Hello everyone,
I tried modifying the staggered-scheme HTC benchmark project available in HTCWithFracture by prescribing a custom Function for the fluid density depending on pressure, temperature, and concentration.
At the first time step, the first process is solved correctly. However, when OGS starts assembling/solving the second process, I get the following error:
critical: /home/rnogandagacapito/apps/ogs-6.5.7/MaterialLib/MPL/Properties/Function.cpp:270 operator()()
warning: There are still 1 global matrices in use. This might be an indicator of a possible waste of memory.
warning: There are still 2 global vectors in use. This might be an indicator of a possible waste of memory.
error: Function property: Scalar variable ‘concentration’ is not initialized.
I found this closed MR which mentions that the issue had been fixed in more recent MRs.
So I would like to ask whether this is currently supported in OGS. Can a Function property such as density depend simultaneously on pressure, temperature, and concentration in the staggered HTC scheme?
I am using OGS 6.5.7, and you will find the modified .prj file attached below.
HTCWithFracture_modif.zip (1019.1 KB)
Thank you in advance for your help.
