OGSTools 0.8.0 released!
We are happy to announce the release of OGSTools 0.8.0!
OGSTools 0.8.0 Release Notes
Python 3.11-3.14
OGS 6.5.7
Breaking changes
API breaking changes
New Core Framework and Storage System
  • New unified framework: Introduced Model, Simulation, and Result classes
    that provide a complete workflow from setup to analysis. See the new
    plot_framework_short.py example for a quick overview.
  • Storage system: All major classes (Model, Meshes, MeshSeries, Project)
    now inherit from SaveBase and support:
    • Unified save() / from_folder() / from_id() interface
    • Automatic backup on overwrite (configurable via SaveBase.Backup)
    • Archive mode for creating self-contained copies
    • ID-based organization in user-defined storage paths
  • Simulation controllers:
    • Removed deprecated ogstools.simulation module
    • New SimulationController base class with OGSInteractiveController and
      OGSNativeController implementations
  • Log parsing: Added Log class for parsing and analyzing OGS log files with
    methods for convergence analysis and simulation status tracking
MeshSeries and Meshes
  • removed the Mesh class entirely, MeshSeries is now a Sequence of native
    pyvista.UnstructuredGrid’s.
  • MeshSeries.scale changes the calling object and returns it.
  • MeshSeries.read_interp → MeshSeries.mesh_interp
  • MeshSeries.probe → MeshSeries.probe_vals
  • MeshSeries.extract_probe → MeshSeries.probe
  • MeshSeries.aggregate_over_domain → MeshSeries.aggregate_spatial
  • MeshSeries.aggregate_over_time → MeshSeries.aggregate_temporal
  • MeshSeries.plot_domain_aggregate → ms.plot_line(variable.max/mean/...)
  • removed deprecated MeshSeries.plot_probe → probe = MeshSeries.probe(...); probe.plot_line(...)
  • MeshSeries.save() signature changed: now uses unified storage interface with
    target, overwrite, dry_run, and archive parameters
  • Meshes now supports storage operations: save(), from_folder(), from_id()
  • Meshes.__init__() now accepts optional id parameter
  • Meshes implements __eq__() and __deepcopy__() for proper comparison and copying
Project
  • Project.__init__() signature changed:
    • output_file is now optional (defaults to auto-generated path if using IDs)
    • Added id parameter for storage system integration
  • Project now inherits from SaveBase and supports save(), from_folder(),
    from_id() operations
  • Project.inputfile renamed to Project.input_file
  • Project implements __eq__(), __deepcopy__(), __repr__(), and __str__()
  • Removed Project.restart; use Simulation.restart instead.
Logfile Parser
  • Add monitor for live logfile parsing in a Jupyter notebook
  • step_start_time column added to time_step_vs_iterations() analysis
Execution
  • Support for parallel execution with MPI
Logparser
  • OGS V1 log format no longer supported; only V2 is parsed
Other API Changes
  • Matrix.mean → Matrix.tensor_mean
  • meshlib has been renamed to mesh - classes to generate a new mesh (e.g.
    Layer, LayerSet, Surface, …) have been moved to a submodule create.
  • ot.mesh.create.LayerSet.to_region_tetraeder → ot.mesh.create.LayerSet.to_region_tetrahedron
  • ot.mesh.create.dataframe_from_csv doesn’t require a parameters .csv anymore,
    but either a mapping of layer_id to surface files, or the directory containing
    all surfaces files (in that case the layer_ids map to the sorted file list)
  • ot.mesh.geo.depth now requires top_mesh as an argument.
  • ot.mesh.geo.p_fluid was removed. See the Stress analysis example for how
    to calculate fluid pressure now.
  • ot.mesh.file_io.save() signature changed: mesh parameter now comes first
Deprecations
Removed Modules
  • Removed ogstools.simulation module (replaced by ogstools.core framework)
Examples
Changes (non API-breaking)
Bugfixes
  • plot.line seems to have been missing the very first point of a linesample, now fixed
  • cli dashed arguments now work as expected
  • cli tools with legitimately underscored arguments (e.g. addDataToRaster, checkMesh,
    generateGeometry) no longer have their argument names incorrectly converted to hyphens
Features
New Core Framework
  • Model: New class combining project file, meshes, and execution settings into
    a complete OGS model. Can be created from components or loaded from disk.
    • Model.run() executes the simulation and returns a Simulation object
    • Model.run(<path>) writes the simulation results into the specified folder
    • Model.cmd property to inspect or reuse the full OGS command string
    • Model.plot_constraints() visualizes boundary conditions and source terms
    • Supports all storage operations (save, load by folder or ID)
  • Simulation: Represents a completed (ongoing by SimulationController) OGS simulation with model and results.
    • Simulation.meshseries provides access to the simulation output
    • Simulation.log provides access to parsed log file as a Log object
    • Simulation.status and Simulation.status_str track simulation state
    • Full save/load support with automatic storage of model, results, and logs
    • Simulation.restart allows restarting a simulation from a previous run.
  • Execution: Manages OGS execution parameters (parallelization, logging, etc.)
    • Configurable OMP threads and assembly threads
    • Execution from YAML files or programmatic configuration
    • ogs parameter accepts binary directory, container path (.sif/.squashfs), or URL
    • Built-in container URLs: Execution.CONTAINER_SERIAL / CONTAINER_PARALLEL (OGS 6.5.7)
    • Auto-detection via OGS_BIN_PATH env var or $PATH if ogs is not specified
    • Site-wide defaults via OGS_EXECUTION_DEFAULTS env var pointing to a YAML file
      (see execution_default_example.yml for reference)
    • Execution.from_default() / Execution.default for sharing a session-wide config
    • cmd property exposes the full OGS command string
  • Log: Parser and analyzer for OGS log files
    • convergence_newton_iteration() and convergence_coupling_iteration() extract
      convergence data
    • plot_convergence() visualizes convergence behavior
    • simulation_info() and termination_info() provide simulation metadata
  • Storage System (SaveBase): Unified base class for all saveable objects
    • Configurable user path via SaveBase.Userpath and backup strategy via SaveBase.Backup flag
    • ID-based organization in class-specific subdirectories
    • Archive mode for creating portable, self-contained copies
    • Temporary storage support for intermediate objects
mesh
  • added ot.mesh.node_reordering to fix node ordering of a mesh to comply with OGS standards
  • added ot.mesh.validate to check, whether a mesh complies with OGS standards
gmsh_tools
  • added more control over the discretization for remesh_with_triangles.
MeshSeries
  • added support for logarithmic scaling in ot.MeshSeries.plot_time_slice.
  • new functions for renaming domain and subdomains
  • can now be scaled spatially / temporally in the Constructor
  • added interpolate method, to interpolate the MeshSeries data on a new mesh
  • added compare method to ot.MeshSeries.
  • Storage support: can be saved and loaded by folder or ID
Meshes
  • save function performs partmesh if number of partitions are given, with optional dry_run
    • create_partitioning() and create_metis if vtu files are already present
  • subdomains() → subdomain, domain_name() → domain_name (with setter)
  • plot method displays domain mesh and subdomains (2D domain only for now)
  • remove_material method removes specified material id from domain and
    updates subdomains accordingly
  • modify_names method extends mesh names with prefix and/or suffix
  • Meshes.from_mesh now also works for 3D domain meshes
  • now checks datatypes of MaterialIDs, bulk_node_ids, bulk_element_ids and coordinates upon saving
  • from_file() method to restore from meta.yaml
  • Storage support with metadata preservation
Project
  • dependencies() return a list of referenced/needed files (meshes, xml includes, python scripts)
  • plot_constraints() → overview plot with boundary conditions and source terms
  • Enhanced __repr__() and __str__() for better object inspection
  • Storage support with proper XML handling
plot
  • add option to plot legend outside of plots.
  • added support for continuous contourplots via continuous_cmap=True.
  • Allow user to set arrowsize parameter in contourf
Variable
  • added aggregation methods min, max, mean, median, sum, std, var.
Infrastructure
  • uv.lock added for reproducible installs
  • scripts/pull_containers.py — helper to pre-pull serial/parallel OGS containers
  • Temporary files now isolated under tmp/ogstools/ instead of the system temp root
  • Drop Python 3.10 support
  • Add Python 3.14 support
  • Updated pinned environment
  • Test with container from 3.10 to 3.12
  • Dependency and tooling update
  • Use Intersphinx for 3rd party package documentation reference
  • Monitor (Bokeh) is optional dependency
Documentation
New Examples
  • plot_framework_short.py: Condensed workflow demonstrating the complete OGSTools
    framework (Setup → Compose → Run → Analyze → Store)
  • plot_storage.py: Comprehensive guide to the storage system covering basic usage,
    ID-based organization, overwriting with backup, archiving, and advanced topics
Updated Examples
  • Updated simulation examples to use new Model and Simulation classes
  • Modified examples to demonstrate the new storage system capabilities
  • Added example data: small_deformation simulation with complete model, execution,
    meshes, and results
Tests
  • plotting tests now actually check whether the resulting figure is as expected
  • Added comprehensive tests for new framework components:
    • test_framework.py: Tests for Model, Simulation, Result integration
    • test_model.py: Model class functionality
    • test_simulation.py: Simulation lifecycle and storage
    • test_storage.py: Storage system, backup, and archive functionality
Imports
  • Top-level API now exports additionally: Model, Simulation, SimulationController, Execution, Log
