OGS newbie here.
Trying to install using pip
pip install --index-url Links for ogs ogs
Get the following errors:
ERROR: Could not find a version that satisfies the requirement ogs (from versions: none)
ERROR: No matching distribution found for ogs
Using Python 3.9.12 (MacOS Catalina V10.15.7)
Any pointers appreciated - Thanks
Sorry - this should have had:
" pip install --index-url Links for ogs ogs "
https link replaced here with “Links for ogs”
mmm…not sure how to handle this - keeps converting part of string to a link.
Used the pip instruction as per Introduction
even tried this:
pip install ogs
Think I am missing something…
Upgraded pip to pip-23.0.1 Same error messages.
bilke
#6
The pip packages are available only for macOS Monterey (version 12).
ok…thanks…that probably explains things.
Is there an alternative installation route ? (for Catalina).
bilke
#8
Unfortunately not. You can try to build it yourself but that’s a pretty involved process… See the developer docs:
If you just want to play a bit with OGS you can also try to use it on BinderHub:
Thank you. Bit surprised that only Mac folk using Monterey are running OGS. Wil try Binder Hub…
Is someone going to build an OGS package for installation on MacOS Ventura ?
