Hi All,
I developed a series of constitutive models for soft clay considering associated and non-associated flow rule. Most cases I used Modified Cam Clay (MCC) Framework, Perzyna’s Overstress theory, Bounding surface theory. For validation, I considered conventional triaxial tests and true-triaxial tests (drained test, undrained test, creep test, ocr effect, strain rate test…).
In my models, five parameters are identical to the MCC model. The other parameters are the secondary compression index and shape parameter. Last two parameters also can be obtained from experiments, i.e., conventional triaxial test.
Now, I want to incorporate my models in ogs 5. Can any one brief me the dependency tree for the MCC model in ogs 5? To be more specific, the MCC model is available in rf_msp_new.cpp. What are the other file, where the MCC model was declared?
Thanks in advance.
Where to change for adding a new model:
1) rf_msp_new.cpp,
* input: std::ios::pos_type CSolidProperties::Read(std::ifstream* msp_file)
(see if (sub_line.find("CAM-CLAY") != string::npos), around line 855 )
* member function for the model, see
CSolidProperties::CalStress_and_TangentialMatrix_CC (start from line 7477)
CSolidProperties::CalStress_and_TangentialMatrix_CC_SubStep (start from line 7957)
2) fem_ele_vec.cpp, void CFiniteElementVec::LocalAssembly_continuum(const int update), where the model is used.
On 11/28/18 10:58 PM, Mohammad Islam wrote:
Hi All,
Thanks in advance.
Dear Wenqing Wang,
Thank you.
On Thursday, 29 November 2018 04:11:04 UTC-5, Wenqing Wang wrote:
2) fem_ele_vec.cpp, void CFiniteElementVec:: LocalAssembly_continuum(const int update), where the model is used.
Hi All,
Thanks in advance.
To unsubscribe from this group and stop receiving emails from it, send an email to ogs-users+...@googlegroups.com.
1) rf_msp_new.cpp,
CSolidProperties::CalStress_ and_TangentialMatrix_CC (start from line 7477)
CSolidProperties::CalStress_and_TangentialMatrix_CC_ SubStep (start from line 7957)
