direct assignment of source terms to nodes
is there a source term method implemented in OGS to assign a specific flux of a flow pcs to a list of nodes?
As far as I understand, $DIS_TYPE DIRECT will assign a CONSTANT volume flux (i.e. m³/s) to all nodes listed in a text file, but I want to assing the flux in m³/s per m² of patch area for each node, i.e. a combination o DIRECT and CONSTANT_NEUMANN.
Cheers, Christof
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
home: www.uni-kiel.de/ghm
Hey Christoph,
I don't know, if I clearly understood you, but you can use the keyword
"$DISTRIBUTE_VOLUME_FLUX" to give a volume per time on a line or
surface, which will then distribute this flux over the element. If you
have your list of nodes as individual source terms, this might work.
Marc
On Thu, 2016-12-08 at 16:09 +0100, cb wrote:
Cheers, Christof
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Marc Walther
Hydrologist
JProf. Dr. rer. nat.
Permoserstraße 15, 04318 Leipzig, Germany
Technische Universität Dresden
Faculty of Environmental Sciences
Department of Hydrosciences
Institute for Groundwater Management
Professorship for Contaminant Hydrology
01062 Dresden
Visiting Address UFZ
Building 7.2, Room E110
Visiting Address TUD
Bergstr. 66, 01069 Dresden
Neubau Chemie 2. Bauabschnitt, CHE-BA2, Room P204
Phone +49 341 235 10 54
Fax +49 341 235 19 39
Mobile +49 178 334 18 19
Email [email protected]
Web http://www.ufz.de
Personal UFZ Seite nicht verfügbar / page not available
Personal TUD https://tu-dresden.de/bu/umwelt/hydro/igw/das-institut/mitarbeiterinformationen/marc-walther
ResGate http://www.researchgate.net/profile/Marc_Walther
Registered Office: Leipzig
Registration Office: Amtsgericht Leipzig
Trade Register Nr. B 4703
Chairman of the Supervisory Board: MinDirig Wilfried Kraus
Scientific Director: Prof. Dr. Dr. h.c. Georg Teutsch
Administrative Director: Prof. Dr. Heike Graßmann
Dear Christof,
There is no direct method for this kind of BC input. Maybe you can mesh the area first, then write a short script (or c++ code) to convert the 2D elements of mesh into surfaces of gli and to assign the Neumann BC to these surfaces.
Wenqing
On 12/08/2016 04:09 PM, cb wrote:
Cheers, Christof
I think the workflow [0] could be a good starting point. Maybe the last step of the workflow needs some modification/additional work.
For the converting of the surface mesh to an geometry it is possible to use the DataExplorer.
Tom
[0] https://docs.opengeosys.org/docs/tools/model-preparation/computesurfacenodeidsinpolygonalregion
these surfaces.
Dr. Thomas Fischer
Scientific Director: Prof. Dr. Georg Teutsch
Administrative Director: Dr. Heike Graßmann
Hi Thomas, Wenqing and Marc,
thanks for your suggestions. This looks like a pretty nice way to assign BCs or STs.
One more question: I guess the ExtractSurface tool will extract outer surfaces of a mesh. In case a ST has to be assigned to a surface *within* the 3D mesh (e.g. a fracture or similar) it would then be necessary to cut away the surrounding elements before surface extraction. In Gina, this can be achieved using the "delete by matgroup" tool. I just found the "Remove Mesh Elements" method description, this obviously does the job...
Best regards, Christof
Am 12.12.2016 um 06:46 schrieb Thomas Fischer:
these surfaces.
Tom
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
