Dear OGS user and developer. A new GINA Version is on the WebSVN
https://svn.ufz.de/svn/ogs/branches/GINA_OGS
if you have no access to the WebSVN you can download the program from this link:
https://teambeam.bgr.de/my/?m=drive#!folder-68
best regards
Dear All,
We announce a new version:
OpenGeoSys 5.5.4 (WW/NW/LB) - 27.06.2014
The version includes
1 Rewritten member functions of class matrix_class that gives better performance in the local assembly computation. With the changes, the computation time for the problem using large local matrix (e.g deformation problems) becomes shorter than the previous versions.
2 Parallel binary I/O for parallel computing with PETSc. With the changes, partmesh outputs binary files by default if option '-asci' is not used. (How to use this binary IO, please refer to the updated page: https://svn.ufz.de/ogs/wiki/PETScPage)
3 Parallelization of the pressure saturation scheme (PS_GLOBAL) with PETSc, and a new benchmark for which is added.
4 OGS_FEM_BRNS now requires BLAS and LAPACK libraries during compilation under UNIX
5 Added MKL_DIR option in CMake to specify a root dir of MKL.
6 Reactivated benchmkars configured for OGS_FEM_LIS and OGS_FEM_MKL.
7 Some other bug fixings in point search on surfaces, PS_GLOBAL, VTK output, FEFLOW import, etc
This is also a first attempt to maintain OGS5 development by using github (https://github.com/envinf/ogs5-trunk/issues/3#issuecomment-42513384). With this way, changes in the source code are committed to forks of OGS5 github repository (https://github.com/envinf/ogs5-trunk.git), reviewed for merging (important but it was missing before), merged to OGS5 github repository and finally committed to the svn repository. Thanks Nori and Lars for transplanting the svn repository to the git repository.
Wenqing, Norihiro, Lars
WOW, this version sounds very integrated with several killing features that I should keep an eye on. Great job, guys. Keep up the good work.
Chan-Hee
On Fri, Jun 27, 2014 at 9:59 PM, Wenqing Wang wenqing.wang@ufz.de wrote:
Dear All,
2 Parallel binary I/O for parallel computing with PETSc. With the changes, partmesh outputs binary files by default if option ‘-asci’ is not used. (How to use this binary IO, please refer to the updated page: https://svn.ufz.de/ogs/wiki/PETScPage)
I tried to extract a fresh copy of OGS5 on the cray ...It worked a while
ago, but with svn I get now the following error:
svn co georg/SOFT> svn co https://svn.ufz.de/svn/ogs/trunk
svn: OPTIONS of 'https://svn.ufz.de/svn/ogs/trunk': SSL negotiation
failed: SSL error: unexpected message (https://svn.ufz.de)
Does someone have an idea if this is related to the server side or maybe
to the client side?
Then I got the idea to use the "new" git repository for ogs5:
georg/SOFT> git clone https://github.com/envinf/ogs5-trunk.git sources
Cloning into 'sources'...
error: error:0D0C50A1:asn1 encoding routines:ASN1_item_verify:unknown
message digest algorithm while accessing
https://github.com/envinf/ogs5-trunk.git/info/refs
fatal: HTTP request failed
and next try replacing https with git:
georg/SOFT> git clone git://github.com/envinf/ogs5-trunk.git sources
fatal: remote error:
Repository not found.
Any idea what I have to do? Is the repository private and not for public
or member access?
Only for your information, git works, as I get ogs6:
georg/SOFT> git clone git://github.com/ufz/ogs.git sources
remote: Reusing existing pack: 25064, done.
remote: Total 25064 (delta 0), reused 0 (delta 0)
Receiving objects: 100% (25064/25064), 6.15 MiB | 1.65 MiB/s, done.
Resolving deltas: 100% (18386/18386), done.
thanks, Georg
On 06/27/2014 02:59 PM, Wenqing Wang wrote:
Dear All,
github
repository.
Phone: +41-56-3104743 * Email: georg.kosakowski@psi.ch
homepage: http://www.psi.ch/les/georg-kosakowski
Hi Georg,
If I remember it correctly, a SSH key of the server was changed some time ago when a critical security issue was found in OpenSSL library. You may need to reset SSH setting to connect the server.
The repository on GitHub is private one and only our department members cab access it at the moment.
Nori
On 07/02/2014 10:19 AM, Georg Kosakowski wrote:
to the client side?
or member access?
thanks, Georg
Dear All,
github
repository.
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
Telefon +49 341 235 1806
finally I managed to find a workaround for one of the access methods.
On the cray git is linked to a "very old" OpenSSL version. In order to
access the git repository via https one can do this under linux:
env GIT_SSL_NO_VERIFY=true git clone
https://github.com/envinf/ogs5-trunk.git ogs5
Greetings, Georg
On 07/02/2014 11:22 AM, Norihiro Watanabe wrote:
Hi Georg,
Nori
to the client side?
or member access?
thanks, Georg
Dear All,
github
repository.
Thanks Nori. I noticed your change made in FindMKL.cmake some weeks ago. Better than the previous. With that change considered, I could compile OGS 5.5.4 with MKL using intel C++ compiler no problem. The compilation option that I used is following. Just for the tips who may be interested.
cmake /home/nbeyond/svn/ogs/trunk/sources -DOGS_FEM_MKL=ON -DPARALLEL_USE_OPENMP=ON -DCMAKE_CXX_COMPILER=icpc -DCMAKE_C_COMPILER=icc -DMKL_DIR=/opt/intel/mkl
Note that MKL_DIR should be your MKL root directory. Other than that, I think it’s pretty straight forward. Once again, with multiphase flow module and MKL simultaneously live, I am on OGS 5.5.4.
Chan-Hee Park, Ph.D.
Phone: +82 42 868 3502
Fax: +82 42 868 3358
Geothermal Resources Team
Korea Institute of Geoscience and Mineral Resources (KIGAM)
124 Gwahang-no, Yuseong-gu, Daejeon 305-350, KOREA
On Thu, Jul 3, 2014 at 3:36 PM, Georg Kosakowski georg.kosakowski@psi.ch wrote:
On the cray git is linked to a “very old” OpenSSL version. In order to
Greetings, Georg
Hi Georg,
Nori
I tried to extract a fresh copy of OGS5 on the cray …It worked a while
svn: OPTIONS of ‘https://svn.ufz.de/svn/ogs/trunk’: SSL negotiation
to the client side?
Then I got the idea to use the “new” git repository for ogs5:
Cloning into ‘sources’…
or member access?
thanks, Georg
Dear All,
github
repository.
Dear GINA_OGS Team,
I am a PhD student at the University of Birmingham please kindly would you help me with the following:
- How can I get a tutorial of the GINA as a guide how to apply the THM coupled processes using the GINA only (Not OGS)?
This is very important as long as the with the GINA I can prescribe the Fracture within the HDR geothermal reservoir.
Please, can you provide me with the steps that I need follow to find the distance of the temperature Profile from the injection pressure using OGS? I can find the curves and its temperature in the results but without data (the distance of each curve (0-9) from the injection well).
would you please help me to know how to put different permeability values for a reservoir?
(more than one permeability data input in different length and depth at the same time).
Thank you in advance,
Kind regards,
Maleaha Samin,
PhD student
United Kingdom
MYS172@bham.ac.uk
best regards
Herbert Kunz
Geologisch-geotechnische Erkundung
BGR Bundesanstalt für Geowissenschaften und Rohstoffe
GEOZENTRUM HANNOVER
Stilleweg 2
30 659 Hannover
Tel.: 0511 - 643 2419
www.geozentrum-hannover.de www.bgr.bund.de
