Modelling with OGS6 - HeatConduction
Dear Ladies and Gentlemen,
In the last few days I have been working on the simulation for HeatConduction and I wanted to create my own simulation model. But now I have the following problem.
Since I am still relatively new, I unfortunately have no clues. Could you help me here? I have also added the files.
Benzersiz İndirme Bağlantısı | WeTransfer
Yours sincerely,
Kiratli
Dear Kiratli,
from the warning message one can read that the mesh contains 6 different layers of material / 6 different porous media. For each of these material layers OpenGeoSys needs a material definition. OpenGeoSys can only find a definition for one material / porous medium in the project file. This can lead to problems in the simulation. For this reason the warning is written out. I suspect that the error message below the warning is such a problem.
In order to solve the issue you could add 5 additional material/medium definitions in the project file. These additional definitions do not have to be different. The easiest way is to add ids to the attribute id of the medium tag:
<media>
    <medium id="0,1,2,3,4,5">
</media>
Tom
Dear Fischer,
Thank you for your effort. Now the simulation works without a warning.
but when the problem was solved, i encountered a new problem. in my simulation i want to simulate heat transport in a 3d model. For this I have defined a Dirichlet condition on the surface and a Neumann condition in the subsurface. Unfortunately, this does not work as desired. Is it possible to take a look at this from your side?
Kind regards,
Kiratli
