I would like to apply a Neumann boundary condition on a vertical surface. This boundary condition is depth dependant.
How to combine the $DIS_TYPE CONSTANT_NEUMANN and the depth dependency?
Is there something similar for the source term to the keyword $DIS_TYPE GRADIENT for boundary condition?
Thanks a lot in advance.
Antoine
Hi Antoine,
with a POLYLINE, you could use this as a boundary condition:
#BOUNDARY_CONDITION
LIQUID_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
POLYLINE RIGHT
$DIS_TYPE
FUNCTION
0+-9810*z
I guess, it will also work with SURFACEs, but I don't know if it works for SOURCE_TERMS. Maybe, Wenqing knows, as FUNCTION is his implementation...
Marc
On 02.12.2014 12:53, Antoine Jacquey wrote:
Antoine
Hi Marc,
Thanks for your answer.
I also noticed in an old manual pdf file a keyword $LINEAR_NEUMANN.
I’m not sure if this still works but I will give it a try.
Thanks again.
Antoine
Hi Antoine,
I guess, LINEAR_NEUMANN is only working with POLYLINES.
I remember, that Norbert Böttcher was trying to use FUNCTIONS with source terms, but I don't know how he solved that. Unfortunately, he is currently not at work - maybe Thomas Nagel has some info...
Marc
On 03.12.2014 12:37, Antoine Jacquey wrote:
Hi Marc,
I'm not sure if this still works but I will give it a try.
Thanks again.
Antoine
Would the $DATA_BASE option be a possible way of doing that? With an csv file with the values.
If yes, do you know a bechmark using this keyword so I can check it the convention of the csv file?
Thank yout in advance.
