Hi everyone,
I have encountered some problems using Gmsh for preprocessing.
First, I used Gmsh to generate a PJ.geo file, and then exported the corresponding PJ.msh file (Version 2 ASCII format).
Afterwards, I successfully converted the PJ.msh file to a PJ.vtu file using the following command:
PS D:\Projects> .\GMSH2OGS -i PJ.msh -o PJ.vtu -e
To ensure the PJ.vtu file was correct, I executed the following command:
PS D:\Projects> .\checkMesh PJ.vtu -p -v
However, the following error message appeared:
[2026-04-20 16:56:21.114] [ogs] [info] 75 elements found with wrong node order.
ElementIDs: 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460, 461, 462, 463, 464, 465, 466, 467, 468, 469, 470, 471, 472, 473, 474,
I am not sure which step or part is causing the problem. The PJ.geo file is attached below.
// Gmsh project created on Mon Apr 20 13:44:26 2026
SetFactory(“OpenCASCADE”);
Point(1) = {0, 0, 0, 1};
Point(2) = {0, 0.75e-2, 0, 1};
Point(3) = {0, -0.75e-2, 0, 1};
Point(4) = {0, 10e-2, 0, 1};
Point(5) = {0, -7e-2, 0, 1};
Point(6) = {5e-2, 0, 0, 1};
Point(7) = {5e-2, 0.75e-2, 0, 1};
Point(8) = {5e-2, -0.75e-2, 0, 1};
Point(9) = {5e-2, 10e-2, 0, 1};
Point(10) = {5e-2, -7e-2, 0, 1};
Point(11) = {15e-2, 0, 0, 1};
Point(12) = {15e-2, 0.75e-2, 0, 1};
Point(13) = {15e-2, -0.75e-2, 0, 1};
Point(14) = {15e-2, 10e-2, 0, 1};
Point(15) = {15e-2, -7e-2, 0, 1};
Point(16) = {26.5e-2, 0, 0, 1};
Point(17) = {26.5e-2, 0.75e-2, 0, 1};
Point(18) = {26.5e-2, -0.75e-2, 0, 1};
Point(19) = {26.5e-2, 10e-2, 0, 1};
Point(20) = {26.5e-2, -7e-2, 0, 1};
Line(1) = {4, 2};
Line(2) = {1, 2};
Line(3) = {1, 3};
Line(4) = {3, 5};
Line(5) = {5, 10};
Line(6) = {10, 15};
Line(7) = {15, 20};
Line(8) = {20, 18};
Line(9) = {18, 16};
Line(10) = {16, 17};
Line(11) = {17, 19};
Line(12) = {19, 14};
Line(13) = {9, 14};
Line(14) = {9, 4};
Line(15) = {2, 7};
Line(16) = {7, 12};
Line(17) = {12, 17};
Line(18) = {1, 6};
Line(19) = {6, 11};
Line(20) = {11, 16};
Line(21) = {3, 8};
Line(22) = {8, 13};
Line(23) = {13, 18};
Line(24) = {9, 7};
Line(25) = {6, 7};
Line(26) = {6, 8};
Line(27) = {8, 10};
Line(28) = {14, 12};
Line(29) = {12, 11};
Line(30) = {11, 13};
Line(31) = {13, 15};
Transfinite Curve {12, 17, 20, 23, 7, 6, 22, 19, 16, 13, 1, 24, 28, 11} = 11 Using Progression 1;
Transfinite Curve {2, 3, 25, 26, 29, 30, 10, 9} = 2 Using Progression 1;
Transfinite Curve {14, 15, 18, 21, 5} = 6 Using Progression 1;
Transfinite Curve {4, 27, 31, 8} = 8 Using Progression 1;
Curve Loop(1) = {1, 15, 24, 14};
Plane Surface(1) = {1};
Curve Loop(2) = {24, 16, 28, 13};
Plane Surface(2) = {2};
Curve Loop(3) = {28, 17, 11, 12};
Plane Surface(3) = {3};
Curve Loop(4) = {29, 20, 10, 17};
Plane Surface(4) = {4};
Curve Loop(5) = {20, 9, 23, 30};
Plane Surface(5) = {5};
Curve Loop(6) = {31, 7, 8, 23};
Plane Surface(6) = {6};
Curve Loop(7) = {16, 29, 19, 25};
Plane Surface(7) = {7};
Curve Loop(8) = {19, 30, 22, 26};
Plane Surface(8) = {8};
Curve Loop(9) = {27, 6, 31, 22};
Plane Surface(9) = {9};
Curve Loop(10) = {21, 27, 5, 4};
Plane Surface(10) = {10};
Curve Loop(11) = {18, 26, 21, 3};
Plane Surface(11) = {11};
Curve Loop(12) = {2, 15, 25, 18};
Plane Surface(12) = {12};
Transfinite Surface {1};
Transfinite Surface {2};
Transfinite Surface {3};
Transfinite Surface {4};
Transfinite Surface {7};
Transfinite Surface {12};
Transfinite Surface {11};
Transfinite Surface {8};
Transfinite Surface {5};
Transfinite Surface {6};
Transfinite Surface {9};
Transfinite Surface {10};
Physical Surface(“blocks”, 32) = {1, 2, 3, 10, 9, 6};
Physical Surface(“channel”, 33) = {12, 11, 7, 8, 4, 5};
Physical Curve(“inlet”, 34) = {2, 3};
Physical Curve(“outlet”, 35) = {10, 9};
Physical Curve(“surface”, 37) = {1, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4};
Recombine Surface {1, 2, 3, 4, 7, 12, 11, 10, 8, 9, 5, 6};
I would be very grateful if someone could help me resolve this.
Wu
