Hi All,
I discussed before regarding the hydrostatic equilibrium condition for H2 case. I would like to thank Nori and Wang.
Now I have a situation. I am checking mechanical equilibrium condition and hydrostatic equilibrium condition for H2M case considering CAM_CLAY. Soil column height is 1 m and width 0.1 m. Gravity activated for both Liquid (Density =1000 ) and Solid (Density = 2000) mass. The mechanical equilibrium is working fine, and logical. But, for Hydrostatic condition, in H2 phase, Liquid pressure is triangular and logical. To achieve it, I used
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 9810
Now for DEFORMATION, I used as follows
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 19620
At time step zero, STRESS_YY is showing zero, and GRADIENT is not working. But, I need STRESS_YY=Densitygy=20009.81y, at top it need to be zero and bottom 19620. Any idea how to resolve it?
I think you need to change $PRIMARY_VARIABLE to DISPLACEMENT_Y (or Y1, not sure).
n
On 06/15/2017 05:37 AM, Mohammad Islam wrote:
Hi All,
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE1
$GEO_TYPE
DOMAIN
$DIS_TYPE
CONSTANT 0
#INITIAL_CONDITION
MULTI_PHASE_FLOW
$PRIMARY_VARIABLE
PRESSURE2
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 9810
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 19620
At time step zero, STRESS_YY is showing zero, and GRADIENT is not working. But, I need STRESS_YY=Density*g*y=2000*9.81*y, at top it need to be zero and bottom 19620. Any idea how to resolve it?
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+unsubscribe@googlegroups.com <mailto:ogs-users+unsubscribe@googlegroups.com>.
Dear Nori,
In Hydrostatic condition, at time=0, Displacements in X, Y, Z directions are zero and OGS results also agree with it. If I use following command, it will provide Displacement gradient along Y-direction. But, I need Vertical Stress gradient due to Gravity force ( Y=1, STRESS_YY=0; Y=0,STRESS_YY=Densityg(1-Y)=19620 )
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_Y
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 19620
I looks GRADIENT command is working fine for H2 case, but some how it is not working for me in Mechanical case, like for DISPLACEMENT_Y or STRESS_YY. Any idea?
On Wednesday, 14 June 2017 17:23:48 UTC-4, Norihiro Watanabe wrote:
not sure).
n
okay.. I thought one should use DISPLACEMENT_Y for stress yy. maybe I'm confused with something else.
how about the following setting?
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
SUB_DOMAIN
1
0 0+19620*y
On 06/15/2017 07:01 AM, Mohammad Islam wrote:
Dear Nori,
In Hydrostatic condition, at time=0, Displacements in X, Y, Z directions are zero and OGS results also agree with it. If I use following command, it will provide Displacement gradient along Y-direction. But, I need Vertical Stress gradient due to Gravity force ( Y=1, STRESS_YY=0; Y=0,STRESS_YY=Density*g*(1-Y)=19620 )
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_Y
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 19620
not sure).
n
Dear Nori,
Now it shows some results! Good sign.
But, in bottom 9.475386710584e+001 and top 1.961106694675e+004, while I need at bottom 19620, top 0.Somehow I need to reverse the result.
On Wednesday, 14 June 2017 18:07:12 UTC-4, Norihiro Watanabe wrote:
okay… I thought one should use DISPLACEMENT_Y for stress yy. maybe I’m
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
SUB_DOMAIN
1
0 0+19620*y
Dear Nori,
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
DISPLACEMENT_Y
$GEO_TYPE
DOMAIN
$DIS_TYPE
GRADIENT 1 0 19620
not sure).
n
Groups “ogs-users” group.
an email to ogs-users+...@googlegroups.com
mailto:ogs-users+...@googlegroups.com.
After using following, bottom 1.952524613289e+004 & top 8.933053249650e+000. I wish I could dig out the source of the 8.93 !!
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
SUB_DOMAIN
1
0 19620±19620*y
If the value is at a mesh node, 8.93 is probably a result of extrapolation. In OGS, stress used for calculation is stored at Gauss integration points (inside of elements). For output purposes, they are extrapolated to nodal values.
n
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
SUB_DOMAIN
1
0 19620+-19620*y
but please also check if the node coordinate is exactly zero at top.
n
#INITIAL_CONDITION
DEFORMATION
$PRIMARY_VARIABLE
STRESS_YY
$GEO_TYPE
SUB_DOMAIN
1
0 19620+-19620*y
