Issue with OGS-PhreeqC coupling
I have a question and I would be grateful if anyone can answer it.
I have a kinetic equation for urea degradation (trial_ogs3 attached file). When I run it using standalone phreeqC, I get the punched values for both tot(“Urea”) and kin(“urea_degradation”) (Please refer to the output file phout_sel).
However, when I use the coupled version OGS-PhreeqC (pds.pqc attached file) for the same phreeqC input file, only tot(“Urea”) is getting punched in the output file (phout_sel(1)) and kin(“urea_degradation”) is not getting punched. I want this to get punched in phout_sel file. What should I do? (I do not have any phase description for this kinetic equation)
I have added both Urea and urea_degradation as a component in .mcp file.
Thank you for you kind help in advance.
Sincerely,
Sumana Bhattacharya
phout_sel (1).dat (16.9 KB)
phout_sel.dat (0 Bytes)
trial_ogs3.pqi (915 Bytes)
pds.pqc (619 Bytes)
Hi Sumana,
you can punch any quantity from Phreeqc to OGS by adding the following commands to your *.pqc file:
     The new Keywords
ADDITIONAL_OUTPUT
     CO3-2 # comp
     HCO3- # comp
     a_HCO3- # comp
#ende
ADDITIONAL_PUNCH
     PUNCH MOL("CO3-2")
     PUNCH MOL("HCO3-")
     PUNCH ACT("HCO3-")
#ende
now allow output of other quantities than primary species concentrations from PHREEQC. For these quantities (e.g. concentrations of secondary species, activities, etc.), additional (immobile) components must be defined in OGS to store the output values, i.e. for the above example the components CO3-2, HCO3- and a_HCO3- have to be defnined. For each component in the ADDITIONAL_OUTPUT list a corresponding ADDITIONAL_PUNCH statement must be provided, which invokes output of the requested quantity from PHREEQC by means of the USER_PUNCH keyword. In the example, additional output are concentrations of CO3-2 and HCO3- complexes as well as the activity of the latter.
This was introduced in v5.5.0
Cheers, Christof
Am 15.04.2015 um 10:57 schrieb sumanab24:
for both tot("Urea") and kin("urea_degradation") (Please refer to the
file) for the same phreeqC input file, only tot("Urea") is getting
punched in the output file (phout_sel(1)) and kin("urea_degradation") is
Sincerely,
Sumana Bhattacharya
Groups "ogs-users" group.
an email to [email protected]
<mailto:[email protected]>.
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
Dr. Beyer,
Does ADDITIONAL_PUNCH punch user defined kinetics also? It doesn’t seem to punch KIN(“urea_degradation”) for me.
Thank you for your kind reply.
Sincerely,
Sumana Bhattacharya
On Wednesday, April 15, 2015 at 2:34:03 PM UTC+5:30, cb wrote:
Hi Sumana,
 The new Keywords
ADDITIONAL_OUTPUT
 CO3-2 # comp
 HCO3- # comp
 a_HCO3- # comp
#ende
ADDITIONAL_PUNCH
 PUNCH MOL("CO3-2")
 PUNCH MOL("HCO3-")
 PUNCH ACT("HCO3-")
#ende
Cheers, Christof
Sincerely,
Sumana Bhattacharya
Groups “ogs-users” group.
mailto:[email protected].
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
I guess so. It should punch any variable or parameter phreeqc can write in the selected output file. You need both statements;
ADDITIONAL_OUTPUT
#ende
ADDITIONAL_PUNCH
#ende
I have attached an example pqc file for you (benchmarks\C\Engesgaard\Additional_pqc_output). If you cannot make OGS-Phreeqc give you the data, I can check what's wrong if you provide me your inputs
Best regards, Christof
pds.pqc (682 Bytes)
Am 15.04.2015 um 12:06 schrieb sumanab24:
Dr. Beyer,
Does ADDITIONAL_PUNCH punch user defined kinetics also? It doesn't seem
to punch KIN("urea_degradation") for me.
Sincerely,
Sumana Bhattacharya
    Hi Sumana,
          The new Keywords
    ADDITIONAL_OUTPUT
          CO3-2 # comp
          HCO3- # comp
          a_HCO3- # comp
    #ende
    ADDITIONAL_PUNCH
          PUNCH MOL("CO3-2")
          PUNCH MOL("HCO3-")
          PUNCH ACT("HCO3-")
    #ende
    concentrations
    ADDITIONAL_PUNCH
    Cheers, Christof
     > Hi,
     > I have a question and I would be grateful if anyone can answer it.
     > I have a kinetic equation for urea degradation (trial_ogs3 attached
     > file). When I run it using standalone phreeqC, I get the punched
    values
     > for both tot("Urea") and kin("urea_degradation") (Please refer to
    the
     > output file phout_sel).
     > However, when I use the coupled version OGS-PhreeqC (pds.pqc
    attached
     > file) for the same phreeqC input file, only tot("Urea") is getting
     > punched in the output file (phout_sel(1)) and
     > not getting punched. I want this to get punched in phout_sel
    file. What
     > should I do? (I do not have any phase description for this
    kinetic equation)
     > I have added both Urea and urea_degradation as a component in
    .mcp file.
     > Thank you for you kind help in advance.
     > Sincerely,
     > Sumana Bhattacharya
     > You received this message because you are subscribed to the Google
     > Groups "ogs-users" group.
     > To unsubscribe from this group and stop receiving emails from it,
    send
     > an email to ogs-users+...@googlegroups.com <javascript:>
     > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
     > For more options, visit https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;\.
    Dr. Christof Beyer
    Geohydromodelling
    24118 Kiel
    Germany
    email: christo...@gpi.uni-kiel.de <javascript:>
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dr. Beyer,
Please find attached my input files. I am sorry that these are for Windows 64 bit OS (please rename the file pds.msp.txt to pds.msp).
Thank you very much for your kind help.
Sincerely,
Sumana Bhattacharya
pds.bc (749 Bytes)
pds.gli (365 Bytes)
pds.ic (880 Bytes)
pds.mcp (932 Bytes)
pds.mfp (481 Bytes)
pds.mmp (1.53 KB)
pds.msh (2.72 KB)
pds.num (1.53 KB)
pds.out (1021 Bytes)
pds.pcs (484 Bytes)
pds.pqc (703 Bytes)
pds.rei (309 Bytes)
pds.rfe (73 Bytes)
pds.st (258 Bytes)
pds.tim (303 Bytes)
phinp.dat (64.4 KB)
phinp.out (565 KB)
phreeqc.dat (26.5 KB)
phreeqc.log (0 Bytes)
profile.lay (17.1 KB)
pds.msp.txt (1.16 KB)
On Wednesday, April 15, 2015 at 3:52:29 PM UTC+5:30, cb wrote:
ADDITIONAL_OUTPUT
#ende
ADDITIONAL_PUNCH
#ende
OGS-Phreeqc give you the data, I can check what’s wrong if you provide
me your inputs
Dr. Beyer,
Sincerely,
Sumana Bhattacharya
Hi Sumana,
      The new Keywords
ADDITIONAL_OUTPUT
      CO3-2 # comp
      HCO3- # comp
      a_HCO3- # comp
#ende
ADDITIONAL_PUNCH
      PUNCH MOL("CO3-2")
      PUNCH MOL("HCO3-")
      PUNCH ACT("HCO3-")
#ende
concentrations
ADDITIONAL_PUNCH
Cheers, Christof
 > Hi,
values
the
attached
file. What
kinetic equation)
.mcp file.
 > Sincerely,
 > Sumana Bhattacharya
send
 > an email to [email protected] <javascript:>
 > <mailto:[email protected] <javascript:>>.
 > For more options, visit [https://groups.google.com/d/optout](https://groups.google.com/d/optout)
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>.
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
email: [email protected] <javascript:>
home: [http://www.ifg.uni-kiel.de/](http://www.ifg.uni-kiel.de/)
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Hi Sumana,
just as in the SOLUTION section of your *.pqc file, you have to add
"# comp"
after Urea_degradation:
ADDITIONAL_OUTPUT
Urea_degradation # comp
This will specify for ogs that "Urea_degradation" is the name of a (dummy) component which will store the information from the requested Phreeqc output. If you ommit this indicator, ogs will ignore the ADDITIONAL_OUTPUT request and the corresponding PUNCH command is not written into the phinp.dat file.
Let me know if this fixed your problem,
Christof
Am 15.04.2015 um 12:46 schrieb sumanab24:
Dr. Beyer,
Sincerely,
Sumana Bhattacharya
    ADDITIONAL_OUTPUT
    #ende
    ADDITIONAL_PUNCH
    #ende
    me your inputs
     > Dr. Beyer,
     > Does ADDITIONAL_PUNCH punch user defined kinetics also? It
    doesn't seem
     > to punch KIN("urea_degradation") for me.
     > Thank you for your kind reply.
     > Sincerely,
     > On Wednesday, April 15, 2015 at 2:34:03 PM UTC+5:30, cb wrote:
     > Hi Sumana,
     > you can punch any quantity from Phreeqc to OGS by adding the
    following
     > commands to your *.pqc file:
     > The new Keywords
     > ADDITIONAL_OUTPUT
     > CO3-2 # comp
     > HCO3- # comp
     > a_HCO3- # comp
     > #ende
     > ADDITIONAL_PUNCH
     > PUNCH MOL("CO3-2")
     > PUNCH MOL("HCO3-")
     > PUNCH ACT("HCO3-")
     > #ende
     > now allow output of other quantities than primary species
     > concentrations
     > from PHREEQC. For these quantities (e.g. concentrations of
    secondary
     > species, activities, etc.), additional (immobile) components
    must be
     > defined in OGS to store the output values, i.e. for the above
    example
     > the components CO3-2, HCO3- and a_HCO3- have to be defnined.
    For each
     > component in the ADDITIONAL_OUTPUT list a corresponding
     > ADDITIONAL_PUNCH
     > statement must be provided, which invokes output of the
    requested
     > quantity from PHREEQC by means of the USER_PUNCH keyword. In the
     > example, additional output are concentrations of CO3-2 and HCO3-
     > complexes as well as the activity of the latter.
     > This was introduced in v5.5.0
     > Cheers, Christof
     > Am 15.04.2015 um 10:57 schrieb sumanab24:
     > > Hi,
     > > I have a question and I would be grateful if anyone can
    answer it.
     > > I have a kinetic equation for urea degradation (trial_ogs3
    attached
     > > file). When I run it using standalone phreeqC, I get the
    punched
     > values
     > > for both tot("Urea") and kin("urea_degradation") (Please
    refer to
     > the
     > > output file phout_sel).
     > > However, when I use the coupled version OGS-PhreeqC (pds.pqc
     > attached
     > > file) for the same phreeqC input file, only tot("Urea") is
    getting
     > > punched in the output file (phout_sel(1)) and
     > kin("urea_degradation") is
     > > not getting punched. I want this to get punched in phout_sel
     > file. What
     > > should I do? (I do not have any phase description for this
     > kinetic equation)
     > > I have added both Urea and urea_degradation as a component in
     > .mcp file.
     > > Thank you for you kind help in advance.
     > > Sincerely,
     > > Sumana Bhattacharya
     > > You received this message because you are subscribed to
    the Google
     > > Groups "ogs-users" group.
     > > To unsubscribe from this group and stop receiving emails
    from it,
     > send
     > > an email to ogs-users+...@googlegroups.com <javascript:>
     > > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
     > > For more options, visit https://groups.google.com/d/optout
     > <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;&gt;\.
     > _______________________________________
     > Dr. Christof Beyer
     > Institute of Geosciences
     > Geohydromodelling
     > Christian-Albrechts-University Kiel
     > Ludewig-Meyn-Str. 10
     > 24118 Kiel
     > Germany
     > phone: +49(0)431-8803172
     > fax: +49(0)431-8807606
     > mobile: +49(0)176-24297908
     > email: christo...@gpi.uni-kiel.de <javascript:>
     > home: http://www.ifg.uni-kiel.de/
    Dr. Christof Beyer
    Geohydromodelling
    24118 Kiel
    Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dr. Beyer,
Yes, it does. Thank you so much. Sorry I was not clear about the usage of #comp.
Thank you so much for the help.
Sincerely,
Sumana Bhattacharya
On Wednesday, April 15, 2015 at 6:20:03 PM UTC+5:30, cb wrote:
Hi Sumana,
“# comp”
ADDITIONAL_OUTPUT
This will specify for ogs that “Urea_degradation” is the name of a
Christof
Am 15.04.2015 um
Dr. Beyer,
Sincerely,
Sumana Bhattacharya
ADDITIONAL_OUTPUT
#ende
ADDITIONAL_PUNCH
#ende
me your inputs
 > Dr. Beyer,
doesn't seem
 > Sincerely,
 > Sumana Bhattacharya
 >     Hi Sumana,
following
 >           The new Keywords
 >     ADDITIONAL_OUTPUT
 >           CO3-2 # comp
 >           HCO3- # comp
 >           a_HCO3- # comp
 >     #ende
 >     ADDITIONAL_PUNCH
 >           PUNCH MOL("CO3-2")
 >           PUNCH MOL("HCO3-")
 >           PUNCH ACT("HCO3-")
 >     #ende
 >     concentrations
secondary
must be
example
For each
 >     ADDITIONAL_PUNCH
requested
 >     Cheers, Christof
 >      > Hi,
answer it.
attached
punched
 >     values
refer to
 >     the
 >     attached
getting
 >     file. What
 >     kinetic equation)
 >     .mcp file.
 >      > Sincerely,
 >      > Sumana Bhattacharya
the Google
from it,
 >     send
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>.
 >     Dr. Christof Beyer
 >     Geohydromodelling
 >     24118 Kiel
 >     Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
your welcome, christof
Am 15.04.2015 um 15:47 schrieb sumanab24:
Dr. Beyer,
of #comp.
Sincerely,
Sumana Bhattacharya
    Hi Sumana,
    "# comp"
    ADDITIONAL_OUTPUT
    Christof
    Am 15.04.2015 um > > > > 12:46 schrieb sumanab24:
     > Dr. Beyer,
     > Please find attached my input files. I am sorry that these are for
     > Windows 64 bit OS (please rename the file pds.msp.txt to pds.msp).
     > Thank you very much for your kind help.
     > Sincerely,
     > On Wednesday, April 15, 2015 at 3:52:29 PM UTC+5:30, cb wrote:
     > Hi,
     > I guess so. It should punch any variable or parameter phreeqc
    can write
     > in the selected output file. You need both statements;
     > ADDITIONAL_OUTPUT
     > #ende
     > ADDITIONAL_PUNCH
     > #ende
     > I have attached an example pqc file for you
     > (benchmarks\C\Engesgaard\Additional_pqc_output). If you
    cannot make
     > OGS-Phreeqc give you the data, I can check what's wrong if
    you provide
     > me your inputs
     > Best regards, Christof
     > Am 15.04.2015 um 12:06 schrieb sumanab24:
     > > Dr. Beyer,
     > > Does ADDITIONAL_PUNCH punch user defined kinetics also? It
     > doesn't seem
     > > to punch KIN("urea_degradation") for me.
     > > Thank you for your kind reply.
     > > Sincerely,
     > > On Wednesday, April 15, 2015 at 2:34:03 PM UTC+5:30, cb > wrote:
     > > Hi Sumana,
     > > you can punch any quantity from Phreeqc to OGS by
    adding the
     > following
     > > commands to your *.pqc file:
     > > The new Keywords
     > > ADDITIONAL_OUTPUT
     > > CO3-2 # comp
     > > HCO3- # comp
     > > a_HCO3- # comp
     > > #ende
     > > ADDITIONAL_PUNCH
     > > PUNCH MOL("CO3-2")
     > > PUNCH MOL("HCO3-")
     > > PUNCH ACT("HCO3-")
     > > #ende
     > > now allow output of other quantities than primary species
     > > concentrations
     > > from PHREEQC. For these quantities (e.g.
    concentrations of
     > secondary
     > > species, activities, etc.), additional (immobile)
    components
     > must be
     > > defined in OGS to store the output values, i.e. for
    the above
     > example
     > > the components CO3-2, HCO3- and a_HCO3- have to be
    defnined.
     > For each
     > > component in the ADDITIONAL_OUTPUT list a corresponding
     > > statement must be provided, which invokes output of the
     > requested
     > > quantity from PHREEQC by means of the USER_PUNCH
    keyword. In the
     > > example, additional output are concentrations of CO3-2
    and HCO3-
     > > complexes as well as the activity of the latter.
     > > This was introduced in v5.5.0
     > > Cheers, Christof
     > > Am 15.04.2015 um 10:57 schrieb sumanab24:
     > > > Hi,
     > > > I have a question and I would be grateful if anyone
    can
     > answer it.
     > > > I have a kinetic equation for urea degradation
    (trial_ogs3
     > attached
     > > > file). When I run it using standalone phreeqC, I
    get the
     > punched
     > > values
     > > > for both tot("Urea") and kin("urea_degradation")
    (Please
     > refer to
     > > the
     > > > output file phout_sel).
     > > > However, when I use the coupled version OGS-PhreeqC
    (pds.pqc
     > > attached
     > > > file) for the same phreeqC input file, only
    tot("Urea") is
     > getting
     > > > punched in the output file (phout_sel(1)) and
     > > kin("urea_degradation") is
     > > > not getting punched. I want this to get punched in
    phout_sel
     > > file. What
     > > > should I do? (I do not have any phase description
    for this
     > > kinetic equation)
     > > > I have added both Urea and urea_degradation as a
    component in
     > > .mcp file.
     > > > Thank you for you kind help in advance.
     > > > Sincerely,
     > > > Sumana Bhattacharya
     > > > You received this message because you are
    subscribed to
     > the Google
     > > > Groups "ogs-users" group.
     > > > To unsubscribe from this group and stop receiving
    emails
     > from it,
     > > send
     > > > an email to ogs-users+...@googlegroups.com
    <javascript:>
     > > > <mailto:ogs-users+...@googlegroups.com <javascript:>>.
     > > > For more options, visit
     > > <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;&gt;&gt;\.
     > > _______________________________________
     > > Dr. Christof Beyer
     > > Institute of Geosciences
     > > Geohydromodelling
     > > Christian-Albrechts-University Kiel
     > > Ludewig-Meyn-Str. 10
     > > 24118 Kiel
     > > Germany
     > > phone: +49(0)431-8803172
     > > fax: +49(0)431-8807606
     > > mobile: +49(0)176-24297908
     > > email: christo...@gpi.uni-kiel.de <javascript:>
     > > home: http://www.ifg.uni-kiel.de/
     > Geohydromodelling
     > 24118 Kiel
     > Germany
    Dr. Christof Beyer
    Geohydromodelling
    24118 Kiel
    Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dear Dr. Beyer,
I am facing an issue with this problem which I did not notice earlier.
Please find my model in the attached zip file. Here in the output file phout_sel.txt I can see that the punched values of tot(‘Urea’) and KIN(“Urea_degradation”) are basically the same. KIN(‘Urea_degradation’) is punched one node ahead of tot(‘Urea’).
But when I run the same PhreeqC file (attached), I get the attached phout_sel.txt file where these quantities are different. One is decreasing (being depleted) and another is increasing (being produced).
Would you please help me to find out where I am mistaking?
Thank you so much for your help.
Sincerely,
Sumana Bhattacharya
Urea_degradation.zip (1.18 MB)
phout_sel.dat (936 Bytes)
Dr. Beyer,
of #comp.
Sincerely,
Sumana Bhattacharya
Hi Sumana,
"# comp"
ADDITIONAL_OUTPUT
Christof
Am 15.04.2015 um > > > > > > > >     12:46 schrieb sumanab24:
 > Dr. Beyer,
 > Sincerely,
 > Sumana Bhattacharya
 >     Hi,
can write
 >     ADDITIONAL_OUTPUT
 >     #ende
 >     ADDITIONAL_PUNCH
 >     #ende
cannot make
you provide
 >     me your inputs
 >      > Dr. Beyer,
 >     doesn't seem
 >      > Sincerely,
 >      > Sumana Bhattacharya
 >      > On Wednesday, April 15, 2015 at 2:34:03 PM UTC+5:30, cb > >     wrote:
 >      >     Hi Sumana,
adding the
 >     following
 >      >           The new Keywords
 >      >     ADDITIONAL_OUTPUT
 >      >           CO3-2 # comp
 >      >           HCO3- # comp
 >      >           a_HCO3- # comp
 >      >     #ende
 >      >     ADDITIONAL_PUNCH
 >      >           PUNCH MOL("CO3-2")
 >      >           PUNCH MOL("HCO3-")
 >      >           PUNCH ACT("HCO3-")
 >      >     #ende
 >      >     concentrations
concentrations of
 >     secondary
components
 >     must be
the above
 >     example
defnined.
 >     For each
 >      >     ADDITIONAL_PUNCH
 >     requested
keyword. In the
and HCO3-
 >      >     Cheers, Christof
 >      >      > Hi,
can
 >     answer it.
(trial_ogs3
 >     attached
get the
 >     punched
 >      >     values
(Please
 >     refer to
 >      >     the
(pds.pqc
 >      >     attached
tot("Urea") is
 >     getting
phout_sel
 >      >     file. What
for this
 >      >     kinetic equation)
component in
 >      >     .mcp file.
 >      >      > Sincerely,
 >      >      > Sumana Bhattacharya
subscribed to
 >     the Google
emails
 >     from it,
 >      >     send
<javascript:>
[https://groups.google.com/d/optout](https://groups.google.com/d/optout) <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>>.
 >      >     Dr. Christof Beyer
 >      >     Geohydromodelling
 >      >     24118 Kiel
 >      >     Germany
 >     Dr. Christof Beyer
 >     Geohydromodelling
 >     24118 Kiel
 >     Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dear Dr. Beyer,
Thanks for the workaround. It seems I forgot to write ‘# comp’ (there is a space between # and comp). The workaround is as follows:
KINETICS
-formula Urea 1
-m 0
-steps 10000 day in 10
#ende
Wherever you define a solution, kinetic, equilibrium etc. species in the *.pqc file, you must identify for OGS the line with the species / component name, otherwise ogs will not be able to identify this line as the component name of a mass transport process but interpret it as some other phreeqc keyword. The line will be printed to the phinp.dat file, but the connection to the ogs data structure of the process for storing the concentration data returned by phreeqc will not be made.
for the same reasons “# comp” also needs to be defined for ADDITIONAL_OUTPUT quantities.
Thanks,
Sincerely,
Sumana Bhattacharya
On Wednesday, April 29, 2015 at 12:28:27 PM UTC+5:30, sumanab24 wrote:
Dear Dr. Beyer,
Sincerely,
Sumana Bhattacharya
Dr. Beyer,
of #comp.
Sincerely,
Sumana Bhattacharya
Hi Sumana,
"# comp"
ADDITIONAL_OUTPUT
Christof
Am 15.04.2015 um > > > > > > > > > > > >     12:46 schrieb sumanab24:
 > Dr. Beyer,
 > Sincerely,
 > Sumana Bhattacharya
 >     Hi,
can write
 >     ADDITIONAL_OUTPUT
 >     #ende
 >     ADDITIONAL_PUNCH
 >     #ende
cannot make
you provide
 >     me your inputs
 >      > Dr. Beyer,
 >     doesn't seem
 >      > Sincerely,
 >      > Sumana Bhattacharya
 >      > On Wednesday, April 15, 2015 at 2:34:03 PM UTC+5:30, cb > > >     wrote:
 >      >     Hi Sumana,
adding the
 >     following
 >      >           The new Keywords
 >      >     ADDITIONAL_OUTPUT
 >      >           CO3-2 # comp
 >      >           HCO3- # comp
 >      >           a_HCO3- # comp
 >      >     #ende
 >      >     ADDITIONAL_PUNCH
 >      >           PUNCH MOL("CO3-2")
 >      >           PUNCH MOL("HCO3-")
 >      >           PUNCH ACT("HCO3-")
 >      >     #ende
 >      >     concentrations
concentrations of
 >     secondary
components
 >     must be
the above
 >     example
defnined.
 >     For each
 >      >     ADDITIONAL_PUNCH
 >     requested
keyword. In the
and HCO3-
 >      >     Cheers, Christof
 >      >      > Hi,
can
 >     answer it.
(trial_ogs3
 >     attached
get the
 >     punched
 >      >     values
(Please
 >     refer to
 >      >     the
(pds.pqc
 >      >     attached
tot("Urea") is
 >     getting
phout_sel
 >      >     file. What
for this
 >      >     kinetic equation)
component in
 >      >     .mcp file.
 >      >      > Sincerely,
 >      >      > Sumana Bhattacharya
subscribed to
 >     the Google
emails
 >     from it,
 >      >     send
<javascript:>
 >      >     Dr. Christof Beyer
 >      >     Geohydromodelling
 >      >     24118 Kiel
 >      >     Germany
 >     Dr. Christof Beyer
 >     Geohydromodelling
 >     24118 Kiel
 >     Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
Dr. Christof Beyer
Geohydromodelling
24118 Kiel
Germany
