Error: OGS terminated with error
Good day. I have an issue to simulate Tutorial 2 ashi.
When I am running the simulation, there will be a flashback,.And output the following.Can someone help me, thank you very much for your help
info: This is OpenGeoSys-6 version 6.3.3.
info: OGS started on 2021-03-26 17:42:19+0800.
critical:E:/gitlab/builds/XBgsxgtH/0/ogs/ogs/BaseLib/ConfigTreeUtil.cpp:134BaseLib::makeConfigTree()
error: Error while parsing XML file `ashi’ at line 0: cannot open file.
info: OGS terminated on 2021-03-26 17:42:19+0800.
Thanks,
Liu
I’m not sure what Tutorial 2 ashi is, but it looks like your project file (ashi) is not available in your working directory.
Maybe it is called ashi.prj? If so run it with path/to/bin/ogs ashi.prj
