I am reading through the documentation of the 2015_Book_Thermo-Hydro-Mechanical-Chemic and unable to work through the sample model in chapter 2.7.4 with the files under the menu Tests\Data\HydroMechanics\Verification\hm1_3Dgravity. I am using OGS version 6.2.1 and the files in the folder updated in 2019.
The feedback from the command window looks like this:
info: This is OpenGeoSys-6 version 6.2.1.
info: OGS started on 2020-03-10 22:50:00-0400.
warning: Consider switching from mesh and geometry input to multiple meshes input. See https://www.opengeosys.org/docs/tools/model-preparation/constructmeshesfromgeometry/ tool for conversion.
warning: Found a nonlinear node whose ID (4) is smaller than the number of base node IDs (55). Some functions may not work properly.
warning: Found a nonlinear node whose ID (4) is smaller than the number of base node IDs (77). Some functions may not work properly.
warning: Found a nonlinear node whose ID (3) is smaller than the number of base node IDs (94). Some functions may not work properly.
warning: Found a nonlinear node whose ID (7) is smaller than the number of base node IDs (95). Some functions may not work properly.
warning: Found a nonlinear node whose ID (10) is smaller than the number of base node IDs (54). Some functions may not work properly.
warning: Found a nonlinear node whose ID (5) is smaller than the number of base node IDs (30). Some functions may not work properly.
warning: Found a nonlinear node whose ID (13) is smaller than the number of base node IDs (100). Some functions may not work properly.
warning: Found a nonlinear node whose ID (10) is smaller than the number of base node IDs (147). Some functions may not work properly.
warning: Found a nonlinear node whose ID (6) is smaller than the number of base node IDs (480). Some functions may not work properly.
warning: Found a nonlinear node whose ID (6) is smaller than the number of base node IDs (478). Some functions may not work properly.
warning: Found a nonlinear node whose ID (11) is smaller than the number of base node IDs (100). Some functions may not work properly.
warning: Found a nonlinear node whose ID (9) is smaller than the number of base node IDs (51). Some functions may not work properly.
info: GroupBasedParameter: E
info: GroupBasedParameter: nu
info: GroupBasedParameter: k
info: GroupBasedParameter: phi
info: GroupBasedParameter: rho_solid
info: GroupBasedParameter: alpha
info: ConstantParameter: mu
info: ConstantParameter: rho_liquid
info: ConstantParameter: zero
info: ConstantParameter: initial_displacement
info: ConstantParameter: initial_pressure
info: No source terms for process variable ‘pressure’ found.
info: No source terms for process variable ‘displacement’ found.
error: ConfigTree: In file `C:\trial\3.7\project3\sample\hm1_3Dgravity.prj’ at path <processes/process>: Key <specific_storage> has not been found at ConfigTree.cpp, line 235
info: OGS terminated on 2020-03-10 22:50:00-0400.
And if I use the new code from Github which seems like being updated a month ago, the feedback looks like this:
info: OGS started on 2020-03-10 22:19:25-0400.
warning: Found a nonlinear node whose ID (6) is smaller than the number of base node IDs (78). Some functions may not work properly.
warning: Found a nonlinear node whose ID (7) is smaller than the number of base node IDs (94). Some functions may not work properly.
warning: Found a nonlinear node whose ID (4) is smaller than the number of base node IDs (54). Some functions may not work properly.
warning: Found a nonlinear node whose ID (3) is smaller than the number of base node IDs (30). Some functions may not work properly.
warning: Found a nonlinear node whose ID (13) is smaller than the number of base node IDs (147). Some functions may not work properly.
warning: Found a nonlinear node whose ID (13) is smaller than the number of base node IDs (479). Some functions may not work properly.
warning: Found a nonlinear node whose ID (12) is smaller than the number of base node IDs (52). Some functions may not work properly.
info: ConstantParameter: E
info: ConstantParameter: nu
error: ConfigTree: In file C:\trial\3.7\project3\sample\hm1_3Dgravity.prj' at path <media/medium>: Value for XML attribute 'id' 0,1,2,3’ not convertible to the desired type. at ConfigTree.cpp, line 235
info: OGS terminated on 2020-03-10 22:19:26-0400.
Since the book mentioned that the version it applied was OGS 5.5, if I tried the project file with it, it didn’t give me any feedback.
Most of the project under Tests\Data\HydroMechanics\Verification has the same “Key <specific_storage> has not been found at ConfigTree.cpp, line 235” problem. What is wrong with those project files? Can someone help me with it?
