Hello everyone,
I’m new to ogs and I have installed the ogs from source following the guides from here. When I ran the basin example following the video tutorials, I met the error shown below
leo@leo-MS-7C37:~/Documents/ogs-6.4.2/example$ /home/leo/Documents/ogs-6.4.2/build/bin/ogs -l debug OGSinput_basin.prj
info: This is OpenGeoSys-6 version NO_VERSION.
info: OGS started on 2022-11-17 21:18:09+0800.
[0] debug: Project configuration from file 'OGSinput_basin.prj' read.
[0] debug: Reading multiple meshes.
[0] debug: Reading mesh file 'mesh_basin_domain.vtu'.
[0] debug: Reading mesh file 'mesh_basin_physical_group_Left.vtu'.
[0] debug: Reading mesh file 'mesh_basin_physical_group_Right.vtu'.
[0] debug: Reading mesh file 'mesh_basin_physical_group_Bottom.vtu'.
[0] debug: Reading mesh file 'mesh_basin_physical_group_Top.vtu'.
[0] debug: Binding Python module OpenGeoSys.
[0] error: AttributeError: module 'sys' has no attribute 'argv'
At:
/usr/lib/python3/dist-packages/gi/overrides/Gdk.py(450): <module>
<frozen importlib._bootstrap>(219): _call_with_frames_removed
<frozen importlib._bootstrap_external>(678): exec_module
<frozen importlib._bootstrap>(665): _load_unlocked
<frozen importlib._bootstrap>(955): _find_and_load_unlocked
<frozen importlib._bootstrap>(971): _find_and_load
<frozen importlib._bootstrap>(994): _gcd_import
/usr/lib/python3.6/importlib/__init__.py(126): import_module
/usr/lib/python3/dist-packages/gi/overrides/__init__.py(131): load_overrides
/usr/lib/python3/dist-packages/gi/importer.py(146): load_module
<frozen importlib._bootstrap>(626): _load_backward_compatible
<frozen importlib._bootstrap>(656): _load_unlocked
<frozen importlib._bootstrap>(1031): _handle_fromlist
/home/leo/.local/lib/python3.6/site-packages/matplotlib/backends/backend_gtk3.py(30): <module>
/home/leo/.local/lib/python3.6/site-packages/matplotlib/backends/backend_gtk3agg.py(8): <module>
/home/leo/.local/lib/python3.6/site-packages/matplotlib/pyplot.py(277): backend_mod
/home/leo/.local/lib/python3.6/site-packages/matplotlib/pyplot.py(276): switch_backend
/home/leo/.local/lib/python3.6/site-packages/matplotlib/pyplot.py(258): switch_backend
/home/leo/.local/lib/python3.6/site-packages/matplotlib/__init__.py(703): __getitem__
/home/leo/.local/lib/python3.6/site-packages/matplotlib/pyplot.py(2336): <module>
./glacierclass.py(5): <module>
timeBCs_glacier.py(2): <module>
[0] info: OGS terminated on 2022-11-17 21:18:10+0800.
[0] error: OGS terminated with error.
What should I do to solve this problem? Any kind of help is apprciated!
