Multicore simulations
I am currently working with ThermoRichardMechanics process and I would like to speed up my simulations using a multi-core machine. I was checking the documentation and it says I could build my configuration with PETS and MPI, which I did. It also says that I need to have structured mesh and create partitions, which I also did, but this changed my initial mesh (which I didn’t want). Moreover, when I tried to run it, the model failed and showed me this message (I also tried to run the model without mpi configuration and it worked):
So my questions are:
  • Is there any other way to use the multi-cores of my computer for the simulations ?
  • Are the number of partitions related to the structured mesh?
  • Which solver should I use for mpi? Should I changed what I had before? I was using this :
* <nonlinear_solvers>
        <nonlinear_solver>
            <name>basic_newton</name>
            <type>Newton</type>
            <max_iter>100</max_iter>
        </nonlinear_solver>
    </nonlinear_solvers>
    <linear_solvers>
        <linear_solver>
            <eigen>
                <solver_type>BiCGSTAB</solver_type>
                <precon_type>DIAGONAL</precon_type>  <!--ILUT is also possible -->
                <max_iteration_step>10000</max_iteration_step>  <!-- 10000 is a default value -->
                <error_tolerance>1e-16</error_tolerance>     <!-- 1e-16 is a default value -->
                <scaling>1</scaling>
            </eigen>
            <petsc>
                <parameters>-ksp_type tfqmr
                    -pc_type jacobi
                    -ksp_rtol 1.e-10 -ksp_atol 1.e-7
                    -ksp_max_it 4000
                </parameters>
            </petsc>
        </linear_solver>
  • if you have any other suggestion/recommendation, feel free :slight_smile:
Thanks for your help,
Maria
Dear Mario Pico,
Instead of PETSc, you can use the PardisoLU eigen solver, and by specifying the number of cores for your analyses, you can benefit from parallel computing, which will help parallelize the assembly process of your problem. For more information please go through the following link: OpenGeoSys 6.5.0
Please note that for configuring and compiling the OGS, you have to use the following command:
cmake --preset=release -DOGS_USE_MKL=ON -DOGS_EIGEN_PARALLEL_BACKEND=OpenMP
Mehran
Dear Mehran,
Thank you for your suggestion. I have already compiled the program using
“cmake --preset=release -DOGS_USE_MKL=ON -DOGS_EIGEN_PARALLEL_BACKEND=OpenMP”
However, when I try to run the simulations with PardisoLU, I get the following error:
I have been checking some previous posts with similar problems, but I don’t really understand what I should do.
Also, do you know exactly where do I have to specify the number of cores that I would like to use?
Thanks for your help :slight_smile:
Hi Maria,
Did you set BUILD_SHARED_LIBS ON during the configuration of the OGS? You can easily use OGS_ASM_THREADS= “number of cores” to parallelize your simulation.
Mehran
Hi Maria,
since the direct linear solver fails using more threads won’t help.
I’d assume the assembled Jacobian is singular. This could result from a zero or wrong stiffness (i.e., a problem with the solid material model) or from completely incompressible condition, such that the system cannot react properly to external forces (could be a problem with the Biot factor and solid and fluid compressibilities). There might be other reasons than these.
It might be worthwhile to check the assembled matrices. How to do this is very well documented at the usual place: https://gitlab.opengeosys.org/ogs/ogs/-/merge_requests/4546#features :wink:
Checking local matrices will be easier than global matrices.
Dear Christoph,
Thank you for your response. I will check the assembled matrices. Nevertheless, I feel the problem is related to the Paradiso solver, I have run this simulation before with BiCGSTAB and it was working alright. This was my solver configuration:
   <nonlinear_solvers>
        <nonlinear_solver>
            <type>Newton</type>
            <max_iter>50</max_iter>
        </nonlinear_solver>
    <linear_solvers>
        <linear_solver>
            <eigen>
            </eigen>
            <petsc>
                    -pc_type jacobi
                    -ksp_max_it 4000
                </parameters>
            </petsc>
        </linear_solver>
    </linear_solvers>
I also tried running a simpler simulation that was working with BICGSTAB and the same problem occurs. Maybe I am mistaken with something in the solver? This is how I set PardisoLU:
   <nonlinear_solvers>
        <nonlinear_solver>
            <type>Newton</type>
        </nonlinear_solver>
    <linear_solvers>
        <linear_solver>
            <eigen>
                <solver_type>PardisoLU</solver_type>
                <error_tolerance>1e-10</error_tolerance>
            </eigen>
        </linear_solver>
    </linear_solvers>
I would really appreciate your help :slight_smile:
María
I added this: BUILD_SHARED_LIBS ON and rebuild it and now it runs :slight_smile:.
Thank youuu!!!
I have now another question regarding the same topic. Is there anything else I need to run the program using the several cores?
I used the following preset for building the program:
      "name": "debug-mfront-mkl-openmp-new",
      "inherits": [
         "debug"
      "cacheVariables": {
        "OGS_USE_MKL": "ON",
        "OGS_EIGEN_PARALLEL_BACKEND": "OpenMP",
        "BUILD_SHARED_LIBS": "ON",
        "OGS_USE_MFRONT": "ON",
        "OGS_ASM_THREADS": "16"
but when I check in the computer system, I can see that only one core is used:
Maria
The presets are only for the build. You need to set OGS_ASM_THREADS in advance to the execution or in the .bashrc/.zshrc.
There is also OMP_NUM_THREADS controling the number of cores for Pardiso. However, this variable is usually already >1 if not set.
