Thank you very much for your prompt response. I am fairly new to this stuff. But I don’t have enough time already. How can I find and remove them?
Here are the codes:
import gmsh
import sys
gmsh.initialize()
gmsh.model.add(“t3”)
out_dir = Path(os.environ.get(“OGS_TESTRUNNER_OUT_DIR”, “_out”))
if not out_dir.exists():
out_dir.mkdir(parents=True)
exe_dir = os.environ.get(“OGS_BINARY_DIR”)
mesh file name
bhe_mesh_file_name = “test3”
#geometry parameters
width = 1300
length = 1300
depth = 700
bhe_depth = 1100
#element sizes
bhe_radius = 0.07
alpha = 6.134 # see Diersch et al. 2011 Part 2
delta = alpha * bhe_radius # meshsize at BHE and distance of the surrounding optimal mesh points
elem_size_corner = 40
elem_size_BHE_relax = 2
#Creating Earth layers
gmsh.model.occ.addPoint(0.0, 0.0, 0.0, elem_size_corner, 1)
gmsh.model.occ.addPoint(1300, 0.0, 0.0, elem_size_corner, 2)
gmsh.model.occ.addPoint(1300, 1300, 0.0, elem_size_corner, 3)
gmsh.model.occ.addPoint(0.0, 1300, 0.0, elem_size_corner, 4)
gmsh.model.occ.addLine(1, 4, 1)
gmsh.model.occ.addLine(2, 1, 2)
gmsh.model.occ.addLine(4, 3, 3)
gmsh.model.occ.addLine(3, 2, 4)
gmsh.model.occ.synchronize()
gmsh.model.occ.addCurveLoop([1, 3, 4, 2], 1)
gmsh.model.occ.addPlaneSurface([-1], 1)
gmsh.model.occ.addPoint(650, 650, 0, delta, 5)
gmsh.model.occ.addPoint(650, 649.6, 0, delta, 6)
gmsh.model.occ.addPoint(650, 650.4, 0, delta, 7)
gmsh.model.occ.addPoint(650.3464, 650.2, 0, delta, 8)
gmsh.model.occ.addPoint(649.6536, 650.2, 0, delta, 9)
gmsh.model.occ.addPoint(650.3464, 649.8, 0, delta, 10)
gmsh.model.occ.addPoint(649.6536, 649.8, 0, delta, 11)
gmsh.model.mesh.embed(0,[5],2,1)
gmsh.model.mesh.embed(0,[6],2,1)
gmsh.model.mesh.embed(0,[7],2,1)
gmsh.model.mesh.embed(0,[8],2,1)
gmsh.model.mesh.embed(0,[9],2,1)
gmsh.model.mesh.embed(0,[10],2,1)
gmsh.model.mesh.embed(0,[11],2,1)
R1 = gmsh.model.occ.extrude([(2, 1)], 0, 0, -depth, [6], [1], True)
gmsh.model.addPhysicalGroup(3, [R1[1][1]], 1)
R2 = gmsh.model.occ.extrude([(2, 6)], 0, 0, -1300, [12], [1], True)
#Creating Salt Cavern
gmsh.model.occ.addPoint(650, 650, -1000, delta, 105)
gmsh.model.occ.addPoint(650, 649.6, -1000, delta, 106)
gmsh.model.occ.addPoint(650, 650.4, -1000, delta, 107)
gmsh.model.occ.addPoint(650.3464, 650.2, -1000, delta, 108)
gmsh.model.occ.addPoint(649.6536, 650.2, -1000, delta, 109)
gmsh.model.occ.addPoint(650.3464, 649.8, -1000, delta, 110)
gmsh.model.occ.addPoint(649.6536, 649.8, -1000, delta, 111)
gmsh.model.occ.addPoint(650, 650, -1000, delta, 112)
gmsh.model.occ.addPoint(650, 625, -1000, delta, 113)
gmsh.model.occ.addPoint(650, 675, -1000, delta, 114)
gmsh.model.occ.addPoint(625, 650, -1000, delta, 115)
gmsh.model.occ.addPoint(675, 650, -1000, delta, 116)
gmsh.model.occ.addCircleArc(113,105,116,106)
gmsh.model.occ.addCircleArc(116,105,114,107)
gmsh.model.occ.addCircleArc(114,105,115,108)
gmsh.model.occ.addCircleArc(115,105,113,109)
gmsh.model.occ.addCurveLoop([106, 107, 108, 109], 101)
gmsh.model.occ.addPlaneSurface([101], 101)
gmsh.model.mesh.embed(0,[105],2,101)
gmsh.model.mesh.embed(0,[106],2,101)
gmsh.model.mesh.embed(0,[107],2,101)
gmsh.model.mesh.embed(0,[108],2,101)
gmsh.model.mesh.embed(0,[109],2,101)
gmsh.model.mesh.embed(0,[110],2,101)
gmsh.model.mesh.embed(0,[111],2,101)
gmsh.model.mesh.embed(0,[112],2,101)
gmsh.model.mesh.embed(0,[113],2,101)
gmsh.model.mesh.embed(0,[114],2,101)
gmsh.model.mesh.embed(0,[115],2,101)
gmsh.model.mesh.embed(0,[116],2,101)
cyc1=gmsh.model.occ.extrude([(2,101)], 0, 0, -200, [12],[1],True)
gmsh.model.geo.synchronize()
#gmsh.model.removeEntities([(3,3)], recursive=False)
cavern,other = gmsh.model.occ.fragment([R2[1]], [cyc1[1]])
#gmsh.model.occ.cut([R2[1]], [cyc1[1]])
#cyc2=gmsh.model.occ.extrude([(2,101)], 0, 0, -200, [12],[1],True)
gmsh.model.addPhysicalGroup(3, [3], 3)
gmsh.model.addPhysicalGroup(3, [4], 4)
#Adding BHE to the model
bhe = gmsh.model.occ.extrude([(0, 5)], 0, 0, -bhe_depth, [110], [1], True)
gmsh.model.addPhysicalGroup(1, [bhe[1][1]], 501)
gmsh.model.addPhysicalGroup(2,[1], name=‘top’)
gmsh.model.addPhysicalGroup(2,[111], name=‘bottom’)
gmsh.option.setNumber(“Mesh.MshFileVersion”, 2.2)
gmsh.model.mesh.generate(3)
if “CI” not in os.environ:
gmsh.fltk.run()
gmsh.finalize()
