convertGEO tool
Hi All,
I want to convert *.gli file to *.geo file using convertGEO tool and command is as follows
convertGEO.exe -o L-Q.geo -i L-Q.gli
However, I found error message "Writing of geometry failed. Since it was not possible to determine the required format from extension". Any idea about the error source? For curiosity, I also used *.gml file. I attached *.gli & *.gml files.
Thanks in advance.
L-Q.gli (724 Bytes)
L-Q.gml (954 Bytes)
What are *.geo files? convertGEO supports only *.gli and *.gml to convert OGS5 files to OGS6.
best,
nori
On 06/10/2017 04:40 AM, Mohammad Islam wrote:
Hi All,
However, I found error message "/Writing of geometry failed. Since it was not possible to determine the required format from extension"/. Any idea about the error source? For curiosity, I also used *.gml file. I attached *.gli & *.gml files.
Thanks in advance.
Dear Nori,
Now it is clear. I thought convertGEO is to convert *.gli or *.gml file to Gmsh file extension *.geo !
On Sunday, 11 June 2017 17:04:07 UTC-4, Norihiro Watanabe wrote:
best,
nori
Hi All,
However, I found error message “/Writing of geometry failed. Since it
was not possible to determine the required format from extension”/. Any
Thanks in advance.
Groups “ogs-users” group.
mailto:[email protected].
To create a GMSH geo file from *.gli, you can use GINA. The program has the exporting function. I guess OGS6 DataExplorer can also do it but from *.gml file.
n
On 06/12/2017 11:50 PM, Mohammad Islam wrote:
Dear Nori,
Now it is clear. I thought convertGEO is to convert *.gli or *.gml file to *Gmsh* <http://gmsh.info/&gt;file extension *.geo !
    best,
    nori
     > Hi All,
     > I want to convert *.gli file to *.geo file using convertGEO tool and
     > command is as follows
     > convertGEO.exe -o L-Q.geo -i L-Q.gli
     > However, I found error message "/Writing of geometry failed.
    Since it
     > was not possible to determine the required format from
    extension"/. Any
     > idea about the error source? For curiosity, I also used *.gml
    file. I
     > attached *.gli & *.gml files.
     > Thanks in advance.
     > Regards,
     > Mohammad
     > You received this message because you are subscribed to the Google
     > Groups "ogs-users" group.
     > To unsubscribe from this group and stop receiving emails from it,
    send
     > an email to ogs-users+...@googlegroups.com <javascript:>
     > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
     > For more options, visit https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;\.
Dear Nori,
I will check GINA. OGS6 DataExplorer can also convert *.gli to *.geo. File>Open>Right Bottom (GeoSys legacy files)>>Tools>> Create Mesh From Input Data>>> Advanced (UnTick Delete GMSH geo-file after generating mesh) .
