Hello Guillaume,
HK1.ic (137 Bytes)
HK1.MFP (171 Bytes)
HK1.mmp (1.31 KB)
HK1.msh (1.39 KB)
HK1.num (149 Bytes)
HK1.out (123 Bytes)
HK1.pcs (105 Bytes)
HK1.tim (96 Bytes)
HK1_msp.txt (587 Bytes)
HK1.bc (268 Bytes)
HK1.gli (252 Bytes)
attached you find your input files. I found following errors in your model:
*.mmp - error with $HEAT_DISPERSION input
*.gli - better add all points to your POLYLINE
*.st - you don't need a source term if you have a constant temperature at domain bottom (if I understood your setup right)
*.out - you can use $ GEO_TYPE DOMAIN if you want to output your variables for all nodes
Hope this helps.
Best
Aaron
PS: Please change the file ending of *.msp before running.
Am 3/22/2018 um 12:11 PM schrieb Guillaume Doudou FAYE:
And here is the.MSP file:
; layer 0
#SOLID_PROPERTIES
$DENSITY
1 2620
$THERMAL
CAPACITY
1 815
CONDUCTIVITY
1 1.97
; layer 1
#SOLID_PROPERTIES
$DENSITY
1 1680
$THERMAL
CAPACITY
1 795
CONDUCTIVITY
1 0.83
; layer 2
#SOLID_PROPERTIES
$DENSITY
1 2240
$THERMAL
CAPACITY
1 810
CONDUCTIVITY
1 1.23
; layer 3
#SOLID_PROPERTIES
$DENSITY
1 1940
$THERMAL
CAPACITY
1 810
CONDUCTIVITY
1 1.30
; layer 4
#SOLID_PROPERTIES
$DENSITY
1 2160
$THERMAL
CAPACITY
1 810
CONDUCTIVITY
1 1.47
; layer 5
#SOLID_PROPERTIES
$DENSITY
1 2640
$THERMAL
CAPACITY
1 775
CONDUCTIVITY
1 3.23
You received this message because you are subscribed to the Google Groups "ogs-users" group. To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com. For more options, visit [https://groups.google.com/d/optout](https://groups.google.com/d/optout).
Aaron Peche (M.Sc.) PhD Student Institute of Fluid Mechanics and Environmental Physics Leibniz-Universität Hannover ------------------------------------------------------ Address: Appelstraße 9a 30167 Hannover, Germany Room Nr: 103 Tel.: +49 511.762 - 3711 E-Mail: ------------------------------------------------------
