I have been running some geothermal doublet simulations using OGS. My models so far has been a reservoir with just one fault and I have moved to a phase of my project where I am considering some more complicated fracture networks.
I used all of the same medium and solid properties as well as BC and IC etc… I basically replaced the mesh with a new mesh that was generated using HyperMesh. I used triangles for the surfaces and tetrahedrons for volume elements so in theory the mesh should be fine, however, when I run the simulation I get the following Error…
I used all of the same medium and solid properties as well as BC and IC etc.. I basically replaced the mesh with a new mesh that was generated using HyperMesh. I used triangles for the surfaces and tetrahedrons for volume elements so in theory the mesh should be fine, however, when I run the simulation I get the following Error..
The error means there is an element with zero volume or zero area. you should check the mesh.
Norihiro Watanabe
Sorry for a short message and any spelling errors. Sent from my mobile phone.
On 16 Jun 2016 17:10 +0200, Ariel Thomas , wrote:
Time step: 1| Time: 86400| Time step size: 86400
->Process 0: LIQUID_FLOW
PCS non-linear iteration: 0/100
Assembling equation system...
*** Jacobian: DetJac == 0 0
zsh: abort (core dumped) ogs res6
Can anyone give me a bit more insight into what exactly can be the root of this error?
Ariel
Ahh ok! I will reduced the complexity of the fracture network a bit and take care of the mesh quality.
Thanks for the feedback everyone!
-Ariel
On Thursday, June 16, 2016 at 5:10:31 PM UTC+2, Ariel Thomas wrote:
