I am looking to apply a ST to the DEFORMATION process on a curved surface. I tried defining the surface using polylines (see Yellow surface) and using the $DISPLACEMENT_N keyword but that doesn’t work.
I then tried to segment my curved surface in multiple flat surfaces (see dotted red outline) and applying the ST to each… but I get odd results… I think the ST might be cumulatively added to some nodes.
I am aware that this particular problem can be solved using the axisymmetric solution, but I have another mesh where that does not work.
I would like to know if:
A) This is doable in OGS 5 and how to do it if it is.
B) If this is doable in OGS 6.
Thank you so much for your help.
