OGSTools 0.3.0 released!
We are happy to announce the release of OGSTools 0.3.0!
Release notes
feflowlib
  • OGS compatible conversion of 2D meshes.
  • Conversion of hydro-thermal FEFLOW models.
  • Bug fix - removed bulk_node and element_ids after assignment.
  • Extended feflowlib to be able to convert user data from FEFLOW files. User data in the FEFLOW data can store data that are not necessary for the FEFLOW simulation.
logparser
meshlib
  • Function to compute differences of meshes.
    • The difference function from meshlib will now return one-to-one, pair-wise, or matrix difference depending on what input the user provides.
  • Function to aggregate all time steps in a MeshSeries given an aggregation function.
meshplotlib
  • Functionality and documentation for (mechanical) stress analyses.
  • Introduction of functionality to probe points on MeshSeries
  • Both, Custom figure and axes objects, can now be passed to plot function.
  • Examples are added for:
    • Custom figure axes.
    • XY labels with shared axes (Adding or not adding labels can be handled semi-automatically based on whether axes are shared).
    • Differences of meshes.
    • Limit plots.
  • Progress bars: for animation and convergence study evolution evaluation.
  • Label in format “property name / property unit” can be obtained from Property.
  • Small fix to how setting aspect ratio is handled.
  • Enable use of external fig and ax in plot functions and plotting different variables within one figure.
  • Reworked aspect ratios (with examples).
  • Interactive PyVista examples.
msh2vtu
Infrastructure & Development
  • Use latest release of OGS ogstools.opengeosys.org: 6.5.1.
  • Code quality report added.
  • Various changes for building OGSTools with GNU Guix.
breaking API-Changes
(from 0.2.0 to 0.3.0)
msh2vtu
  • rename parameter
  • argument defaults are now the same for both CLI and python interface
msh2vtu(
    rdcd --> reindex (Default changed from True to False)
    ogs --> keep_ids (Reverse meaning, new default of False is the same as ogs=True before)
propertylib
  • rename function
Property(__Call__  --> transform )
