Density driven flow caused by heat source in porous media
Ladies and gentelemen,
I started working with OGS to compare it to other platforms solving heat transport coupled with richards flow.
In fluid properties I can define a line where the density is dependant of the temperature.
I did a bit research and found this page Inputfile .mfp density as fard as I understood 4. gives a relation between density and temperature. But I need to know how exactly OGS is calculating the density. The formula given at point 4. and the values lower on the page are rather confusing.
Density approximations are dependant of temperature ranges. And I can’t see something that is modelling something like that here.
A co-worker said he is using this equation:
$DENSITY
4 1.000000e+003 0 0.2 ; C0 is 0. beta_C (drho_dC) is 0.2
but this looks for me on the first sight more like a concentration related behaviour, also on the website it is described like that.
In addition viscosity should change too with temperature.
I’m new to OGS and I have to say I didnt find a lot about this stuff in the web.
MB
Hi Marius,
density model 4 is a linear density model, e.g.
  $DENSITY
   4 999.7 283.15 -2.5e-4
Parameters are rho(T_ref), T_ref, droh/dT. There are many other density models implemented, some of them are also taking into account concentration and/or pressure changes by such linearization.
You can also provide your own non-linear density model by ascii text input ("model 0"):
  $DENSITY
   0 1
Parameter "1" refers to the first data table in a *.rfd ascii input file, which you will have to provide in this case:
;Curve 1 Temp Density
#CURVES
273.15 999.8675792
274.15 999.9265054
For T dependent viscosity, you can also provide a data file using the same syntax as for density, or you can use the empirical Yaws (model 3) or deMarsily (model 4) models
  $VISCOSITY
   3 ; Yaws
   ;4 ; DeMarsily
where the parameters are hardcoded in OGS. There are other model, which also take into account pressure and/or concentrations
Btw, you should define temperature in Kelvin.
Best, Christof
Am 11.11.2015 um 20:56 schrieb Mar. Bitt.:
of the temperature.
<https://svn.ufz.de/ogs/wiki/public/doc-auto/by_ext/mfp/S_density&gt; as
Density approximations are dependant of temperature ranges. And I can't
    $DENSITY
      4 1.000000e+00300.2; C0 is 0. beta_C (drho_dC) is 0.2
I'm new to OGS and I have to say I didnt find a lot about this stuff in
the web.
MB
Groups "ogs-users" group.
an email to [email protected]
<mailto:[email protected]>.
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
i added density and viscosity models into the cheat sheet https://github.com/drjod/ogs_kb1/blob/master/README.md, since we often need that
2015-11-11 21:39 GMT+01:00 Christof Beyer [email protected]:
Hi Marius,
$DENSITY
You can also provide your own non-linear density model by ascii text input (“model 0”):
$DENSITY
0 1
Parameter “1” refers to the first data table in a *.rfd ascii input file, which you will have to provide in this case:
#CURVES
273.15 999.8675792
274.15 999.9265054
$VISCOSITY
3 ; Yaws
;4 ; DeMarsily
Best, Christof
of the temperature.
<https://svn.ufz.de/ogs/wiki/public/doc-auto/by_ext/mfp/S_density> as
$DENSITY
the web.
MB
Groups “ogs-users” group.
mailto:[email protected].
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Good evening ladies and gentlemen,
thank you for the answer cb! :slight_smile:
I took into account what you said and investigated more about this.
I still does not understand how this linear approach is looking. From the input parameters maybe something like this is logical:
(The second formula shows the equation with the parameters that I gave to OGS in my example)
but this really would be only a rough approach. In addition this forumla only works with °C.
When it is really the case that the density is calculated like the formula that is given above I calculated my own values and put them as a #CURVE in a *.rfd file.
I worte a programm to write me a nice approach from 0°C-250°C or when needed 273.15°K-523.15°K. All my files were depending on °C and I dont get any nice results on the contrary at a certain time step the programm stops and windows tells me it stopped running properly also I get really high temperature results and I dont know from what they occur.
My #CURVES file looks like this:
link to .rfd file
I tried both: °K and °C but the same error occurs. I thought that maybe 273,15°K or (0°C) as initial value may be insufficient? Or is the accuracy not high enough?
Thank you for helping. All may have a nice weekend.
MB
(sorry for deleting my post three times, the link expired)
Am Mittwoch, 11. November 2015 20:56:15 UTC+1 schrieb Marius:
$DENSITY
MB
I’m sorry somehow the link expires all the time.Hopefully this one works:
LINK TO *.rfd file
In addition I have another question. Is it possible to do exactly this for a temperature dependant viscosity?
$DENSITY
MB
Dear Marius,
I have to admit that I did not follow all replies concerning your question. If I understand it correctly you want to get the correct density for a given temperature using curves in the *.rfd file but your simulation crashes. I had a quick glance at your file and you are using comma as the decimal mark. You should switch that to periods:
#CURVES
273.15 999.8732768
273.151 999.8733405
Give it a try and see if that helps.
Concerning your question regarding temperature dependent viscosity: I think yes, but i have not checked it. The integer flag for reading data from a curve is always 0. So you could set your viscosity in addition to your density like this:
$VISCOSITY
0 2
In this case the second curve in the *.rfd file should contain the viscosity data.
All the best, Tilmann
LINK TO *.rfd file
https://drive.google.com/file/d/0B_S15Ubp4R77VzNvbTZVY1hsdEU/view?usp=sharing
can't see something that is modelling something like that here.
    $DENSITY
stuff in the web.
MB
Hey,
I just realized that maybe I should show you the syntax you should follow if you have multiple curves in the *.rfd file. Do not put a #STOP between the curves. The #STOP goes wherever you want ogs to stop reading the file. Everything behind it will not be used in any way. If you have multiple curves just separate them by a blank line followed by the second #CURVES keyword:
; Curve 1: kr_w(S) for mat group 1
#CURVES
0.6 0
0.9 0.00154
; Curve 2: kr_w(S) for mat group 2
#CURVES
0.3 0
Wolf Tilmann Pfeiffer schrieb:
Dear Marius,
your simulation
#CURVES
273.15 999.8732768
273.151 999.8733405
$VISCOSITY
0 2
viscosity data.
LINK TO *.rfd file
for a
https://svn.ufz.de/ogs/wiki/public/doc-auto/by_ext/mfp/S_density as
$DENSITY
stuff in the web.
MB
om
Even after changing the sings from comma as decimal sign to a point the results were not satisfactory. Howsoever I decided to take the linear (since the temperature differences are really small) approach that hopefully works as I understood it.
For temperature dependant viscosity I chosed the number 4 it is a approach by Marsily. (1987)
Now I just still have the problem, that the temperatures in my domain remain pretty low.
This case can be seen as closed.
Thanks everyone for the replies.
I wish a good start in the new year whoever might read this.
Greetings,
MB
$DENSITY
MB
