Dear OGS Developer
I discovered a big bug by setting the boundary conditions. An example is on the Web SVN in the folder:
/branches/BGR/3d2d_surfaces
When you check the boundary condition output, there are no conditions on the surfaces OUT.
Who has changed the function to set the boundary condition? The version 5.10 works correct.
best regards
Herbert
Hi Herbert,
can you be a little bit more specific where in the code you think the
bug is located?
had) a general problem in the geometry routines. In general things seem
to work, but there are some dependencies on how you define the surfaces.
Can you check, if the OUT surface is found? (should be some indication
in the screen output)
For certain of my current 2D/3D examples I had to add the $EPS keyword
to the surface definitions in the GLI file. I found that I need a well
defined epsilon, as otherwise the surfaces were not found.
Greetings. Georg
From my experience with applying/defining surfaces the code has (and
On 12/12/2013 09:08 AM, Herbert Kunz wrote:
Dear OGS Developer
best regards
Herbert
Groups "ogs-devs" group.
an email to ogs-devs+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
Phone: +41-56-3104743 * Fax: +41-56-3102821
Email: georg.kosakowski@psi.ch h323:+41563104743
homepage: http://people.web.psi.ch/kosakowski/
Dear Georg
I have tried the $Epsilon Keyword. This doesn't solve the problem.
I don' t developed the OGS code so I can't specified where in the code the bug is.
There must be a big change after the version 5.10. This, and older versions works properly.
I'm using the Keyword $BOUNDARY_CONDITION_OUTPUT in the PCS File.
With GINA you can check the Boundary Conditions on the Screen.
Herbert
-----Ursprüngliche Nachricht-----
Von: ogs-devs@googlegroups.com [mailto:ogs-devs@googlegroups.com] Im Auftrag von Georg Kosakowski
Gesendet: Donnerstag, 12. Dezember 2013 10:03
An: ogs-devs@googlegroups.com
Betreff: Re: Big Bug by Boundary Condition on Surfaces
Hi Herbert,
can you be a little bit more specific where in the code you think the bug is located?
had) a general problem in the geometry routines. In general things seem to work, but there are some dependencies on how you define the surfaces.
Can you check, if the OUT surface is found? (should be some indication in the screen output) For certain of my current 2D/3D examples I had to add the $EPS keyword to the surface definitions in the GLI file. I found that I need a well defined epsilon, as otherwise the surfaces were not found.
Greetings. Georg
Dear OGS Developer
best regards
Herbert
PD Dr. Georg Kosakowski * Laboratory for Waste Management Paul Scherrer Institut * 5232 Villigen/PSI * Switzerland
You received this message because you are subscribed to the Google Groups "ogs-devs" group.
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-devs+unsubscribe@googlegroups.com.
Dear Herbert,
thank you for providing test data. Which versions did you check after 5.10? Which of them worked?
I took a look into your gli file. There is no surface called OUT. You defined OUT_i, i = 1, ..., 16.
For those surfaces only the nodes at the top and the bottom of the given mesh are found with OGS-5.5.
I am investigating this problem further and inform you if I have found the reason for this.
tom
On 12/12/2013 10:03 AM, Georg Kosakowski wrote:
Hi Herbert,
bug is located?
Greetings. Georg
Dear OGS Developer
best regards
Herbert
Dr. Thomas Fischer
Permoserstra�e 15 / 04318 Leipzig / Germany
Tel.: +49 341 235 - 1054 / Fax: +49 341 235 - 1939
thomas.fischer@ufz.de / http://www.ufz.de
Helmholtz-Zentrum f�r Umweltforschung GmbH - UFZ
Wissenschaftlicher Gesch�ftsf�hrer: Prof. Dr. Georg Teutsch
Administrative Gesch�ftsf�hrerin: Dr. Heike Gra�mann
Dear Tom
That's right. All the surfaces with the name OUT (OUT_1 and so on).
I have not all versions after 5.10. I tried different, but there are the same (wrong) result.
Thanks for your help.
Herbert
Von: ogs-devs@googlegroups.com [mailto:ogs-devs@googlegroups.com] Im Auftrag von Thomas Fischer
Gesendet: Donnerstag, 12. Dezember 2013 10:43
Hi Herbert,
bug is located?
were not found.
Greetings. Georg
Dear OGS Developer
best regards
Herbert
Dear Herbert,
tom
Dr. Thomas Fischer
Helmholtz Centre for Environmental Research GmbH - UFZ Permoserstraße 15 / 04318 Leipzig / Germany
Tel.: +49 341 235 - 1054 / Fax: +49 341 235 - 1939 thomas.fischer@ufz.de / http://www.ufz.de
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ Sitz der Gesellschaft: Leipzig
Registergericht: Amtsgericht Leipzig, Handelsregister Nr. B 4703 Vorsitzender des Aufsichtsrats: MinDirig Wilfried Kraus Wissenschaftlicher Geschäftsführer: Prof. Dr. Georg Teutsch Administrative Geschäftsführerin: Dr. Heike Graßmann
Dear Herbert,
to limit the effort to find the reason, can you provide the version number of the first version that did not work.
tom
On 12/12/2013 10:45 AM, Kunz, Herbert wrote:
Dear Tom
Herbert
Dr. Thomas Fischer
As far as I tested, it doesn't work since v5.2.03.
best,
nori
Dear Tom
Herbert
Dear Herbert,
tom
Dr.-Ing. Norihiro Watanabe
Wissenschaftler
Telefon +49 341 235 1806
Administrativer Gesch�ftsf�hrer: Dr. Heike Gra�mann
Hoi Nori,
only to make sure that I am not the bad guy
You mean that 5.2.02 works and 5.2.03 does not work, correct?
If 5.2.03 works and 5.2.04 does not work ...I will have to look what I
did wrong...
Greetings, Georg
best,
nori
Dear Tom
Herbert
Dear Herbert,
tom
Hi Georg,
nobody is a bad guy, at least in ogs developers
yes, 5.2.02 works and 5.2.03 does not work, though I didn't check 5.2.04.
best,
Nori
On 12/13/2013 10:32 AM, Georg Kosakowski wrote:
Hoi Nori,
did wrong...
Greetings, Georg
best,
nori
Dear Tom
Herbert
Dear Herbert,
tom
Wissenschaftler
Hoi,
I am relieved that there are no bad guys here!
From what I see, there are multiple changes from 5.2.02 to 5.2.03 which
makes identification of the problem not easier....
Only a stupid question: who is working/responsible for solving the
issue? Is there a procedure implemented for assigning such things to
someone?
There is a ticket system in the wiki, but this seems a bit "out of use".
Greetings, Georg
On 12/13/2013 10:36 AM, Norihiro Watanabe wrote:
Hi Georg,
best,
Nori
Hoi Nori,
did wrong...
Greetings, Georg
best,
nori
Dear Tom
Herbert
Dear Herbert,
tom
Tom is the best person who can solve the issue, as he implemented that part. I'll ask him
The ticket system in the wiki is not used anymore (and never really used). Officially (in leipzig group), bug reports are supposed to be submitted to
http://www.opengeosys.org/forum/
No we don't really have a procedure for solving reported bugs yet.
best,
nori
On 12/13/2013 10:45 AM, Georg Kosakowski wrote:
Hoi,
someone?
Greetings, Georg
Hi Georg,
best,
Nori
Hoi Nori,
did wrong...
Greetings, Georg
best,
nori
Dear Tom
Herbert
Dear Herbert,
tom
Wissenschaftler
I take care of the problem. I can not promise to solve it today.
Best regards
tom
Dr. Thomas Fischer
I uploaded changes in Triangle::containsPoint() method to the trunk. The benchmarks are all fine. Hope this fixes some problems. If not, please sen me test cases!
tom
Dr. Thomas Fischer
It would be nice if Herbert's problem (or simplified one if it's too big) is added into benchmark to ensure the same issue will not occur again in the future.
best,
nori
On 12/16/2013 08:59 AM, Thomas Fischer wrote:
sen me test cases!
tom
Wissenschaftler
