@Shuang, many thanks for replying and to clarify the documentation!
Have I correctly amended lines 237~238 in the prj file?
i.e the succession (eight lines) of “repeat …delta_t” ?
<time_stepping>
<type>FixedTimeStepping</type>
<t_initial> 0.0 </t_initial>
<!-- use the following for full simulation
<t_end> 15552000 </t_end>
<timesteps>
</pair>
<repeat>10</repeat>
<delta_t>60</delta_t>
<repeat>1</repeat>
<delta_t>3000</delta_t>
<repeat>5</repeat>
<delta_t>3600</delta_t>
<repeat>1</repeat>
<delta_t>10800</delta_t>
</pair>
<!-- <pair>
<repeat>10</repeat>
</pair>
</timesteps>
</time_stepping>
I will read through your answer for 1) regarding the 41-42 degC problem.
Intuitively I can follow the logic,
but I am uncertain as to what I should be changing to get the correct result?
