Density and Gravity Force
Hi All,
To neglect gravity effect, materials and liquid densities are considered as zero. I found some cases, where density is considered as -ve/ +ve value. What does negative sign represent? There are total three files where GRAVITY key word is available
For *. mfp GRAVITY
*.msp GRAVITY_CONSTANT
*.num GRAVITY_PROFILE
I am wondering what is the appropriate way to consider Gravity force effect. I followed following steps, but failed. Any idea how can I achieve gravity force effect?
GeoSys-MAT-FP: Fluid Properties ------------------------------------
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.0e3
$GRAVITY
9.81
$VISCOSITY
1 1.000000e-003
GeoSys-MAT-SP: Solid Properties ------------------------------------
#SOLID_PROPERTIES
$DENSITY
1 2.000000e+003
$GRAVITY_CONSTANT
9.81
$ELASTICITY
POISSION 0.4
YOUNGS_MODULUS
1 1.300000e+006
GeoSys-NUM: Numerical Parameter ----------------------------------------
#NUMERICS
RICHARDS_FLOW
$ELE_UPWINDING
0.5
$ELE_MASS_LUMPING
1
$GRAVITY_PROFILE
1
$LINEAR_SOLVER
; method error_tolerance max_iterations theta precond storage
2 2 1.e-010 2000 1.0 100 4
$NON_LINEAR_SOLVER
; method error_tolerance max_iterations relaxation
PICARD 1e-3 25 0.0
; $COUPLING_ITERATIONS
; HM 5 1.0e-6 // The first string is arbitrary
#NUMERICS
DEFORMATION
$LINEAR_SOLVER
2 5 1.e-10 1000 1.0 100 4
$ELE_GAUSS_POINTS
3
hi, usually you don’t need to use any of the GRAVITY keywords. To neglect gravity effects, you can use negative sign for the densities. The densitiy values (absolute one) will still be used in some calculation, e.g. in heat transport. but don’t ask me why it’s like that…
Sent: 水曜日, 6月 7, 2017 2:46 午前
Subject: [ogs-users] Density and Gravity Force
To: ogs-users [email protected]
Hi All,
For *. mfp GRAVITY
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.0e3
$GRAVITY
9.81
$VISCOSITY
1 1.000000e-003
#SOLID_PROPERTIES
$DENSITY
1 2.000000e+003
$GRAVITY_CONSTANT
9.81
$ELASTICITY
POISSION  0.4
YOUNGS_MODULUS
 1 1.300000e+006
#NUMERICS
RICHARDS_FLOW
$ELE_UPWINDING
0.5
$ELE_MASS_LUMPING
1
$GRAVITY_PROFILE
1
$LINEAR_SOLVER
$NON_LINEAR_SOLVER
PICARD 1e-3 25 0.0
#NUMERICS
DEFORMATION
$LINEAR_SOLVER
$ELE_GAUSS_POINTS
3
To unsubscribe from this group and stop receiving emails from it, send an email [email protected].
If negative density value is given in msp file, the gravity force effect in deformation analysis is neglected, while absolute value of the solid density data is still used in calculation of the heat capacity related term when heat transport process being coupled. For fluid density values in mfp, they have to be always positive.
On 06/07/2017 01:31 AM, 渡邉教弘 wrote:
hi, usually you don't need to use any of the GRAVITY keywords. To neglect gravity effects, you can use negative sign for the densities. The densitiy values (absolute one) will still be used in some calculation, e.g. in heat transport. but don't ask me why it's like that...
_____________________________
To: ogs-users <[email protected]>
Hi All,
For *. mfp GRAVITY
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.0e3
$GRAVITY
9.81
$VISCOSITY
1 1.000000e-003
#SOLID_PROPERTIES
  $DENSITY
    1 2.000000e+003
  $GRAVITY_CONSTANT
  9.81
  $ELASTICITY
    POISSION 0.4
    YOUNGS_MODULUS
     1 1.300000e+006
#NUMERICS
RICHARDS_FLOW
$ELE_UPWINDING
0.5
$ELE_MASS_LUMPING
1
$GRAVITY_PROFILE
1
$LINEAR_SOLVER
$NON_LINEAR_SOLVER
PICARD 1e-3 25 0.0
#NUMERICS
DEFORMATION
$LINEAR_SOLVER
$ELE_GAUSS_POINTS
3
To unsubscribe from this group and stop receiving emails from it, send an email [email protected] <mailto:[email protected]>.
Thank you for your kind reply.
Hi All,
For *. mfp GRAVITY
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
PRESSURE1
$DENSITY
1 1.0e3
$GRAVITY
9.81
$VISCOSITY
1 1.000000e-003
#SOLID_PROPERTIES
$DENSITY
1 2.000000e+003
$GRAVITY_CONSTANT
9.81
$ELASTICITY
POISSION  0.4
YOUNGS_MODULUS
 1 1.300000e+006
#NUMERICS
RICHARDS_FLOW
$ELE_UPWINDING
0.5
$ELE_MASS_LUMPING
1
$GRAVITY_PROFILE
1
$LINEAR_SOLVER
$NON_LINEAR_SOLVER
PICARD 1e-3 25 0.0
#NUMERICS
DEFORMATION
$LINEAR_SOLVER
$ELE_GAUSS_POINTS
3
Dear Wang,
Thanks again for your help.
This conversation is a bit hilarious but very useful in a random way. Thanks, guys. It helps eventually.
Chan-Hee
On Saturday, June 10, 2017 at 2:57:17 AM UTC+9, Mohammad Islam wrote:
Dear Wang,
