Metis + integration points + petsc
Dear ogs-Team,
we want to run a (restart) simulation using openmpi + petsc. The restart mesh contains integration points. We got the following warning:
“warning: Could not open file ‘Mesh_physical_group_Boundary_Front_canister_partitioned_integration_point_properties_cfg48.bin’.
You can ignore this warning if the mesh does not contain integration_point-wise property data.”
Therefore the question is if we can run such a configuration? Thanks for the support.
Carlos
Hi Carlos,
usually integration point data is read from the bulk mesh only, and not necessary in boundary meshes. Since the warning mentions a boundary mesh everything should be OK.
Hi Christoph,
thanks for the answer.
Cheers
Carlos
