density changes (for density driven flow processes)
who is working on density driven flow processes, especially Richards_flow or liquid, groundwater flow and knows/understands where Density is called for these processes?
I would like to pass fluid densities from my chemical solver GEMS to the corresponding routines and wonder how to do this in an efficient way.
You may contact me directly via email ([email protected]).
Thanks and greetings, Georg
If think you need density model 3.
If you take the Boussinesq approximation, you have to pass the concentration in the function
void CFiniteElementStd::Assemble_Gravity()
You have to specify dens_arg[2] = concentration and call Density(dens_arg)
(maybe it calls Density() in your version, then you have to include the densarg).
The *.mfp input looks like:
#FLUID_PROPERTIES
$FLUID_TYPE
LIQUID
$DENSITY
3 1e+3 0 0.03
$VISCOSITY
1 1e-3
Better ask Ashok to confirm of this, because he is more familiar with this stuff than I am
2012/6/21 Georg Kosakowski [email protected]
Hi Georg,
If the density is calculated at points and it is not needed to be
calculated again in the local assembly, I suggest to do as follows
for each global assembly:
calculate the density for each element at the centroid of the
element
save all values of element in a vector.
make CFluidProperties::Density(double* variables) return the density
value for an element from the vector.
Wenqing
On 21.06.2012 16:17, jens-olaf Delfs wrote:
Density(dens_arg)
  #FLUID_PROPERTIES
   $FLUID_TYPE
    LIQUID
   $DENSITY
    3 1e+3 0 0.03
   $VISCOSITY
    1 1e-3
      Hi
all,
Gruetzi Wenqing,
thanks for the hint. I guess that is the way to go!
Greetings, Georg
Am Donnerstag, 21. Juni 2012 18:05:15 UTC+2 schrieb Wenqing Wang:
      Hi
all,
Density(dens_arg)
  #FLUID_PROPERTIES
   $FLUID_TYPE
    LIQUID
   $DENSITY
    3 1e+3 0 0.03
   $VISCOSITY
    1 1e-3
Hi Georg,
element
make CFluidProperties::Density(    double* variables) return the density
Wenqing
