dear all
i am new user here, i want to update "OGS_BUILD_UTILS "
but after i run “ccmake .” the i push [c] and [g] i got error
that i am confused to solved it
$<COMPILE_LANG_AND_ID:lang,id> may only be used with binary targets to
specify include directories, compile definitions, and compile options. It
may not be used with the add_custom_command, add_custom_target, or
file(GENERATE) commands.
ThirdParty/cmake-modules/cotire.cmake:2993 (cotire_generate_target_script)
ThirdParty/cmake-modules/cotire.cmake:3383 (cotire_process_target_language)
ThirdParty/cmake-modules/cotire.cmake:3567 (cotire_target)
Tests/CMakeLists.txt:89 (cotire)
CMake Error at ThirdParty/cmake-modules/cotire.cmake:2374 (file):
Error evaluating generator expression:
$<COMPILE_LANG_AND_ID:CUDA,NVIDIA>
may not be us:ed with the add_custom_command, add_custom_target, or
Anyone could help me?
