I am wondering how to model heat plumes originating from groundwater pumps (e.g. reinjection of warm water back to the ground water). By assigning a boundary condition for the temperature at the reinjection node (dirichlet BC) within a rfd file, the temperature can be set (at all times). If the groundwater pump is only used once in a while (e.g 2 hours per day and the temporal source term is defined in a rfd file), there ist still heat orginating from the reinjection node if the pump is not reinjecting water, as there ist still a regional ground water flow, that passes the reinjection node. Is there a way to temporarily switch off the temparature boundary condition at the reinjection node (that is by temporarily not defining a certain temperature in the boundary condition)?
Am Mittwoch, 21. Dezember 2016 16:51:12 UTC+1 schrieb pmb...@gmail.com:
Dear OGS users
