i.e. + for tension.
* z takes the value of z coordinate of an node defined in the mesh data.
The initial stresses can be input as (in a benchmark directory of THM/init)
GeoSys-IC: Initial Conditions
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_XX
  $GEO_TYPE
   SUB_DOMAIN
    3
    0 -32.1e6+0.55e5*y
    1 -32.1e6+0.55e5*y
    2 -32.1e6+0.55e5*y
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_YY
  $GEO_TYPE
   SUB_DOMAIN
    3
    0 -13243500+26487*y
    1 -13243500+26487*y
    2 -13243500+26487*y
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_ZZ
  $GEO_TYPE
   SUB_DOMAIN
    3
    0 -10.6e6+0.2e5*y
    1 -10.6e6+0.2e5*y
    2 -10.6e6+0.2e5*y
Since one one domain is shown in your data, you input can be, for example,
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_YY
  $GEO_TYPE
   SUB_DOMAIN
    1
    0 -1.176e06+22.491e03*z
#INITIAL_CONDITION
  HEAT_TRANSPORT
$PRIMARY_VARIABLE
  TEMPERATURE1
$GEO_TYPE
  DOMAIN
$DIS_TYPE
  CONSTANT 453.15
#INITIAL_CONDITION
  LIQUID_FLOW
$PRIMARY_VARIABLE
  PRESSURE1
$GEO_TYPE
  DOMAIN
$DIS_TYPE
  GRADIENT 9810.00
#INITIAL_CONDITION
  DEFORMATION
$PRIMARY_VARIABLE
  STRESS_XX
$GEO_TYPE
  DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
  DEFORMATION
$PRIMARY_VARIABLE
  STRESS_YY
$GEO_TYPE
  DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
  DEFORMATION
$PRIMARY_VARIABLE
  STRESS_ZZ
$GEO_TYPE
  DOMAIN
$DIS_TYPE
Jhonny Encalada
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com <mailto:ogs-users+unsubscribe@googlegroups.com>.
Dear Wenqing Wang
Thanks for your help,
Regarding to your explanation about the sub-domain. I have 5 material groups actually; however I decided to assign the initial conditions to the WHOLE DOMAIN.
My material groups are numbered from 0,1,… to 4 and four materials are discrete fractures. The material No4 is the rock matrix. Let me know if I am mistaken please.
Thanks again!
Jhonny
  GeoSys-IC: Initial Conditions ------------------------------------------------
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_XX
   $GEO_TYPE
    SUB_DOMAIN
     3
     0   -32.1e6+0.55e5*y
     1     -32.1e6+0.55e5*y
     2    -32.1e6+0.55e5*y
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_YY
   $GEO_TYPE
    SUB_DOMAIN
     3
     0   -13243500+26487*y
     1   -13243500+26487*y
     2   -13243500+26487*y
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_ZZ
   $GEO_TYPE
    SUB_DOMAIN
     3
     0   -10.6e6+0.2e5*y
     1   -10.6e6+0.2e5*y
     2   -10.6e6+0.2e5*y
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_YY
   $GEO_TYPE
    SUB_DOMAIN
     1
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 453.15
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 9810.00
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_XX
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_ZZ
$GEO_TYPE
DOMAIN
$DIS_TYPE
Jhonny Encalada
  To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+...@googlegroups.com.
Then you have to input the initial stress data as
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_XX
  $GEO_TYPE
   SUB_DOMAIN
    5
    0 [expression of stress]
    1 [expression of stress]
    2 [expression of stress]
    3 [expression of stress]
    4 [expression of stress]
On 07/12/2016 07:35 PM, Jhonny Encalada wrote:
Dear Wenqing Wang
My material groups are numbered from 0,1,.. to 4 and four materials are discrete fractures. The material No4 is the rock matrix. Let me know if I am mistaken please.
Thanks again!
Jhonny
    mesh data.
    THM/init)
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      SUB_DOMAIN
       3
       0 -32.1e6+0.55e5*y
       1 -32.1e6+0.55e5*y
       2 -32.1e6+0.55e5*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       3
       0 -13243500+26487*y
       1 -13243500+26487*y
       2 -13243500+26487*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      SUB_DOMAIN
       3
       0 -10.6e6+0.2e5*y
       1 -10.6e6+0.2e5*y
       2 -10.6e6+0.2e5*y
    example,
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       1
    #INITIAL_CONDITION
      HEAT_TRANSPORT
     $PRIMARY_VARIABLE
      TEMPERATURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      CONSTANT 453.15
    #INITIAL_CONDITION
      LIQUID_FLOW
     $PRIMARY_VARIABLE
      PRESSURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      GRADIENT 9810.00
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    simulation.
    Jhonny Encalada
    -- You received this message because you are subscribed to the
    send an email to ogs-users+...@googlegroups.com <javascript:>.
    <https://groups.google.com/d/optout>.
Thanks for the help
The initial stresses are ok now. But I am getting result of deformation = 0.00 for every node; I am wondering what is going on?? In the VTK file, there is a column full of zeros. OGS is taking more than an hour to solve just the deformation process. Do you imagine what the problem would be? I apologize for the many inquiries. I am doing a coursework and there is not much time left for the submission.
Thanks,
Jhonny
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_XX
   $GEO_TYPE
    SUB_DOMAIN
     5
Dear Wenqing Wang
Thanks again!
Jhonny
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_XX
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -32.1e6+0.55e5*y
               1     -32.1e6+0.55e5*y
               2    -32.1e6+0.55e5*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_YY
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -13243500+26487*y
               1   -13243500+26487*y
               2   -13243500+26487*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_ZZ
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -10.6e6+0.2e5*y
               1   -10.6e6+0.2e5*y
               2   -10.6e6+0.2e5*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_YY
             $GEO_TYPE
              SUB_DOMAIN
               1
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 453.15
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 9810.00
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_XX
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_ZZ
$GEO_TYPE
DOMAIN
$DIS_TYPE
Jhonny Encalada
By the way,
I was thinking that the problem could be associated to the MSP. I have assigned the Elasticity properties as follows.
GINA - Material Solid Properties
#SOLID_PROPERTIES
$NAME
MSPFAULT
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
3 0.0 ; model_3: bishop=0.0 or 1.0
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT2
$DENSITY
1 2.85e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-005
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
; BISHOP-BIOT Model:
; Sigma_tot = Sigma_eff - Biot*bishop(S)*p_w
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT3
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT4
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPROCKMATRIX
$DENSITY
1 2.850e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+010
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
$PLASTICITY
MOHR-COULOMB
4903500
45 ;friction angle
0
2451750
0
0
I was wondering what characteristic I am missing. Are the friction angles in radiant? I was also thinking that the problem might be in the numerical NUM. Do I have to consider the overall coupling so that the thermal effects cause strain in my material?
Thanks!
  #INITIAL_CONDITION
    DEFORMATION
   $PRIMARY_VARIABLE
    STRESS_XX
   $GEO_TYPE
    SUB_DOMAIN
     5
Dear Wenqing Wang
Thanks again!
Jhonny
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_XX
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -32.1e6+0.55e5*y
               1     -32.1e6+0.55e5*y
               2    -32.1e6+0.55e5*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_YY
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -13243500+26487*y
               1   -13243500+26487*y
               2   -13243500+26487*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_ZZ
             $GEO_TYPE
              SUB_DOMAIN
               3
               0   -10.6e6+0.2e5*y
               1   -10.6e6+0.2e5*y
               2   -10.6e6+0.2e5*y
            #INITIAL_CONDITION
              DEFORMATION
             $PRIMARY_VARIABLE
              STRESS_YY
             $GEO_TYPE
              SUB_DOMAIN
               1
#INITIAL_CONDITION
HEAT_TRANSPORT
$PRIMARY_VARIABLE
TEMPERATURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 453.15
#INITIAL_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 9810.00
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_XX
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_ZZ
$GEO_TYPE
DOMAIN
$DIS_TYPE
Jhonny Encalada
The MSP looks not bad, though I don't think the following lines are necessary (why the gravity constant to zero?).
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
Have you checked whether a linear solver successfully converged?
Nori
On 07/13/2016 11:40 AM, Jhonny Encalada wrote:
By the way,
#SOLID_PROPERTIES
  $NAME
MSPFAULT
  $DENSITY
   1 2.85e+03
  $ELASTICITY
   POISSION 0.25
   YOUNGS_MODULUS
   1 6.00e+09
  $THERMAL
   EXPANSION
   1.000e-05
   CAPACITY
   1 1.017e+003
   CONDUCTIVITY
   1 3.00e+000
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
#SOLID_PROPERTIES
  $NAME
MSPFRACT2
  $DENSITY
   1 2.85e+003
  $ELASTICITY
   POISSION 0.25
   YOUNGS_MODULUS
   1 6.00e+09
  $THERMAL
   EXPANSION
   1.00e-005
   CAPACITY
   1 1.017e+003
   CONDUCTIVITY
   1 3.00e+000
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
#SOLID_PROPERTIES
  $NAME
MSPFRACT3
  $DENSITY
   1 2.85e+03
  $ELASTICITY
   POISSION 0.25
   YOUNGS_MODULUS
   1 6.00e+09
  $THERMAL
   EXPANSION
   1.000e-05
   CAPACITY
   1 1.017e+003
   CONDUCTIVITY
   1 3.00e+000
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
#SOLID_PROPERTIES
  $NAME
MSPFRACT4
  $DENSITY
   1 2.85e+03
  $ELASTICITY
   POISSION 0.25
   YOUNGS_MODULUS
   1 6.00e+09
  $THERMAL
   EXPANSION
   1.00e-05
   CAPACITY
   1 1.017e+003
   CONDUCTIVITY
   1 3.00e+000
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
#SOLID_PROPERTIES
  $NAME
  MSPROCKMATRIX
  $DENSITY
   1 2.850e+003
  $ELASTICITY
   POISSION 0.25
   YOUNGS_MODULUS
   1 6.00e+010
  $THERMAL
   EXPANSION
   1.00e-05
   CAPACITY
   1 1.017e+003
   CONDUCTIVITY
   1 3.00e+000
  $BIOT_CONSTANT
   1.0
  BISHOP_COEFFICIENT
  $GRAVITY_CONSTANT
   0
  $SOLID_BULK_MODULUS
   1.e-9
$PLASTICITY
   MOHR-COULOMB
   4903500
   45 ;friction angle
   0
   2451750
   0
Thanks!
    #INITIAL_CONDITION
       DEFORMATION
      $PRIMARY_VARIABLE
       STRESS_XX
      $GEO_TYPE
       SUB_DOMAIN
        5
> Dear Wenqing Wang
> Thanks again!
> Jhonny
> mesh data.
> of THM/init)
> #INITIAL_CONDITION
> $PCS_TYPE
> DEFORMATION
> $PRIMARY_VARIABLE
> STRESS_XX
> $GEO_TYPE
> SUB_DOMAIN
> 3
> 0 -32.1e6+0.55e5*y
> 1 -32.1e6+0.55e5*y
> 2 -32.1e6+0.55e5*y
> #INITIAL_CONDITION
> $PCS_TYPE
> DEFORMATION
> $PRIMARY_VARIABLE
> STRESS_YY
> $GEO_TYPE
> SUB_DOMAIN
> 3
> 0 -13243500+26487*y
> 1 -13243500+26487*y
> 2 -13243500+26487*y
> #INITIAL_CONDITION
> $PCS_TYPE
> DEFORMATION
> $PRIMARY_VARIABLE
> STRESS_ZZ
> $GEO_TYPE
> SUB_DOMAIN
> 3
> 0 -10.6e6+0.2e5*y
> 1 -10.6e6+0.2e5*y
> 2 -10.6e6+0.2e5*y
> #STOP
> for example,
> #INITIAL_CONDITION
> $PCS_TYPE
> DEFORMATION
> $PRIMARY_VARIABLE
> STRESS_YY
> $GEO_TYPE
> SUB_DOMAIN
> 1
>> #INITIAL_CONDITION
>> $PCS_TYPE
>> HEAT_TRANSPORT
>> $PRIMARY_VARIABLE
>> TEMPERATURE1
>> $GEO_TYPE
>> DOMAIN
>> $DIS_TYPE
>> CONSTANT 453.15
>> #INITIAL_CONDITION
>> $PCS_TYPE
>> LIQUID_FLOW
>> $PRIMARY_VARIABLE
>> PRESSURE1
>> $GEO_TYPE
>> DOMAIN
>> $DIS_TYPE
>> GRADIENT 9810.00
>> #INITIAL_CONDITION
>> $PCS_TYPE
>> DEFORMATION
>> $PRIMARY_VARIABLE
>> STRESS_XX
>> $GEO_TYPE
>> DOMAIN
>> $DIS_TYPE
>> #INITIAL_CONDITION
>> $PCS_TYPE
>> DEFORMATION
>> $PRIMARY_VARIABLE
>> STRESS_YY
>> $GEO_TYPE
>> DOMAIN
>> $DIS_TYPE
>> #INITIAL_CONDITION
>> $PCS_TYPE
>> DEFORMATION
>> $PRIMARY_VARIABLE
>> STRESS_ZZ
>> $GEO_TYPE
>> DOMAIN
>> $DIS_TYPE
>> #STOP
>> Jhonny Encalada
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
Telefon +49 341 235 1806
Dear Norihiro,
Thanks for the reply. I have modified the MSP file and eliminated the unnecessary information. I also modified to NUM file so the calculation can converge fast. I dont have problems with the H and T processes; however the Deformation PCS is still with defect. In the results, I am getting “zero effective strain” and the stress invariants “p” and “q” have reasonable values for some sones “sinks”. The diagram of stresses in the VTK files is giving me a correct initial stress distribution; the stress in the fracture zones is decreasing with time; however, there are !no strains to show!. The deformation process takes about 30 min per step. and H and T take 2-3 min per step. When I use overall coupling, the deformations process does not converge and I have been running 1 step for almost 4 hours without any result.
About the gravity constant, I assumed it was zero, because I assumed an initial stress field, and I thought the thermal expansion was the unique effect to consider and not gravitational loads. Is this assumption correct? I am a little confused about the “gravity constant”. I was wondering whether it is “gravity aceleratio” or any other constant. I don’t understand its function very well.
Regarding to the PERMEABILITY FUCTION STRAIN. I found some functions, but are for PERMEABILITY_SATURATION. In the OGS, is the relative permeability in the range [0, 1]?. I want to know this, because I am assuming any function to run the model.
I will be glad that you give me some clues about the defects of my model. Thanks in advance!
Jhonny Encalada
On Monday, 18 July 2016 06:14:10 UTC+1, Norihiro Watanabe wrote:
The MSP looks not bad, though I don’t think the following lines are necessary (why the gravity constant to zero?).
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
Nori
By the way,
#SOLID_PROPERTIES
$NAME
MSPFAULT
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT2
$DENSITY
1 2.85e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-005
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT3
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT4
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPROCKMATRIX
$DENSITY
1 2.850e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+010
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
$PLASTICITY
MOHR-COULOMB
4903500
45 ;friction angle
0
2451750
0
0
Thanks!
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_XX
  $GEO_TYPE
   SUB_DOMAIN
    5
Dear Wenqing Wang
Thanks again!
Jhonny
    mesh data.
    of THM/init)
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -32.1e6+0.55e5*y
       1     -32.1e6+0.55e5*y
       2    -32.1e6+0.55e5*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -13243500+26487*y
       1   -13243500+26487*y
       2   -13243500+26487*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -10.6e6+0.2e5*y
       1   -10.6e6+0.2e5*y
       2   -10.6e6+0.2e5*y
    for example,
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       1
    #INITIAL_CONDITION
      HEAT_TRANSPORT
     $PRIMARY_VARIABLE
      TEMPERATURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      CONSTANT   453.15
    #INITIAL_CONDITION
      LIQUID_FLOW
     $PRIMARY_VARIABLE
      PRESSURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      GRADIENT   9810.00
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    Jhonny Encalada
    <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>.
Groups “ogs-users” group.
mailto:ogs-users+...@googlegroups.com.
Wissenschaftler
norihiro...@ufz.de / http://www.ufz.de
By the way,
I enclose a compilation of the files I wrote. I hope you can check it.
Thanks!
model.txt (6.59 KB)
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
Nori
By the way,
#SOLID_PROPERTIES
$NAME
MSPFAULT
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT2
$DENSITY
1 2.85e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-005
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT3
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.000e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPFRACT4
$DENSITY
1 2.85e+03
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+09
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
#SOLID_PROPERTIES
$NAME
MSPROCKMATRIX
$DENSITY
1 2.850e+003
$ELASTICITY
POISSION 0.25
YOUNGS_MODULUS
1 6.00e+010
$THERMAL
EXPANSION
1.00e-05
CAPACITY
1 1.017e+003
CONDUCTIVITY
1 3.00e+000
$BIOT_CONSTANT
1.0
BISHOP_COEFFICIENT
$GRAVITY_CONSTANT
0
$SOLID_BULK_MODULUS
1.e-9
$PLASTICITY
MOHR-COULOMB
4903500
45 ;friction angle
0
2451750
0
0
Thanks!
#INITIAL_CONDITION
   DEFORMATION
  $PRIMARY_VARIABLE
   STRESS_XX
  $GEO_TYPE
   SUB_DOMAIN
    5
Dear Wenqing Wang
Thanks again!
Jhonny
    mesh data.
    of THM/init)
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -32.1e6+0.55e5*y
       1     -32.1e6+0.55e5*y
       2    -32.1e6+0.55e5*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -13243500+26487*y
       1   -13243500+26487*y
       2   -13243500+26487*y
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      SUB_DOMAIN
       3
       0   -10.6e6+0.2e5*y
       1   -10.6e6+0.2e5*y
       2   -10.6e6+0.2e5*y
    for example,
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      SUB_DOMAIN
       1
    #INITIAL_CONDITION
      HEAT_TRANSPORT
     $PRIMARY_VARIABLE
      TEMPERATURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      CONSTANT   453.15
    #INITIAL_CONDITION
      LIQUID_FLOW
     $PRIMARY_VARIABLE
      PRESSURE1
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
      GRADIENT   9810.00
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_XX
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_YY
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    #INITIAL_CONDITION
      DEFORMATION
     $PRIMARY_VARIABLE
      STRESS_ZZ
     $GEO_TYPE
      DOMAIN
     $DIS_TYPE
    Jhonny Encalada
Wissenschaftler
Thanks for the file. It helps
The problem in your setting is that you are trying to use fracture elements for DEFORMATION process. I'm afraid that current OGS does not support it yet. To include mechanical effects into your simulation, you need to either
1) exclude them from mechanic simulation with $DEACTIVATED_SUBDOMAIN keyword in PCS (i.e. no opening and slip effect of fractures)
https://svn.ufz.de/ogs/wiki/public/doc-auto/by_ext/pcs/S_deactivated_subdomain
or 2) use thin volumetric elements for the fractures
Nori
On 07/18/2016 10:02 AM, Jhonny Encalada wrote:
By the way,
Thanks!
       $BIOT_CONSTANT
        1.0
       BISHOP_COEFFICIENT
       $GRAVITY_CONSTANT
        0
       $SOLID_BULK_MODULUS
        1.e-9
    Nori
     > By the way,
     > I was thinking that the problem could be associated to the MSP. I
    have
     > assigned the Elasticity properties as follows.
     > GINA - Material Solid Properties
     > #SOLID_PROPERTIES
     > $NAME
     > MSPFAULT
     > $DENSITY
     > 1 2.85e+03
     > $ELASTICITY
     > POISSION 0.25
     > YOUNGS_MODULUS
     > 1 6.00e+09
     > $THERMAL
     > EXPANSION
     > 1.000e-05
     > CAPACITY
     > 1 1.017e+003
     > CONDUCTIVITY
     > 1 3.00e+000
     > $BIOT_CONSTANT
     > 1.0
     > BISHOP_COEFFICIENT
     > 3 0.0 ; model_3: bishop=0.0 or 1.0
     > $GRAVITY_CONSTANT
     > 0
     > $SOLID_BULK_MODULUS
     > 1.e-9
     > #SOLID_PROPERTIES
     > $NAME
     > MSPFRACT2
     > $DENSITY
     > 1 2.85e+003
     > $ELASTICITY
     > POISSION 0.25
     > YOUNGS_MODULUS
     > 1 6.00e+09
     > $THERMAL
     > EXPANSION
     > 1.00e-005
     > CAPACITY
     > 1 1.017e+003
     > CONDUCTIVITY
     > 1 3.00e+000
     > ; BISHOP-BIOT Model:
     > ; Sigma_tot = Sigma_eff - Biot*bishop(S)*p_w
     > $BIOT_CONSTANT
     > 1.0
     > $GRAVITY_CONSTANT
     > 0
     > 1.e-9
     > #SOLID_PROPERTIES
     > $NAME
     > MSPFRACT3
     > $DENSITY
     > 1 2.85e+03
     > $ELASTICITY
     > POISSION 0.25
     > YOUNGS_MODULUS
     > 1 6.00e+09
     > $THERMAL
     > EXPANSION
     > 1.000e-05
     > CAPACITY
     > 1 1.017e+003
     > CONDUCTIVITY
     > 1 3.00e+000
     > $BIOT_CONSTANT
     > 1.0
     > $GRAVITY_CONSTANT
     > 0
     > 1.e-9
     > #SOLID_PROPERTIES
     > $NAME
     > MSPFRACT4
     > $DENSITY
     > 1 2.85e+03
     > $ELASTICITY
     > POISSION 0.25
     > YOUNGS_MODULUS
     > 1 6.00e+09
     > $THERMAL
     > EXPANSION
     > 1.00e-05
     > CAPACITY
     > 1 1.017e+003
     > CONDUCTIVITY
     > 1 3.00e+000
     > $BIOT_CONSTANT
     > 1.0
     > $GRAVITY_CONSTANT
     > 0
     > 1.e-9
     > #SOLID_PROPERTIES
     > $NAME
     > MSPROCKMATRIX
     > $DENSITY
     > 1 2.850e+003
     > $ELASTICITY
     > POISSION 0.25
     > YOUNGS_MODULUS
     > 1 6.00e+010
     > $THERMAL
     > EXPANSION
     > 1.00e-05
     > CAPACITY
     > 1 1.017e+003
     > CONDUCTIVITY
     > 1 3.00e+000
     > $BIOT_CONSTANT
     > 1.0
     > $GRAVITY_CONSTANT
     > 0
     > 1.e-9
     > #STOP
     > $PLASTICITY
     > MOHR-COULOMB
     > 4903500
     > 45 ;friction angle
     > 0
     > 2451750
     > 0
     > I was wondering what characteristic I am missing. Are the friction
     > angles in radiant? I was also thinking that the problem might be
    in the
     > numerical NUM. Do I have to consider the overall coupling so that
    the
     > thermal effects cause strain in my material?
     > Thanks!
     > On Wednesday, 13 July 2016 09:05:58 UTC+1, Wenqing Wang wrote:
     > Then you have to input the initial stress data as
     > #INITIAL_CONDITION
     > $PCS_TYPE
     > DEFORMATION
     > $PRIMARY_VARIABLE
     > STRESS_XX
     > $GEO_TYPE
     > SUB_DOMAIN
     > 5
     > 0 [expression of stress]
     > 1 [expression of stress]
     > 2 [expression of stress]
     > 3 [expression of stress]
     > 4 [expression of stress]
     > On 07/12/2016 07:35 PM, Jhonny Encalada wrote:
     > > Dear Wenqing Wang
     > > Thanks for your help,
     > > Regarding to your explanation about the sub-domain. I have 5
     > > material groups actually; however I decided to assign the
    initial
     > > conditions to the WHOLE DOMAIN.
     > > My material groups are numbered from 0,1,.. to 4 and four
     > > materials are discrete fractures. The material No4 is the rock
     > > matrix. Let me know if I am mistaken please.
     > > Thanks again!
     > > Jhonny
     > > On Tuesday, 12 July 2016 17:09:59 UTC+1, Wenqing Wang wrote:
     > > * The sign of stress or strain takes the conventional
    solid
     > > mechanics' one, i.e. + for tension.
     > > * z takes the value of z coordinate of an node defined
    in the
     > > mesh data.
     > > The initial stresses can be input as (in a benchmark
    directory
     > > of THM/init)
     > > GeoSys-IC: Initial Conditions
     > > #INITIAL_CONDITION
     > > $PCS_TYPE
     > > DEFORMATION
     > > $PRIMARY_VARIABLE
     > > STRESS_XX
     > > $GEO_TYPE
     > > SUB_DOMAIN
     > > 3
     > > 0 -32.1e6+0.55e5*y
     > > 1 -32.1e6+0.55e5*y
     > > 2 -32.1e6+0.55e5*y
     > > $PCS_TYPE
     > > DEFORMATION
     > > STRESS_YY
     > > $GEO_TYPE
     > > SUB_DOMAIN
     > > 3
     > > 0 -13243500+26487*y
     > > 1 -13243500+26487*y
     > > 2 -13243500+26487*y
     > > $PCS_TYPE
     > > DEFORMATION
     > > STRESS_ZZ
     > > $GEO_TYPE
     > > SUB_DOMAIN
     > > 3
     > > 0 -10.6e6+0.2e5*y
     > > 1 -10.6e6+0.2e5*y
     > > 2 -10.6e6+0.2e5*y
     > > #STOP
     > > Since one one domain is shown in your data, you input
    can be,
     > > for example,
     > > $PCS_TYPE
     > > DEFORMATION
     > > STRESS_YY
     > > $GEO_TYPE
     > > SUB_DOMAIN
     > > 1
     > > 0 -1.176e06+22.491e03*z
     > > On 07/12/2016 05:06 PM, Jhonny Encalada wrote:
     > >> Dear Users and Developers,
     > >> I am running a 3 model for HTM processes. I have
    completed
     > >> the HT models and seem to be working well; however,
    when I
     > >> implemented the third effect (M); I am not getting any
     > >> solution at all. I have assigned the initial
    conditions as
     > >> they are showed in the benchmarks, for example:
     > >> GINA - Initial Condition
     > >> #INITIAL_CONDITION
     > >> $PCS_TYPE
     > >> HEAT_TRANSPORT
     > >> $PRIMARY_VARIABLE
     > >> TEMPERATURE1
     > >> $GEO_TYPE
     > >> DOMAIN
     > >> $DIS_TYPE
     > >> CONSTANT 453.15
     > >> $PCS_TYPE
     > >> LIQUID_FLOW
     > >> PRESSURE1
     > >> $GEO_TYPE
     > >> DOMAIN
     > >> $DIS_TYPE
     > >> GRADIENT 9810.00
     > >> $PCS_TYPE
     > >> DEFORMATION
     > >> STRESS_XX
     > >> $GEO_TYPE
     > >> DOMAIN
     > >> $DIS_TYPE
     > >> FUNCTION -1.854e06+14.513e03*z
     > >> $PCS_TYPE
     > >> DEFORMATION
     > >> STRESS_YY
     > >> $GEO_TYPE
     > >> DOMAIN
     > >> $DIS_TYPE
     > >> FUNCTION -1.176e06+22.491e03*z
     > >> $PCS_TYPE
     > >> DEFORMATION
     > >> STRESS_ZZ
     > >> $GEO_TYPE
     > >> DOMAIN
     > >> $DIS_TYPE
     > >> FUNCTION 0.3e06+25.60e03*z
     > >> #STOP
     > >> Since my calculations are at 4km depth, I was
    wondering what
     > >> is the correct sign (+/-) for stresses that OGS
    recognizes.
     > >> Is it (-) for compression and (+) for tension liek in
     > >> convetional mechanics of materials. Or is it (+) for
     > >> compression and negative for tension. Furthermore,
    what are
     > >> the implications when using equations; is the depth(z)
    taken
     > >> with the sign I modeled the geometry e.g. -4000m? I
    assume
     > >> that all the units need to be transformed into Pascals
    like
     > >> the pressures for the Hydraulic simulation.
     > >> Please let me know your opinions and advice. I will be
    very glad.
     > >> Jhonny Encalada
     > >> You received this message because you are subscribed
    to the
     > >> Google Groups "ogs-users" group.
     > >> To unsubscribe from this group and stop receiving
    emails from
     > >> it, send an email to ogs-users+...@googlegroups.com.
     > >> For more options, visit
     > >> <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout>>.
     > > You received this message because you are subscribed to the
    Google
     > > Groups "ogs-users" group.
     > > To unsubscribe from this group and stop receiving emails
    from it,
     > > send an email to ogs-users+...@googlegroups.com <javascript:>.
     > > For more options, visit https://groups.google.com/d/optout
     > > <https://groups.google.com/d/optout
     > You received this message because you are subscribed to the Google
     > To unsubscribe from this group and stop receiving emails from it,
    send
     > an email to ogs-users+...@googlegroups.com <javascript:>
     > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
    Wissenschaftler
    norihiro...@ufz.de <javascript:> / http://www.ufz.de
Wissenschaftler
Dear Norihiro,
The first option sounds good; for the second I would have to change everything I have done.
Thank you !
The problem in your setting is that you are trying to use fracture elements for DEFORMATION process. I’m afraid that current OGS does not support it yet. To include mechanical effects into your simulation, you need to either
  1. exclude them from mechanic simulation with $DEACTIVATED_SUBDOMAIN keyword in PCS (i.e. no opening and slip effect of fractures)
Nori
By the way,
Thanks!
   $BIOT_CONSTANT
    1.0
   BISHOP_COEFFICIENT
   $GRAVITY_CONSTANT
    0
   $SOLID_BULK_MODULUS
    1.e-9
Nori
 > By the way,
have
 > #SOLID_PROPERTIES
 >   $NAME
 > MSPFAULT
 >   $DENSITY
 >    1 2.85e+03
 >   $ELASTICITY
 >    POISSION 0.25
 >    YOUNGS_MODULUS
 >    1 6.00e+09
 >   $THERMAL
 >    EXPANSION
 >    1.000e-05
 >    CAPACITY
 >    1 1.017e+003
 >    CONDUCTIVITY
 >    1 3.00e+000
 >   $BIOT_CONSTANT
 >    1.0
 >   BISHOP_COEFFICIENT
 >   $GRAVITY_CONSTANT
 >    0
 >   $SOLID_BULK_MODULUS
 >    1.e-9
 > #SOLID_PROPERTIES
 >   $NAME
 > MSPFRACT2
 >   $DENSITY
 >    1 2.85e+003
 >   $ELASTICITY
 >    POISSION 0.25
 >    YOUNGS_MODULUS
 >    1 6.00e+09
 >   $THERMAL
 >    EXPANSION
 >    1.00e-005
 >    CAPACITY
 >    1 1.017e+003
 >    CONDUCTIVITY
 >    1 3.00e+000
 >   $BIOT_CONSTANT
 >    1.0
 >   BISHOP_COEFFICIENT
 >   $GRAVITY_CONSTANT
 >    0
 >   $SOLID_BULK_MODULUS
 >    1.e-9
 > #SOLID_PROPERTIES
 >   $NAME
 > MSPFRACT3
 >   $DENSITY
 >    1 2.85e+03
 >   $ELASTICITY
 >    POISSION 0.25
 >    YOUNGS_MODULUS
 >    1 6.00e+09
 >   $THERMAL
 >    EXPANSION
 >    1.000e-05
 >    CAPACITY
 >    1 1.017e+003
 >    CONDUCTIVITY
 >    1 3.00e+000
 >   $BIOT_CONSTANT
 >    1.0
 >   BISHOP_COEFFICIENT
 >   $GRAVITY_CONSTANT
 >    0
 >   $SOLID_BULK_MODULUS
 >    1.e-9
 > #SOLID_PROPERTIES
 >   $NAME
 > MSPFRACT4
 >   $DENSITY
 >    1 2.85e+03
 >   $ELASTICITY
 >    POISSION 0.25
 >    YOUNGS_MODULUS
 >    1 6.00e+09
 >   $THERMAL
 >    EXPANSION
 >    1.00e-05
 >    CAPACITY
 >    1 1.017e+003
 >    CONDUCTIVITY
 >    1 3.00e+000
 >   $BIOT_CONSTANT
 >    1.0
 >   BISHOP_COEFFICIENT
 >   $GRAVITY_CONSTANT
 >    0
 >   $SOLID_BULK_MODULUS
 >    1.e-9
 > #SOLID_PROPERTIES
 >   $NAME
 >   MSPROCKMATRIX
 >   $DENSITY
 >    1 2.850e+003
 >   $ELASTICITY
 >    POISSION 0.25
 >    YOUNGS_MODULUS
 >    1 6.00e+010
 >   $THERMAL
 >    EXPANSION
 >    1.00e-05
 >    CAPACITY
 >    1 1.017e+003
 >    CONDUCTIVITY
 >    1 3.00e+000
 >   $BIOT_CONSTANT
 >    1.0
 >   BISHOP_COEFFICIENT
 >   $GRAVITY_CONSTANT
 >    0
 >   $SOLID_BULK_MODULUS
 >    1.e-9
 > #STOP
 > $PLASTICITY
 >    MOHR-COULOMB
 >    4903500
 >    45                    ;friction angle
 >    0
 >    2451750
 >    0
 >    0
in the
the
 > Thanks!
 >     #INITIAL_CONDITION
 >       $PCS_TYPE
 >        DEFORMATION
 >       $PRIMARY_VARIABLE
 >        STRESS_XX
 >       $GEO_TYPE
 >        SUB_DOMAIN
 >         5
 > >     Dear Wenqing Wang
initial
 > >     Thanks again!
 > >     Jhonny
solid
in the
 > >         mesh data.
directory
 > >         of THM/init)
 > >         #INITIAL_CONDITION
 > >          $PCS_TYPE
 > >           DEFORMATION
 > >          $PRIMARY_VARIABLE
 > >           STRESS_XX
 > >          $GEO_TYPE
 > >           SUB_DOMAIN
 > >            3
 > >            0   -32.1e6+0.55e5*y
 > >            1     -32.1e6+0.55e5*y
 > >            2    -32.1e6+0.55e5*y
 > >         #INITIAL_CONDITION
 > >          $PCS_TYPE
 > >           DEFORMATION
 > >          $PRIMARY_VARIABLE
 > >           STRESS_YY
 > >          $GEO_TYPE
 > >           SUB_DOMAIN
 > >            3
 > >            0   -13243500+26487*y
 > >            1   -13243500+26487*y
 > >            2   -13243500+26487*y
 > >         #INITIAL_CONDITION
 > >          $PCS_TYPE
 > >           DEFORMATION
 > >          $PRIMARY_VARIABLE
 > >           STRESS_ZZ
 > >          $GEO_TYPE
 > >           SUB_DOMAIN
 > >            3
 > >            0   -10.6e6+0.2e5*y
 > >            1   -10.6e6+0.2e5*y
 > >            2   -10.6e6+0.2e5*y
 > >         #STOP
can be,
 > >         for example,
 > >         #INITIAL_CONDITION
 > >          $PCS_TYPE
 > >           DEFORMATION
 > >          $PRIMARY_VARIABLE
 > >           STRESS_YY
 > >          $GEO_TYPE
 > >           SUB_DOMAIN
 > >            1
completed
when I
conditions as
 > >>         #INITIAL_CONDITION
 > >>          $PCS_TYPE
 > >>           HEAT_TRANSPORT
 > >>          $PRIMARY_VARIABLE
 > >>           TEMPERATURE1
 > >>          $GEO_TYPE
 > >>           DOMAIN
 > >>          $DIS_TYPE
 > >>           CONSTANT   453.15
 > >>         #INITIAL_CONDITION
 > >>          $PCS_TYPE
 > >>           LIQUID_FLOW
 > >>          $PRIMARY_VARIABLE
 > >>           PRESSURE1
 > >>          $GEO_TYPE
 > >>           DOMAIN
 > >>          $DIS_TYPE
 > >>           GRADIENT   9810.00
 > >>         #INITIAL_CONDITION
 > >>          $PCS_TYPE
 > >>           DEFORMATION
 > >>          $PRIMARY_VARIABLE
 > >>           STRESS_XX
 > >>          $GEO_TYPE
 > >>           DOMAIN
 > >>          $DIS_TYPE
 > >>         #INITIAL_CONDITION
 > >>          $PCS_TYPE
 > >>           DEFORMATION
 > >>          $PRIMARY_VARIABLE
 > >>           STRESS_YY
 > >>          $GEO_TYPE
 > >>           DOMAIN
 > >>          $DIS_TYPE
 > >>         #INITIAL_CONDITION
 > >>          $PCS_TYPE
 > >>           DEFORMATION
 > >>          $PRIMARY_VARIABLE
 > >>           STRESS_ZZ
 > >>          $GEO_TYPE
 > >>           DOMAIN
 > >>          $DIS_TYPE
 > >>         #STOP
wondering what
recognizes.
what are
taken
assume
like
very glad.
 > >>         Jhonny Encalada
to the
emails from
[https://groups.google.com/d/optout](https://groups.google.com/d/optout) <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>.
Google
from it,
send
Wissenschaftler
norihiro...@ufz.de <javascript:> / [http://www.ufz.de](http://www.ufz.de)
Wissenschaftler
