When I try to run the benchmark (calcite.prj), I am getting an error shown in figure below.
emre@emre-VirtualBox:~/Desktop/OGS1/EquilibriumPhase$ ~/Desktop/OGS1/build-release/bin/ogs -l debug calcite.prj
Am I missing something?
info: This is OpenGeoSys-6 version 6.3.3-573-g4e0cd0af9.
info: OGS started on 2021-03-11 11:59:19+0300.
debug: Project configuration from file ‘calcite.prj’ read.
debug: Reading multiple meshes.
debug: Reading mesh file ‘calcite.vtu’.
debug: Reading mesh file ‘calcite_upstream.vtu’.
debug: Reading mesh file ‘calcite_downstream.vtu’.
debug: Reading mesh file ‘calcite_ReactiveDomain.vtu’.
debug: Reading parameters:
info: ConstantParameter: kappa
debug: Using following values for the constant parameter:
debug: 1.157e-12
info: ConstantParameter: porosity
debug: Using value 0.32 for constant parameter.
info: ConstantParameter: decay
debug: Using value 0 for constant parameter.
info: ConstantParameter: p0
debug: Using value 1 for constant parameter.
info: ConstantParameter: p_upstream
debug: Using value 100000 for constant parameter.
info: ConstantParameter: p_downstream_Neumann
debug: Using value -0.00299769 for constant parameter.
info: ConstantParameter: c0_C(4)
debug: Using value 0.000123 for constant parameter.
info: ConstantParameter: c0_Ca
info: ConstantParameter: c0_Mg
debug: Using value 1e-12 for constant parameter.
info: ConstantParameter: c0_Cl
info: ConstantParameter: c0_H
debug: Using value 1.23027e-10 for constant parameter.
info: ConstantParameter: c_C(4)
debug: Using value 1e-10 for constant parameter.
info: ConstantParameter: c_Ca
info: ConstantParameter: c_Mg
debug: Using value 0.001 for constant parameter.
info: ConstantParameter: c_Cl
debug: Using value 0.002 for constant parameter.
info: ConstantParameter: c_H
debug: Using value 1e-07 for constant parameter.
debug: Parse process variables:
debug: Found parameter p0'. debug: Constructing process variable pressure debug: Found mesh 'calcite_upstream' with id 1. debug: Found mesh 'calcite_downstream' with id 2. info: No source terms for process variable 'pressure' found. debug: Found parameter c0_C(4)‘.
debug: Constructing process variable C(4)
debug: Found mesh ‘calcite_upstream’ with id 1.
info: No source terms for process variable ‘C(4)’ found.
debug: Found parameter c0_Ca'. debug: Constructing process variable Ca debug: Found mesh 'calcite_upstream' with id 1. info: No source terms for process variable 'Ca' found. debug: Found parameter c0_Mg’.
debug: Constructing process variable Mg
info: No source terms for process variable ‘Mg’ found.
debug: Found parameter c0_Cl'. debug: Constructing process variable Cl debug: Found mesh 'calcite_upstream' with id 1. info: No source terms for process variable 'Cl' found. debug: Found parameter c0_H’.
debug: Constructing process variable H
info: No source terms for process variable ‘H’ found.
debug: Reading media:
debug: Create Constant property pore_diffusion.
critical: /home/emre/Desktop/OGS1/ogs/MaterialLib/MPL/PropertyType.h:319 convertStringToProperty()
warning: Property is not used: ‘property ‘pore_diffusion’ defined for medium’
error: The property name ‘pore_diffusion’ does not correspond to any known property
info: OGS terminated on 2021-03-11 11:59:19+0300.
