Hi, everyone, the command “ExtractBoundary -i [] [-o ]” of OGS can only extract the overall outer contour.But I didn’t find a command that can extract different boundary lines, how should I extract different boundaries of a 2D network? Thanks all.
Hi, if you generate yur mesh with gmsh you can mark the physical groups in your gmsh script and msh2vtu will the boundaries for you. Otherwise, the quickest solution would probably be to use the resulting contour from ExtractBoundary, load it in paraview, manually select the different boundaries, extract selection and save to corresponding vtu files.
Florian
Thank you for your reply. Best wishes!
Hi, you probably need to run the tool IdentifySubdomains over the bulk mesh and the extracted boundary afterwards to have the correct mapping of the bulk_node_ids. Also check, that the bulk mesh doesn’t contain the boundary elements itself.
If you have marked the boundaries as physical groups in gmsh you can also just use msh2vtu and don’t need to extract them manually in paraview. Then you also shouldn’t need the extra IdentifySubdomains afterwards.
Best, Florian
But there doesn’t seem to be a command for msh2vtu in Linux.
It’s not a Binary from the OGS build. It’s a part of the ogstools which you can install via pip. And then you should be able to execute msh2vtu from the commandline - or you use the python interface - whatever you prefer.
Can you send your pip / python version? Please run:
pip --version
I also tried pip3 install ogstools, but it also showed this result.
You need to have at least Python 3.10.
Hi, I used the command “msh2vtu -p slope slope.msh” and got a series of vtu files, but when I run it I get an error:
I guessed that there is no boundary on the region file(slope_domain.vtu), so I generated the region file using the command “GMSH2OGS -i slope.msh -o slope.vtu”, but it still reported an error:
I’m trying to figure out which file I should use.
Best regards!
Hi
I have had the same error of the negative jacobian and I changed the order of my curve loops as suggested in this link
https://discourse.opengeosys.org/t/det-j-is-negative/457/5
hope it works ![]()
María
Hi
Regarding the first error, I have no idea. And the second one, looks like you are not declaring one parameter right in the input file. Maybe you are using it somewhere before declaring it. Try to check the input file and that all the parameters are being declare properly.
Hope it helps
María
Thanks for the advice. Good luck!!
