OpenGeoSys 6.2.2 released!
Changelog
Other process’ changes
Surface sorption / desorption process implemented. #2658
Tag to fix amount of a KineticReactant in ChemistryLib. #2638
Replaced the material parameters of ThermoHydroMechanicsProcess with MPL. #2614
Explicit tag to set initial stresses in
SmallDeformation,ThermoMechancis,HydroMechanics, andRichardsMechanicsprocesses. #2635 -
Invoke material parameters that are associated with
component transport processfrom MPL. #2646 -
Integrated another Phreeqc interface using direct memory access approach for reactive transport modeling. #2640
Replaced the specific material properties of TwoPhaseFlowWithPP with generalized MPL. #2644
Pass
dtthrough interfaces instead of storage in process’ data or coupled solutions. #2673
Numerics
Generalized implementation for specification of the non-equilibrium initial states. #2633
Bulk element point mapping for tetrahedrons added. #2662
Repeat time step if assembly failed. Specifically for MFront material models if the integration fails, the time step will be repeated given adaptive time stepping scheme. #2730
Boundary condition
- Add possibility to specify ‘lower’ dimensional Robin/Neumann boundary conditions. #2710
Source term
- Line source terms are available. #2685
Input and output
[HT] Test if all the needed material properties read from project file. #2727
Extend internal state variables (MFront) output to TM, RM, and HM. #2732
Material models
New ParameterProperty can be used for heterogeneous spatial distributed MPL properties. #2616, #2683
Include MFrontGenericInterface as submodule and update to version tfel-3.2.1. #2631
Add Mohr-Coulomb-Abbo-Sloan (and its orthotropic version) to MFront material models. #2634
Extend
LinearPropertyfor linear dependency upon multiple dependent variables. #2649 -
New
IdealGasLawMPL property for pure phases consisting of ideal gases. #2651 -
New MPL property
Saturationbased on the Brooks and Corey material model. #2652 -
New MPL property
Relative Permeabilitybased on the Brooks and Corey material model. #2656 -
New MPL properties
SaturationandRelative Permeabilityaccording to the original Liakopoulos multiphase flow experiment. #2657
File I/O
- A no longer used
RapidStnInterfaceforstnfiles is dropped. The usedXmlStnInterfaceremains. #2609
New tools
command line utility to interpolate equidistant raster files between two boundary rasters (for vertical refinement of subsurface layers). #2621
command line utility to convert 2D meshes into ESRI shape files. #2627
command line utility to conver netCDF-files into OGS meshes. #2654
command line utility for for 3D mesh to grid conversion. #2704
Other notable code changes
Split BuildInfo from BaseLib into separate libs to reduce re-linking after changes in the info variables. #2625
Remove almost unused “named functions”. #2708
Infrastructure
Update tetgen to version 1.5.1 released on 18. of August 2018. #2618
Add options to enable gcc sanitizer flags. #2706
Jenkins
Builds Singularity container with OGS compiled for different MPI versions on master, #2628
Run benchmarks in Singularity container, #2648
CMake options changes
- Added option to set OGS_BUILD_PROCESSES=OFF to disable building of all processes. #2752
Web / Docs
Added links to latest benchmark pages to homepage, added sticky navigation. #2620
Website is now fully built (including generation of CSS and JS files) by Netlify, #2731
