Dear Development team,
I would like to use OGS on MacOS however I ran into some problems.
I use MacOS Mojave with OGS2.6.0 (2019-04-30 built) for MacOS.
Firstly, following the instruction running the command for OGS in terminal I get the following feedback:
“Required argument missing: project-file” - this I try to fix by adding the following argument to set the project file path, but fail…as I am not able to set the path.
NOTE: “test.prj” acts as my project file name, whereas in the instruction it refer to BenchmarkName.prj. Should I create a black text file for this? Currently there is no “test.prj” file nor BenchmarkName.prj.
Terminal:
Theo$ /Users/Theo/Downloads/ogs-6.2.0-121-g483fce3c4-OSX-10.14-x64-de-utils/bin/ogs /Users/Theo/Downloads/ogs-6.2.0-121-g483fce3c4-OSX-10.14-x64-de-utils/bin/test.prj
info: This is OpenGeoSys-6 version 6.2.0-121-g483fce3c4.
info: OGS started on 2019-04-30 15:18:27+0200.
error: Error while parsing XML file `/Users/Theo/Downloads/ogs-6.2.0-121-g483fce3c4-OSX-10.14-x64-de-utils/bin/Test.prj' at line 0: cannot open file. at ConfigTreeUtil.cpp, line 66
info: OGS terminated on 2019-04-30 15:18:27+020
After this I tested Data Explorer.
By running Data Explorer I import a polygon into the Geometry frame, however, I notice only polylines and points. In a previous version of Data Explorer (OGS5) I can see “surface” as a polygon. In OGS6 I do not see any surface or polygon file. I imported a number of polygon files and none return with surface / polygon in Geometry frame. Is this a potential bug?
NOTE: I select Read Polyline/Surfaces for this.
Following this, I tried to to “Create Mesh from input data” using the imported shapefile, however, returned with the following error:
Execution of gmsh command returned non-zero status, 32256. (NOTE: I did install gmsh and specified directory in the settings.)
Running into these two problems I am stuck.
Hope to hear from you soon.
Theo
