OGS5 and PETSc
Dear OGS developers,
although OGS5 is at the end of its development (or am I wrong?) may you update the page
https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2
adding the information that to compile with PETSc not only the OGS_CONFIG must be changed, but also the OGS_LSOLVER (see https://github.com/ufz/ogs5/pull/18 ) ?
It is a trivial problem. But only after you solve it.
Another question: what is the latest supported version of PETSc by OGS 5.7.1?
Thanks.
Luca Urpi
+41446338372
Swiss Seismological Service
ETH Zürich, NO H 62
Sonneggstrasse 5
8092 Zürich
Hi Luca,
Setting -DOGS_CONFIG=PESC in CMake should be enough. OGS_LSOLVER is automatically set during cmake.
Regarding the PETSc version, I think current OGS5 supports till 3.5.
(Wenqing, please correct me if I'm wrong).
Nori
adding the information that to compile with PETSc not only the OGS_CONFIG must be changed, but also the OGS_LSOLVER (see Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub ) ?
Thanks.
Luca Urpi
+41446338372
ETH Zürich, NO H 62
Sonneggstrasse 5
8092 Zürich
You received this message because you are subscribed to the Google Groups "ogs-devs" group.
I tried again, at least on the machine I am using (Fedora 25, cmake 3.8.0), it does not set automatically with cmake or with cmake-gui (also, it does not work with MPI).
2017-05-23 23:20 GMT+02:00 Norihiro Watanabe [email protected]:
Hi Luca,
(Wenqing, please correct me if I’m wrong).
Nori
Thanks.
Luca Urpi
+41446338372
ETH Zürich, NO H 62
Sonneggstrasse 5
8092 Zürich
You received this message because you are subscribed to the Google Groups “ogs-devs” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected] mailto:[email protected].
i see. it’s working on the test machine at ufz. i will check it later when i have time. thanks for reporting the problem.
n
From: [email protected] [email protected] on behalf of Luca Urpi [email protected]
Sent: Wednesday, May 24, 2017 6:41:05 PM
To: [email protected]
Subject: Re: OGS5 and PETSc
[email protected]:
Hi Luca,
Nori
Thanks.
Luca Urpi
+41446338372
ETH Zürich, NO H 62
Sonneggstrasse 5
8092 Zürich
sorry there was a typo. it should be -DOGS_CONFIG=PETC. I tested on my machine with the following command and it is also working here.
cmake ../sources/ -DOGS_CONFIG=PETSC -DPESC_DIR=/opt/petsc/petsc-3.5.4/ -DPETSC_ARCH=gcc-release
maybe you need to remove the build dir once and test it again.
n
2017-05-23 23:20 GMT+02:00 Norihiro Watanabe <[email protected] <mailto:[email protected]>>:
    Hi Luca,
    Nori
        <https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2&gt;
        <https://github.com/ufz/ogs5/pull/18&gt; ) ?
        by OGS 5.7.1?
        Thanks.
        Luca Urpi
        +41446338372 <tel:%2B41446338372>
        ETH Zürich, NO H 62
        Sonneggstrasse 5
        8092 Zürich
        -- You received this message because you are subscribed to the
        <mailto:ogs-devs%[email protected]>
        <mailto:ogs-devs%[email protected]>>.
        <https://groups.google.com/d/optout&gt;\.
    -- You received this message because you are subscribed to the Google
    <mailto:ogs-devs%[email protected]>.
Alright, yes the problem is with reusing the build dir.
If cmake is run for the first time, then it sets OGS_LSOLVER to the corresponding OGS_CONFIG: if no value is given it defaults to RF. Then if the same build folder is used afterwards, with different OGS_CONFIG, the OGS_LSOLVER needs to be set manually.
With cmake-gui, OGS_LSOLVER must be set manually, since it is set to RF with the first “configure”.
However, if OGS_LSOLVER is set manually to DEFAULT, then it is updated automatically with the right value according to OGS_CONFIG, running “configure” for the second time.
Maybe there is an error and OGS_LSOLVER should be set to DEFAULT by the first “configure”? I am not very practical with cmake definitions and set-up.
Thanks for your patience.
Luca
2017-05-26 0:11 GMT+02:00 Norihiro Watanabe [email protected]:
2017-05-23 23:20 GMT+02:00 Norihiro Watanabe <[email protected] mailto:[email protected]>:
Hi Luca,
Nori
    [https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2](https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2)
    <[https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2](https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2)>
    [https://github.com/ufz/ogs5/pull/18](https://github.com/ufz/ogs5/pull/18)
    <[https://github.com/ufz/ogs5/pull/18](https://github.com/ufz/ogs5/pull/18)> ) ?
    by OGS 5.7.1?
    Thanks.
    Luca Urpi
    ETH Zürich, NO H 62
    Sonneggstrasse 5
    8092 Zürich
    For more options, visit [https://groups.google.com/d/optout](https://groups.google.com/d/optout)
    <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>.
cmake …/sources/ -DOGS_CONFIG=PETSC -DPESC_DIR=/opt/petsc/petsc-3.5.4/ -DPETSC_ARCH=gcc-release
n
many thanks for reporting the details. The problem should be fixed in #81 (https://github.com/ufz/ogs5/pull/81\).
best,
nori
With cmake-gui, OGS_LSOLVER must be set manually, since it is set to RF with the first "configure".
However, if OGS_LSOLVER is set manually to DEFAULT, then it is updated automatically with the right value according to OGS_CONFIG, running "configure" for the second time.
Maybe there is an error and OGS_LSOLVER should be set to DEFAULT by the first "configure"? I am not very practical with cmake definitions and set-up.
Luca
2017-05-26 0:11 GMT+02:00 Norihiro Watanabe <[email protected] <mailto:[email protected]>>:
    n
        <[email protected]
        <mailto:[email protected]>>>:
             Hi Luca,
        OGS_LSOLVER is
        till 3.5.
             Nori
        wrong?)
        <https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2&gt;&gt;
        only the
                 <Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub
        <https://github.com/ufz/ogs5/pull/18&gt;&gt; ) ?
        of PETSc
                 by OGS 5.7.1?
                 Thanks.
                 Luca Urpi
        +41446338372 <tel:%2B41446338372> <tel:%2B41446338372>
                 ETH Zürich, NO H 62
                 Sonneggstrasse 5
                 8092 Zürich
        subscribed to the
        emails from
        [email protected]
        <mailto:ogs-devs%[email protected]>>>.
        <https://groups.google.com/d/optout&gt;&gt;\.
        to the Google
        from it,
Hello Nori,
I have followed your latest patch just merged on CentOS 7. The compilation works just fine with the configuration below. However, when I tried it with KueperProblem-PS benchmark, it works great with the following.
[nbeyond@cc KueperProblem-PS]$ mpirun -f mfile -np 3 $ogs_petsc kueper
My question from here is: How can I prepare kueper_partitioned_nodes_3.msh, kueper_partitioned_elems_3.msh, and kueper_partitioned_cfg3.msh? I guess those should come from
partmesh --ogs2metis kueper
mpmetis kueper.mesh
partmesh --metis2ogs -np 3 -n kueper
I do not see how to get the last one ( kueper_partitioned_cfg3.msh). I appreciate any help on this.
One more question, please. Would the latest ogs 5 with the patch work with HT problems on sequential mode if the configuration files are prepared just as I talked? This is extremely important because it is all about scale-up of applications to multi-million nodes. Thanks in advance.
#81 (https://github.com/ufz/ogs5/pull/81).
best,
nori
set-up.
Luca
<norihiro…@aist.go.jp mailto:[email protected]>:
n
    <[email protected]
         Hi Luca,
    OGS_LSOLVER is
    till 3.5.
         Nori
    wrong?)
    <[https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2](https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2)>>
    only the
    <[https://github.com/ufz/ogs5/pull/18](https://github.com/ufz/ogs5/pull/18)>> ) ?
    of PETSc
             by OGS 5.7.1?
             Thanks.
             Luca Urpi
             ETH Zürich, NO H 62
             Sonneggstrasse 5
             8092 Zürich
    subscribed to the
    emails from
    [email protected]
    <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>.
    to the Google
    from it,
Hello Nori,
    mpmetis kueper.mesh
I do not see how to get the last one ( *kueper_partitioned_cfg3.msh*). I appreciate any help on this.
Have you tested with the latest partmesh available from GitHub - ufz/mesh_partition? I think Wenqing has made some changes and it generates _cfg*.
What do you mean sequential mode? sequential coupling? HT processes should also work with petsc.
n
On 05/31/2017 02:45 PM, Chan-Hee Park wrote:
    #81 ([CMake] fix switching OGS_CONFIG by norihiro-w · Pull Request #81 · ufz/ogs5 · GitHub
    <https://github.com/ufz/ogs5/pull/81&gt;\).
    best,
    nori
     > Alright, yes the problem is with reusing the build dir.
     > If cmake is run for the first time, then it sets OGS_LSOLVER to the
     > corresponding OGS_CONFIG: if no value is given it defaults to RF.
    Then
     > if the same build folder is used afterwards, with different
    OGS_CONFIG,
     > the OGS_LSOLVER needs to be set manually.
     > With cmake-gui, OGS_LSOLVER must be set manually, since it is set
    to RF
     > with the first "configure".
     > However, if OGS_LSOLVER is set manually to DEFAULT, then it is
    updated
     > automatically with the right value according to OGS_CONFIG, running
     > "configure" for the second time.
     > Maybe there is an error and OGS_LSOLVER should be set to DEFAULT
    by the
     > first "configure"? I am not very practical with cmake definitions
    and
     > set-up.
     > Thanks for your patience.
     > Luca
     > 2017-05-26 0:11 GMT+02:00 Norihiro Watanabe
     > <norihiro...@aist.go.jp <javascript:>
    <mailto:norihiro...@aist.go.jp <javascript:>>>:
     > Hi,
     > sorry there was a typo. it should be -DOGS_CONFIG=PETC. I
    tested on
     > my machine with the following command and it is also working
    here.
     > cmake ../sources/ -DOGS_CONFIG=PETSC
     > -DPESC_DIR=/opt/petsc/petsc-3.5.4/ -DPETSC_ARCH=gcc-release
     > maybe you need to remove the build dir once and test it again.
     > n
     > On 05/24/2017 06:41 PM, Luca Urpi wrote:
     > I tried again, at least on the machine I am using (Fedora
    25,
     > cmake 3.8.0), it does not set automatically with cmake or
    with
     > cmake-gui (also, it does not work with MPI).
     > 2017-05-23 23:20 GMT+02:00 Norihiro Watanabe
     > <mailto:norihiro...@aist.go.jp <javascript:>>
     > <mailto:norihiro...@aist.go.jp <javascript:>>>>:
     > Hi Luca,
     > Setting -DOGS_CONFIG=PESC in CMake should be enough.
     > OGS_LSOLVER is
     > automatically set during cmake.
     > Regarding the PETSc version, I think current OGS5
    supports
     > till 3.5.
     > (Wenqing, please correct me if I'm wrong).
     > Best,
     > Nori
     > On 05/22/2017 11:25 PM, Luca Urpi wrote:
     > Dear OGS developers,
     > although OGS5 is at the end of its development
    (or am I
     > wrong?)
     > may you update the page
     > <https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2
    <https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2&gt;&gt;&gt;
     > adding the information that to compile with
    PETSc not
     > only the
     > OGS_CONFIG must be changed, but also the
    OGS_LSOLVER (see
     > Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub
     > <Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub
    <https://github.com/ufz/ogs5/pull/18&gt;&gt;&gt; ) ?
     > It is a trivial problem. But only after you
    solve it.
     > Another question: what is the latest supported
    version
     > of PETSc
     > by OGS 5.7.1?
     > Thanks.
     > Luca Urpi
     > +41446338372 <tel:%2B41446338372> <tel:%2B41446338372>
     > Swiss Seismological Service
     > ETH Zürich, NO H 62
     > Sonneggstrasse 5
     > 8092 Zürich
     > -- You received this message because you
    are
     > subscribed to the
     > Google Groups "ogs-devs" group.
     > To unsubscribe from this group and stop receiving
     > emails from
     > it, send an email to
     > ogs-devs+u...@googlegroups.com <javascript:>
     > <mailto:ogs-devs%[email protected]
    <javascript:>>
    <javascript:>
    <javascript:>>>
     > <mailto:ogs-devs+u...@googlegroups.com
    <javascript:>
    <javascript:>>
    <javascript:>
    <javascript:>>>>.
     > For more options, visit
     > https://groups.google.com/d/optout
     > <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;&gt;&gt;\.
     > -- You received this message because you are
    subscribed
     > to the Google
     > Groups "ogs-devs" group.
    emails
     > from it,
     > send an email to ogs-devs+u...@googlegroups.com
    <javascript:>
    <javascript:>>
    <javascript:>
    <javascript:>>>.
     > You received this message because you are subscribed to the
     > To unsubscribe from this group and stop receiving emails
    from
     > it, send an email to ogs-devs+u...@googlegroups.com
    <javascript:>
    <javascript:>>
     > <mailto:ogs-devs+u...@googlegroups.com <javascript:>
    <javascript:>>>.
    Google
     > To unsubscribe from this group and stop receiving emails from
    it,
     > send an email to ogs-devs+u...@googlegroups.com <javascript:>
     > <mailto:ogs-devs%[email protected] <javascript:>>.
     > For more options, visit https://groups.google.com/d/optout
     > You received this message because you are subscribed to the Google
     > To unsubscribe from this group and stop receiving emails from it,
    send
     > an email to ogs-devs+u...@googlegroups.com <javascript:>
     > <mailto:ogs-devs+u...@googlegroups.com <javascript:>>.
Thanks, Nori. It works with the new mesh_partition given by WW.
Now, another problem with PVD in the .out file. It doesn’t output .pvtu files to combine .vtu of each decomposed domain to have a whole domain. Does this need update Nori?
On Wednesday, May 31, 2017 at 2:54:41 PM UTC+9, Norihiro Watanabe wrote:
Hello Nori,
following.
mpmetis kueper.mesh
https://github.com/ufz/mesh_partition? I think Wenqing has made some
n
#81 ([https://github.com/ufz/ogs5/pull/81](https://github.com/ufz/ogs5/pull/81)
<[https://github.com/ufz/ogs5/pull/81](https://github.com/ufz/ogs5/pull/81)>).
best,
nori
Then
OGS_CONFIG,
to RF
updated
by the
and
 > set-up.
 > Luca
 > <[email protected] <javascript:>
<mailto:[email protected] <javascript:>>>:
 >     Hi,
tested on
here.
 >     n
25,
with
 >         <mailto:[email protected] <javascript:>>>>:
 >              Hi Luca,
 >         OGS_LSOLVER is
supports
 >         till 3.5.
 >              Best,
 >              Nori
(or am I
 >         wrong?)
<[https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2](https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2)>>>
PETSc not
 >         only the
OGS_LSOLVER (see
<[https://github.com/ufz/ogs5/pull/18](https://github.com/ufz/ogs5/pull/18)>>> ) ?
solve it.
version
 >         of PETSc
 >                  by OGS 5.7.1?
 >                  Thanks.
 >                  Luca Urpi
 >                  ETH Zürich, NO H 62
 >                  Sonneggstrasse 5
 >                  8092 Zürich
are
 >         subscribed to the
 >         emails from
<javascript:>>
<javascript:>
<javascript:>>>
<javascript:>
<javascript:>>
<javascript:>
<javascript:>>>>.
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>>.
subscribed
 >         to the Google
emails
 >         from it,
<javascript:>
<javascript:>>
<javascript:>
<javascript:>>>.
[https://groups.google.com/d/optout](https://groups.google.com/d/optout) <[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>
from
<javascript:>
<javascript:>>
<javascript:>>>.
Google
it,
 >     send an email to [email protected] <javascript:>
send
 > <mailto:[email protected] <javascript:>>.
I don't think PVTU output is supported in the official ogs5. you can use Wenqing's script
Now, another problem with PVD in the .out file. It doesn't output
.*pvtu* files to combine .*vtu* of each decomposed domain to have a
    > Hello Nori,
    > I have followed your latest patch just merged on CentOS 7. The
    > compilation works just fine with the configuration below. However,
    when
    > I tried it with KueperProblem-PS benchmark, it works great with the
    > following.
    > [nbeyond@cc KueperProblem-PS]$ mpirun -f mfile -np 3 $ogs_petsc
    kueper
    > My question from here is: How can I
    > prepare kueper_partitioned_nodes_3.msh,
    > and kueper_partitioned_cfg3.msh? I guess those should come from
    > partmesh --ogs2metis kueper
    > mpmetis kueper.mesh
    > partmesh --metis2ogs -np 3 -n kueper
    > I do not see how to get the last one (
    > appreciate any help on this.
    <https://github.com/ufz/mesh_partition&gt;? I think Wenqing has made some
    > One more question, please. Would the latest ogs 5 with the patch work
    > with HT problems on sequential mode if the configuration files are
    > prepared just as I talked? This is extremely important because it
    is all
    > about scale-up of applications to multi-million nodes. Thanks in
    advance.
    n
    > Best regards,
    > On Monday, May 29, 2017 at 7:28:03 AM UTC+9, Norihiro Watanabe wrote:
    > many thanks for reporting the details. The problem should be
    fixed in
    > #81 ([CMake] fix switching OGS_CONFIG by norihiro-w · Pull Request #81 · ufz/ogs5 · GitHub
    > <[CMake] fix switching OGS_CONFIG by norihiro-w · Pull Request #81 · ufz/ogs5 · GitHub
    <https://github.com/ufz/ogs5/pull/81&gt;&gt;\).
    > best,
    > nori
    > On 05/26/2017 08:39 PM, Luca Urpi wrote:
    > > Alright, yes the problem is with reusing the build dir.
    > > If cmake is run for the first time, then it sets
    OGS_LSOLVER to the
    > > corresponding OGS_CONFIG: if no value is given it defaults
    to RF.
    > Then
    > > if the same build folder is used afterwards, with different
    > OGS_CONFIG,
    > > the OGS_LSOLVER needs to be set manually.
    > > With cmake-gui, OGS_LSOLVER must be set manually, since it
    is set
    > to RF
    > > with the first "configure".
    > > However, if OGS_LSOLVER is set manually to DEFAULT, then it is
    > updated
    > > automatically with the right value according to OGS_CONFIG,
    running
    > > "configure" for the second time.
    > > Maybe there is an error and OGS_LSOLVER should be set to
    DEFAULT
    > by the
    > > first "configure"? I am not very practical with cmake
    definitions
    > and
    > > set-up.
    > > Thanks for your patience.
    > > Luca
    > > 2017-05-26 0:11 GMT+02:00 Norihiro Watanabe
    > > <norihiro...@aist.go.jp <javascript:>
    > <mailto:norihiro...@aist.go.jp <javascript:>>>:
    > > Hi,
    > > sorry there was a typo. it should be -DOGS_CONFIG=PETC. I
    > tested on
    > > my machine with the following command and it is also
    working
    > here.
    > > cmake ../sources/ -DOGS_CONFIG=PETSC
    > > -DPESC_DIR=/opt/petsc/petsc-3.5.4/
    > > maybe you need to remove the build dir once and test it
    again.
    > > n
    > > On 05/24/2017 06:41 PM, Luca Urpi wrote:
    > > I tried again, at least on the machine I am using
    (Fedora
    > 25,
    > > cmake 3.8.0), it does not set automatically with
    cmake or
    > with
    > > cmake-gui (also, it does not work with MPI).
    > > 2017-05-23 23:20 GMT+02:00 Norihiro Watanabe
    > > <mailto:norihiro...@aist.go.jp <javascript:>>
    > > <mailto:norihiro...@aist.go.jp <javascript:>>>>:
    > > Hi Luca,
    > > Setting -DOGS_CONFIG=PESC in CMake should be
    enough.
    > > OGS_LSOLVER is
    > > automatically set during cmake.
    > > Regarding the PETSc version, I think current OGS5
    > supports
    > > till 3.5.
    > > (Wenqing, please correct me if I'm wrong).
    > > Best,
    > > Nori
    > > On 05/22/2017 11:25 PM, Luca Urpi wrote:
    > > Dear OGS developers,
    > > although OGS5 is at the end of its
    development
    > (or am I
    > > wrong?)
    > > may you update the page
    <https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2&gt;&gt;&gt;&gt;
    > > adding the information that to compile with
    > PETSc not
    > > only the
    > > OGS_CONFIG must be changed, but also the
    > OGS_LSOLVER (see
    > > Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub
    > > <Decompose OGS_CONFIG by norihiro-w · Pull Request #18 · ufz/ogs5 · GitHub
    <https://github.com/ufz/ogs5/pull/18&gt;&gt;&gt;&gt; ) ?
    > > It is a trivial problem. But only after you
    > solve it.
    > > Another question: what is the latest
    supported
    > version
    > > of PETSc
    > > by OGS 5.7.1?
    > > Thanks.
    > > Luca Urpi
    > > +41446338372 <tel:%2B41446338372> <tel:%2B41446338372>
    > > Swiss Seismological Service
    > > ETH Zürich, NO H 62
    > > Sonneggstrasse 5
    > > 8092 Zürich
    > > -- You received this message
    because you
    > are
    > > subscribed to the
    > > Google Groups "ogs-devs" group.
    > > To unsubscribe from this group and stop
    receiving
    > > emails from
    > > it, send an email to
    > > ogs-devs+u...@googlegroups.com <javascript:>
    > > <mailto:ogs-devs%[email protected]
    <javascript:>
    > <javascript:>>
    > <javascript:>
    <javascript:>
    > <javascript:>>>
    > > <mailto:ogs-devs+u...@googlegroups.com
    > <javascript:>
    <javascript:>
    > <javascript:>>
    > <javascript:>
    <javascript:>
    > <javascript:>>>>.
    > > For more options, visit
    > > https://groups.google.com/d/optout
    > > <https://groups.google.com/d/optout
    <https://groups.google.com/d/optout&gt;&gt;&gt;&gt;\.
    > > -- You received this message because you are
    > subscribed
    > > to the Google
    > > Groups "ogs-devs" group.
    > > To unsubscribe from this group and stop receiving
    > emails
    > > from it,
    > > send an email to ogs-devs+u...@googlegroups.com
    > <javascript:>
    <javascript:>
    > <javascript:>>
    > <javascript:>
    <javascript:>
    > <javascript:>>>.
    > > You received this message because you are
    subscribed to the
    emails
    > from
    > > it, send an email to ogs-devs+u...@googlegroups.com
    > <javascript:>
    <javascript:>
    > <javascript:>>
    > > <mailto:ogs-devs+u...@googlegroups.com <javascript:>
    <javascript:>
    > <javascript:>>>.
    > > You received this message because you are subscribed to
    the
    > Google
    emails from
    > it,
    <javascript:>
    <javascript:> <javascript:>>.
    > > You received this message because you are subscribed to the
    Google
    > > To unsubscribe from this group and stop receiving emails
    from it,
    > send
    > > an email to ogs-devs+u...@googlegroups.com <javascript:>
    > > <mailto:ogs-devs+u...@googlegroups.com <javascript:>>.
    > > For more options, visit https://groups.google.com/d/optout
    send
渡邉 教弘(工博 Dr.-Ing.)
国立研究開発法人 産業技術総合研究所
再生可能エネルギー研究所(FREA)
再生可能エネルギー研究センター
地熱チーム 研究員
〒963-0298 福島県郡山市待池台二丁目2番9
TEL: 029-861-4463 (内222-44463)
FAX: 024-963-0828
E-MAIL: [email protected]
URL: http://www.aist.go.jp/fukushima/
I tried Wenqing’s script. Didn’t work with my example. Kueper-PcPnw-petsc. However, VTK outputs everything ok. Great work with petsc.
On Thursday, June 1, 2017 at 5:51:07 AM UTC+9, Norihiro Watanabe wrote:
I don’t think PVTU output is supported in the official ogs5. you can use
Wenqing’s script
https://github.com/wenqing/post_process_ogs5
> Hello Nori,
when
> following.
kueper
>     mpmetis kueper.mesh
[https://github.com/ufz/mesh_partition](https://github.com/ufz/mesh_partition)
<[https://github.com/ufz/mesh_partition](https://github.com/ufz/mesh_partition)>? I think Wenqing has made some
is all
advance.
n
> Best regards,
fixed in
<[https://github.com/ufz/ogs5/pull/81](https://github.com/ufz/ogs5/pull/81)>>).
>     best,
>     nori
OGS_LSOLVER to the
to RF.
>     Then
>     OGS_CONFIG,
is set
>     to RF
>     updated
running
DEFAULT
>     by the
definitions
>     and
>      > set-up.
>      > Luca
>      >     Hi,
>     tested on
working
>     here.
again.
>      >     n
(Fedora
>     25,
cmake or
>     with
>      >              Hi Luca,
enough.
>      >         OGS_LSOLVER is
>     supports
>      >         till 3.5.
>      >              Best,
>      >              Nori
development
>     (or am I
>      >         wrong?)
<[https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2](https://docs.opengeosys.org/docs/devguide5/getting-started/build-configuration#panel3-2)>>>>
>     PETSc not
>      >         only the
>     OGS_LSOLVER (see
<[https://github.com/ufz/ogs5/pull/18](https://github.com/ufz/ogs5/pull/18)>>>> ) ?
>     solve it.
supported
>     version
>      >         of PETSc
>      >                  by OGS 5.7.1?
>      >                  Thanks.
>      >                  Luca Urpi
>      >                  ETH Zürich, NO H 62
>      >                  Sonneggstrasse 5
>      >                  8092 Zürich
because you
>     are
>      >         subscribed to the
receiving
>      >         emails from
<javascript:>
>     <javascript:>>
>     <javascript:>
<javascript:>
>     <javascript:>>>
>     <javascript:>
<javascript:>
>     <javascript:>>
>     <javascript:>
<javascript:>
>     <javascript:>>>>.
<[https://groups.google.com/d/optout](https://groups.google.com/d/optout)>>>>.
>     subscribed
>      >         to the Google
>     emails
>      >         from it,
>     <javascript:>
<javascript:>
>     <javascript:>>
>     <javascript:>
<javascript:>
>     <javascript:>>>.
subscribed to the
emails
>     from
>     <javascript:>
<javascript:>
>     <javascript:>>
<javascript:>
>     <javascript:>>>.
the
>     Google
emails from
>     it,
<javascript:>
Google
from it,
>     send
send
渡邉 教弘(工博 Dr.-Ing.)
国立研究開発法人 産業技術総合研究所
再生可能エネルギー研究所(FREA)
再生可能エネルギー研究センター
地熱チーム 研究員
FAX: 024-963-0828
E-MAIL: norihiro…@aist.go.jp
