OpenGeoSys 6.2.1 released!
Changelog
Features
New processes
- A thermo-hydro-mechanical (THM) process, monolithic implementation for Newton non-linear solver. #2446
Other process’ changes
Non-equilibrium initial state in the small deformation, HM, and TM processes. #2501, #2561, and #2544
A reactive transport process, integrated IPhreeqc Module 3.5.0 for reactive transport modeling. #2494, #2512
Fix velocity output in HM. #2507
Store process’ names in the Process class instead of an outside map. #2534
Generalize permeability models for the fracture flow in LIE/HM:
CubicLaw (just generalization). #2542
ConstantPermeability. #2543
Add simple mass lumping to the RichardsMechanics. #2590
Numerics
Parameter
- new TimeDependentHeterogeneousParameter. #2588
Feature can be used for time dependent heterogeneous boundary condition or source term specification.
Boundary condition
Source term
Input and output
HT process: Use MaterialPropertyLibrary for solid phase properties, too. This makes it necessary to changed the project files. #2487
Reactive transport process: Output time-series amounts of kinetic reactants and equilibrium phases defined under the subtree of chemical system. #2564
Material models
File I/O
Testing and documentation
New tools
New tools and CLI usage
Add switch multiple-nodes-allowed to tool constructMeshesFromGeometry, #2459
Add option to vtkdiff tool to compare meshes using absolute tolerances and connectivity, #2485
Scalar arrays are copied when using the ExtractSurface-tool, #2492
Data Explorer
Mesh to shape export is now writing all cell-based scalar arrays to the DBF-file, #2436
Added support of world files to georeference arbitrary raster files, #2460
Scalar arrays are copied when extracting mesh surfaces, #2492
Gocad TSurfaces can be imported into Data Explorer #2547
Gocad PLines can be imported into Data Explorer #2586
Other notable code changes
- Conversion to linear mesh is now independent of node numbering. #2519
Development workflows
- Added git hooks via pre-commit. See docs/devguide/getting-started/get-the-source-code/ for installation instructions, #2599
Infrastructure
Jenkins
Added web link checker, #2572
Reordered Jenkins pipeline for better concurrency, #2560
Updated Docker base images to Ubuntu 18.04, #2493
Migrated from envinf1 to frontend2, #2440
Conan: Use lower-case package names for qt, vtk and shapelib, #2450, #2573
CMake options changes
Bumbed miniumum CMake version to 3.12, #2597
Added option
OGS_CONAN_BUILD_TYPEto overwrite Conan build type, #2577
Web / Docs
- Added embedded screen recordings with https://asciinema.org, #2510
Version info
CMake minimum 3.12
VTK minimum 8.2
