jMC
October 4, 2019, 1:16pm
#1
Thank you for developing such a great software! I am new to the forum so please do let me know if my post would be better elsewhere for next time.
I have been trying to run the examples from the “Computational Geotechnics I – Storage of Energy Carriers” tutorial style book .
I am on Windows 10 and had to update the line endings with Notepad++.
I then downloaded the ogs-5.8-Windows-x64 from the link above, and copied the ogs.exe into the folder with all the input files.
I then created a batch file in that folder to get a text file output.
Run.bat contains only one line:
ogs.exe non-isothermal > out.txt
The output file contains:
## OpenGeoSys-Project ##
## Helmholtz Center for Environmental Research ##
## UFZ Leipzig - Environmental Informatics ##
## TU Dresden ##
## University of Kiel ##
## University of Edinburgh ##
## University of Tuebingen (ZAG) ##
## Federal Institute for Geosciences ##
## and Natural Resources (BGR) ##
## German Research Centre for Geosciences (GFZ) ##
## Version data-explorer-5-76-g5b7c300 Date 21.12.2018 ##
File name (without extension):
Data input:
Error: point 125 not found
Error: point 1 not found
Error: point 122 not found
Error: point 61 not found
GEOLIB::readGLIFile open stream from file non-isothermal.gli ... done
read points from stream ... ok, 158 points read
read polylines from stream ... ok, 7 polylines read
PCSRead ... done, read 1 processes
MFPRead
Fluid type of LIQUID is not valid. Take the default type of WATER
BCRead ... done, read 2 boundary conditions
STRead ... done, read 3 source terms
ICRead
OUTRead
TIMRead
And in the command prompt window when I run the batch file I get:
WARNING: there are 1 double points
tag #SURFACE not found or input stream error in GEOObjects
I checked the .gli file for any double points, including all the polylines. I also ran file searches for #SURFACE without success. I couldn’t find anything wrong in the mesh file either.
Any help would be most welcome. Let me know if you need any additional information.
Best
Please see the discussion as follows. You will also find a possible temporary solution.
Dr. Thomas Kalbacher “First of all, the message “SURFACE not found or input stream error in GeoObject” seems to be a bug ”
Hi All,
To use $DEACTIVATED_SUBDOMAIN, I used two different approaches. But, having some issues. I am using OGS5.
First case: *pcs File:
For this case, I considered THM benchmark as a reference (https://github.com/ufz/ogs5-benchmarks/tree/master/THM ), where directly $DEACTIVATED_SUBDOMAIN is used
#PROCESS
RICHARDS_FLOW
$NEGLECT_H_INI_EFFECT
2
1
2
$ELEMENT_MATRIX_OUTPUT
0
However, in my case, if I don’t use list of elements after SUBDOMIAN number, I…
jMC
October 7, 2019, 4:14pm
#3
Thank you Mohammad,
Adding the dummy surface did indeed remove that part of the error message.
I am still stuck with the following error though and the code doesn’t seem to progress:
I am unclear what this error means.
Unfortunately I cannot yet upoad zip files. But here is the content of the Gli file:
#POINTS
0 0.0000000000000000e+00 -1.0000000000000000e+06 0.0000000000000000e+00 $NAME P_0
1 0.0000000000000000e+00 -1.1009950899999999e+06 0.0000000000000000e+00 $NAME P_1
2 4.7187424686120022e+02 -1.1010136299896534e+06 0.0000000000000000e+00 $NAME P_2
3 9.4083923207639111e+02 -1.1010691356534120e+06 0.0000000000000000e+00 $NAME P_3
4 1.4040036305650387e+03 -1.1011612647804013e+06 0.0000000000000000e+00 $NAME P_4
5 1.8585118797926689e+03 -1.1012894493639173e+06 0.0000000000000000e+00 $NAME P_5
6 2.3015617852634632e+03 -1.1014528991033772e+06 0.0000000000000000e+00 $NAME P_6
7 2.7304217969811511e+03 -1.1016506062767843e+06 0.0000000000000000e+00 $NAME P_7
8 3.1424478503630671e+03 -1.1018813519536706e+06 0.0000000000000000e+00 $NAME P_8
9 3.5350996677775461e+03 -1.1021437135102074e+06 0.0000000000000000e+00 $NAME P_9
10 3.9059564202002475e+03 -1.1024360734001540e+06 0.0000000000000000e+00 $NAME P_10
11 4.2527316524301023e+03 -1.1027566291275697e+06 0.0000000000000000e+00 $NAME P_11
12 4.5732873798459477e+03 -1.1031034043597998e+06 0.0000000000000000e+00 $NAME P_12
13 4.8656472697926674e+03 -1.1034742611122224e+06 0.0000000000000000e+00 $NAME P_13
14 5.1280088263292109e+03 -1.1038669129296369e+06 0.0000000000000000e+00 $NAME P_14
15 5.3587545032154612e+03 -1.1042789389830190e+06 0.0000000000000000e+00 $NAME P_15
16 5.5564616766226891e+03 -1.1047077989947365e+06 0.0000000000000000e+00 $NAME P_16
17 5.7199114160825347e+03 -1.1051508489002071e+06 0.0000000000000000e+00 $NAME P_17
18 5.8480959995986705e+03 -1.1056053571494350e+06 0.0000000000000000e+00 $NAME P_18
19 5.9402251265880232e+03 -1.1060685215479236e+06 0.0000000000000000e+00 $NAME P_19
20 5.9957307903466590e+03 -1.1065374865331387e+06 0.0000000000000000e+00 $NAME P_20
21 6.0142707800000007e+03 -1.1070093607800000e+06 0.0000000000000000e+00 $NAME B
22 6.0142707800000007e+03 -1.1080091267341250e+06 0.0000000000000000e+00 $NAME P_22
23 6.0142707800000007e+03 -1.1090088926882499e+06 0.0000000000000000e+00 $NAME P_23
24 6.0142707800000007e+03 -1.1100086586423749e+06 0.0000000000000000e+00 $NAME P_24
25 6.0142707800000007e+03 -1.1110084245964999e+06 0.0000000000000000e+00 $NAME P_25
26 6.0142707800000007e+03 -1.1120081905506249e+06 0.0000000000000000e+00 $NAME P_26
27 6.0142707800000007e+03 -1.1130079565047498e+06 0.0000000000000000e+00 $NAME P_27
28 6.0142707800000007e+03 -1.1140077224588748e+06 0.0000000000000000e+00 $NAME P_28
29 6.0142707800000007e+03 -1.1150074884130000e+06 0.0000000000000000e+00 $NAME P_29
30 6.0142707800000007e+03 -1.1160072543671250e+06 0.0000000000000000e+00 $NAME P_30
31 6.0142707800000007e+03 -1.1170070203212500e+06 0.0000000000000000e+00 $NAME P_31
32 6.0142707800000007e+03 -1.1180067862753749e+06 0.0000000000000000e+00 $NAME P_32
33 6.0142707800000007e+03 -1.1190065522294999e+06 0.0000000000000000e+00 $NAME P_33
34 6.0142707800000007e+03 -1.1200063181836249e+06 0.0000000000000000e+00 $NAME P_34
35 6.0142707800000007e+03 -1.1210060841377499e+06 0.0000000000000000e+00 $NAME P_35
36 6.0142707800000007e+03 -1.1220058500918748e+06 0.0000000000000000e+00 $NAME P_36
37 6.0142707800000007e+03 -1.1230056160459998e+06 0.0000000000000000e+00 $NAME P_37
38 6.0142707800000007e+03 -1.1240053820001248e+06 0.0000000000000000e+00 $NAME P_38
39 6.0142707800000007e+03 -1.1250051479542500e+06 0.0000000000000000e+00 $NAME P_39
40 6.0142707800000007e+03 -1.1260049139083750e+06 0.0000000000000000e+00 $NAME P_40
41 6.0142707800000007e+03 -1.1270046798624999e+06 0.0000000000000000e+00 $NAME C
42 6.0142707800000007e+03 -1.1280044458166249e+06 0.0000000000000000e+00 $NAME P_42
43 6.0142707800000007e+03 -1.1290042117707499e+06 0.0000000000000000e+00 $NAME P_43
44 6.0142707800000007e+03 -1.1300039777248749e+06 0.0000000000000000e+00 $NAME P_44
45 6.0142707800000007e+03 -1.1310037436789998e+06 0.0000000000000000e+00 $NAME P_45
46 6.0142707800000007e+03 -1.1320035096331248e+06 0.0000000000000000e+00 $NAME P_46
47 6.0142707800000007e+03 -1.1330032755872498e+06 0.0000000000000000e+00 $NAME P_47
48 6.0142707800000007e+03 -1.1340030415413748e+06 0.0000000000000000e+00 $NAME P_48
49 6.0142707800000007e+03 -1.1350028074954997e+06 0.0000000000000000e+00 $NAME P_49
50 6.0142707800000007e+03 -1.1360025734496252e+06 0.0000000000000000e+00 $NAME P_50
51 6.0142707800000007e+03 -1.1370023394037501e+06 0.0000000000000000e+00 $NAME P_51
52 6.0142707800000007e+03 -1.1380021053578751e+06 0.0000000000000000e+00 $NAME P_52
53 6.0142707800000007e+03 -1.1390018713120001e+06 0.0000000000000000e+00 $NAME P_53
54 6.0142707800000007e+03 -1.1400016372661251e+06 0.0000000000000000e+00 $NAME P_54
55 6.0142707800000007e+03 -1.1410014032202500e+06 0.0000000000000000e+00 $NAME P_55
56 6.0142707800000007e+03 -1.1420011691743750e+06 0.0000000000000000e+00 $NAME P_56
57 6.0142707800000007e+03 -1.1430009351285000e+06 0.0000000000000000e+00 $NAME P_57
58 6.0142707800000007e+03 -1.1440007010826250e+06 0.0000000000000000e+00 $NAME P_58
59 6.0142707800000007e+03 -1.1450004670367499e+06 0.0000000000000000e+00 $NAME P_59
60 6.0142707800000007e+03 -1.1460002329908749e+06 0.0000000000000000e+00 $NAME P_60
61 6.0142707800000007e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME D
62 6.0142707800000007e+03 -1.1479997648991251e+06 0.0000000000000000e+00 $NAME P_62
63 6.0142707800000007e+03 -1.1489995308532501e+06 0.0000000000000000e+00 $NAME P_63
64 6.0142707800000007e+03 -1.1499992968073750e+06 0.0000000000000000e+00 $NAME P_64
65 6.0142707800000007e+03 -1.1509990627615000e+06 0.0000000000000000e+00 $NAME P_65
66 6.0142707800000007e+03 -1.1519988287156250e+06 0.0000000000000000e+00 $NAME P_66
67 6.0142707800000007e+03 -1.1529985946697500e+06 0.0000000000000000e+00 $NAME P_67
68 6.0142707800000007e+03 -1.1539983606238749e+06 0.0000000000000000e+00 $NAME P_68
69 6.0142707800000007e+03 -1.1549981265779999e+06 0.0000000000000000e+00 $NAME P_69
70 6.0142707800000007e+03 -1.1559978925321249e+06 0.0000000000000000e+00 $NAME P_70
71 6.0142707800000007e+03 -1.1569976584862501e+06 0.0000000000000000e+00 $NAME P_71
72 6.0142707800000007e+03 -1.1579974244403751e+06 0.0000000000000000e+00 $NAME P_72
73 6.0142707800000007e+03 -1.1589971903945000e+06 0.0000000000000000e+00 $NAME P_73
74 6.0142707800000007e+03 -1.1599969563486250e+06 0.0000000000000000e+00 $NAME P_74
75 6.0142707800000007e+03 -1.1609967223027500e+06 0.0000000000000000e+00 $NAME P_75
76 6.0142707800000007e+03 -1.1619964882568750e+06 0.0000000000000000e+00 $NAME P_76
77 6.0142707800000007e+03 -1.1629962542109999e+06 0.0000000000000000e+00 $NAME P_77
78 6.0142707800000007e+03 -1.1639960201651249e+06 0.0000000000000000e+00 $NAME P_78
79 6.0142707800000007e+03 -1.1649957861192499e+06 0.0000000000000000e+00 $NAME P_79
80 6.0142707800000007e+03 -1.1659955520733749e+06 0.0000000000000000e+00 $NAME P_80
81 6.0142707800000007e+03 -1.1669953180274998e+06 0.0000000000000000e+00 $NAME E
82 6.0142707800000007e+03 -1.1679950839816250e+06 0.0000000000000000e+00 $NAME P_82
83 6.0142707800000007e+03 -1.1689948499357500e+06 0.0000000000000000e+00 $NAME P_83
84 6.0142707800000007e+03 -1.1699946158898750e+06 0.0000000000000000e+00 $NAME P_84
85 6.0142707800000007e+03 -1.1709943818440000e+06 0.0000000000000000e+00 $NAME P_85
86 6.0142707800000007e+03 -1.1719941477981249e+06 0.0000000000000000e+00 $NAME P_86
87 6.0142707800000007e+03 -1.1729939137522499e+06 0.0000000000000000e+00 $NAME P_87
88 6.0142707800000007e+03 -1.1739936797063749e+06 0.0000000000000000e+00 $NAME P_88
89 6.0142707800000007e+03 -1.1749934456604999e+06 0.0000000000000000e+00 $NAME P_89
90 6.0142707800000007e+03 -1.1759932116146248e+06 0.0000000000000000e+00 $NAME P_90
91 6.0142707800000007e+03 -1.1769929775687498e+06 0.0000000000000000e+00 $NAME P_91
92 6.0142707800000007e+03 -1.1779927435228748e+06 0.0000000000000000e+00 $NAME P_92
93 6.0142707800000007e+03 -1.1789925094770000e+06 0.0000000000000000e+00 $NAME P_93
94 6.0142707800000007e+03 -1.1799922754311250e+06 0.0000000000000000e+00 $NAME P_94
95 6.0142707800000007e+03 -1.1809920413852499e+06 0.0000000000000000e+00 $NAME P_95
96 6.0142707800000007e+03 -1.1819918073393749e+06 0.0000000000000000e+00 $NAME P_96
97 6.0142707800000007e+03 -1.1829915732934999e+06 0.0000000000000000e+00 $NAME P_97
98 6.0142707800000007e+03 -1.1839913392476249e+06 0.0000000000000000e+00 $NAME P_98
99 6.0142707800000007e+03 -1.1849911052017498e+06 0.0000000000000000e+00 $NAME P_99
100 6.0142707800000007e+03 -1.1859908711558748e+06 0.0000000000000000e+00 $NAME P_100
101 6.0142707800000007e+03 -1.1869906371099998e+06 0.0000000000000000e+00 $NAME F
102 5.9957307903466599e+03 -1.1874625113568611e+06 0.0000000000000000e+00 $NAME P_102
103 5.9402251265880250e+03 -1.1879314763420762e+06 0.0000000000000000e+00 $NAME P_103
104 5.8480959995986732e+03 -1.1883946407405650e+06 0.0000000000000000e+00 $NAME P_104
105 5.7199114160825375e+03 -1.1888491489897924e+06 0.0000000000000000e+00 $NAME P_105
106 5.5564616766226936e+03 -1.1892921988952633e+06 0.0000000000000000e+00 $NAME P_106
107 5.3587545032154658e+03 -1.1897210589069810e+06 0.0000000000000000e+00 $NAME P_107
108 5.1280088263292164e+03 -1.1901330849603631e+06 0.0000000000000000e+00 $NAME P_108
109 4.8656472697926729e+03 -1.1905257367777773e+06 0.0000000000000000e+00 $NAME P_109
110 4.5732873798459550e+03 -1.1908965935302002e+06 0.0000000000000000e+00 $NAME P_110
111 4.2527316524301104e+03 -1.1912433687624300e+06 0.0000000000000000e+00 $NAME P_111
112 3.9059564202002557e+03 -1.1915639244898458e+06 0.0000000000000000e+00 $NAME P_112
113 3.5350996677775538e+03 -1.1918562843797924e+06 0.0000000000000000e+00 $NAME P_113
114 3.1424478503630762e+03 -1.1921186459363292e+06 0.0000000000000000e+00 $NAME P_114
115 2.7304217969811598e+03 -1.1923493916132154e+06 0.0000000000000000e+00 $NAME P_115
116 2.3015617852634737e+03 -1.1925470987866225e+06 0.0000000000000000e+00 $NAME P_116
117 1.8585118797926784e+03 -1.1927105485260824e+06 0.0000000000000000e+00 $NAME P_117
118 1.4040036305650483e+03 -1.1928387331095985e+06 0.0000000000000000e+00 $NAME P_118
119 9.4083923207640169e+02 -1.1929308622365880e+06 0.0000000000000000e+00 $NAME P_119
120 4.7187424686121039e+02 -1.1929863679003464e+06 0.0000000000000000e+00 $NAME P_120
121 0.0000000000000000e+00 -1.1930049078899999e+06 0.0000000000000000e+00 $NAME P_121
122 0.0000000000000000e+00 -1.2939999978899998e+06 0.0000000000000000e+00 $NAME P_122
123 2.5000000000000000e+05 -1.2939999978899998e+06 0.0000000000000000e+00 $NAME P_123
124 2.5000000000000000e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_124
125 2.5000000000000000e+05 -1.0000000000000000e+06 0.0000000000000000e+00 $NAME P_125
126 6.4338426566000007e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_126
127 6.9890337256363646e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_127
128 7.6798439871090914e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_128
129 8.5062734410181820e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_129
130 9.4683220873636346e+03 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_130
131 1.0565989926145456e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_131
132 1.1799276957363636e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_132
133 1.3168183181018183e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_133
134 1.4672708597109091e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_134
135 1.6312853205636362e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_135
136 1.8088617006600001e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_136
137 2.0000000000000000e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_137
138 2.0000000000000000e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_138
139 2.2300000000000000e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_139
140 2.5568421052631576e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_140
141 2.9805263157894737e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_141
142 3.5010526315789473e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_142
143 4.1184210526315794e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_143
144 4.8326315789473680e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_144
145 5.6436842105263160e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_145
146 6.5515789473684206e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_146
147 7.5563157894736840e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_147
148 8.6578947368421053e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_148
149 9.8563157894736825e+04 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_149
150 1.1151578947368421e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_150
151 1.2543684210526317e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_151
152 1.4032631578947368e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_152
153 1.5618421052631582e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_153
154 1.7301052631578950e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_154
155 1.9080526315789472e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_155
156 2.0956842105263157e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_156
157 2.2929999999999997e+05 -1.1469999989450001e+06 0.0000000000000000e+00 $NAME P_157
#POLYLINE
$NAME
TOP
$POINTS
0
125
#POLYLINE
$NAME
TOP_LEFT
$POINTS
0
1
#POLYLINE
$NAME
BOT_LEFT
$POINTS
121
122
#POLYLINE
$NAME
BOT
$POINTS
122
123
#POLYLINE
$NAME
OUTER
$POINTS
125
123
#POLYLINE
$NAME
CAVERN
$POINTS
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
#POLYLINE
$NAME
SECTION
$POINTS
61
124
#POLYLINE
$NAME
Domain_Boundary
$EPSILON
0.001
$POINTS
0
1
2
3
0
#SURFACE
$NAME
Domain_Boundary
$POLYLINES
Domain_Boundary
Please go to this drive \ogs-6.0.8\bin\DataExplorer,
then open the Data Explorer
Then File>Open (From the bottom right drop down menu select GeoSys legacy files (*.gli, *.msh)).
Then open Geometry file and Mesh file.
You will able to inspect your points. Additionally, check a couple of issues, $NAME B, $NAME C, $NAME D, $NAME E,$NAME F. Finally please also check following points
Data input:
jMC
October 8, 2019, 11:39am
#5
Hi Mohammad,
Thank you for your help.
A colleague and I managed to get it to work. The double point were:
Then updating to a newer OGS5 version removed the following error:
Data input:
We then had to use the Linear Solver method “2” instead of “805” though.
