Installing OGS - Virtual environment problem
Hi - I am trying to install OGS on a Mac - I have limited python experience.
OGS says:
A straightforward way of installing OGS is via Python’s pip-tool:
# Optional: create a Python virtual environment, see below
python -m venv .venv
.\venv\Scripts\Activate.ps1 # for PowerShell OR
.\venv\Scripts\activate.bat # for Command Prompt
This is what I see in Terminal:
robincurtis@Robins-MacBook-Pro750 ~ % python -m venv .venv
robincurtis@Robins-MacBook-Pro750 ~ % .\venv\Scripts\activate.bat
zsh: command not found: .venvScriptsactivate.bat
Do I need an activate.bat file ? Where ?
This is basic stuff - any help appreciated
Thank you.......
in the top of the page you are referring (Introduction) you need to select the macOS tab or (in this special case) the Linux tab and you will find:
source .venv/bin/activate
Tobias
Thank you for this Tobias. I have tried clicking on the Select OS option in the Introduction - and I don’t see anything change. (Tried 3 different browsers).
Do I just put:
into Terminal ?
Apologies for unfamiliarity with python - just want to get to the modelling !!
Regards Robin.
yest, then the next step (if you follow the Python way) would be:
pip install ogstools[ogs]
Now ogs is available in your current shell session (terminal).
If you do not need/want to work with Python see Option2 in:
Tobias
Tobias - thank you for this.
Think I need to upgrade my version of Python.
Regards Robin
As additional remark for the default zsh terminal on Mac: pip install ogstools[ogs] didn’t work, instead pip install ogstools"[ogs]" works
Or pip install ogstools\[ogs\].
