We are pleased to announce the release of OpenGeoSys 6.3.3!
This release contains a lot of improvements in all processes and also new material properties. We also fixed a few bugs and improved documentation and general procedures. Stay tuned for the next major release 6.4.0 featuring new processes implementations which are already in the pipeline…
We also received lots of contributions from non-core developers and welcomed even a few first-time contributors! Thanks a lot for your help and we highly appreciate your input!
Changelog
Features
- You can
<include file="../path/to/file.xml">other XML files into a.prj-file. !3081
Process’ changes
Reactive transport process:
allow to assign chemical formula alternative to a component when defining water composition. !3122
output equilibrium and kinetic reactants (immobile phase) in amount. !3138, !3141
Heat Transport BHE process: allow to specify a flow and temperature control condition with the BHE inflow rate and temperature values both following the corresponding curves. !3125
ThermoHydroMechanics:
The storage is now derived from the fluid density and the solid bulk modulus. !3159
Fix bug in temperature equation for non-zero velocity. !3193
HydroMechanics: Allow linear shape functions for displacement. !3334
Use MPL properties in HeatConduction process. !3062
Fix bug in deactivation of subdomains !3065
Exterior forces output in LiquidFlow and HeatConduction. !3068
Allow thermal expansion to be anisotropic in ThermoHydroMechanics process. !3107
Improve generic interface for updating medium property variables. !3262
Improve generic interface for computing secondary variables. !3227
Component transport process: output flow velocity averaged over integration points. !3254
Boundary condition and source terms
Added a special Dirichlet boundary condition called “SolutionDependentDirichlet”. The value assigned for the boundary condition is dependent on the process solution of last time step. !3085, !3123
Cleanup of source term implementations (use volumetric source terms for line source terms). !3233
Numerics
Changed the way to pass dot x for staggered scheme. !3082
Add dotx to postNonLinearSolver. !3164
The extrapolators now accept an empty integration point values vector, in which case these are ignored. For now relevant only for LIE/SD process. !3117
LIE; Update Heaviside function to [-1/2,1/2] range. !3140
Parameter
The “Function” type parameter becomes independent from a domain specification, i.e. it is not any longer possible and necessary to specify a domain via a mesh tag !3054
Extend the “Function” type parameter to handle time in the expressions introducing the t variable, additionally to the currently available x, y, z. !3054
Pass curves to the “Function” parameter, such that they can be used in expressions like
curveA(sin(t)). !3058 -
Increased the tolerance for |A|=1 test in coordinate system. !3203
Time stepping
Fixed bugs in the fixed time output. !3026
Removed the fixed output time data from time stepper classes. !3080
Allow time stepping continue after nonlinear fails in the staggered coupling loop. !3106
Material models
New material models:
strain dependent permeability !3236
relative permeability model ‘RelativePermeabilityUdell’. !3290
saturation dependent thermal conductivity. !3298
permeability model ‘Kozeny-Carman Model’. !3264
Linear, saturation dependent swelling stress model. !3096
Pass variables from previous time step to MPL Property::value() calls where increments are required. All *rate variables were removed in
favor of the increments. !3102
Use 2D coordinate system for LinearElasticOrthotropic solid material. A bugfix, now allowing 2D anisotropy and solid material orthotropy to be used simultaneously. !3165
Unused MPL properties are shown as warnings after successful run in debug mode. !3197
Error message now informs user of missing properties on the medium scale. !3337
Bugfix of a 2D case in MFront’s implementation of Mohr-Coulomb-Abbo-Sloan anisotropic model. !3260
Update interface of the solid material models now accepting MPL Variables. !3261
File I/O
New optional output format XDMF:
light data is written into .xdmf file and heavy data into .h5 file. !3184
reduced number of iNodes for HPC applications and removed redundancies in file output. !3246
Visualization
Refactored insitu-functionality for VTK 9 / ParaView 5.8. The mpi container generated by the CI job now contains this functionality. !3092
partmeshtool now exports “vtkGhostType” array indicating duplicate cells. !3111
Documentation and webpages
Update the Heat_Transport_BHE PipeNetwork Tutorial to TESPy version 0.3.x API. !3070
Three-part video tutorial available on YouTube. !3278
New benchmark based the Liakopoulos experiment for RichardsMechanics. !3175
New test of heat transport in liquid flow with a constant velocity, HeatTransportInStationaryFlow. !3194, !3328
Fixed a formula display in “BGRa creep model”. !3329
Switched from Pandoc to GoldMark Markdown parser. !3076
Added troubleshooting web page for runtime issues. !3129
Web site usage tracking with Plausible, No personal data is tracked. Fully GDPR-compliant. !3168
Added web pages on how to get support and fill a bug report. Also enabled GitLabs Service Desk feature. !3270
Tests
CTests now have labels based on their subdir in
ProcessLib. !3079 -
LARGE benchmarks are determined by their
RUNTIMEgiven inAddTest()/OgsTest(). Current threshold: 60 s. !3079 -
Added
DISABLED-paramter toAddTest()/`OgsTest(). !3079 -
Run PETSc LARGE benchmarks in CI. !3079
Add tests for mesh element quality criteria, fixing bug in AngleSkew criterion. !3279
Updated to MathJax 3 for web formulas. !3300
Better ctest dependencies and gui utils tests. !3323
Changed the output name in square_5500x5500_staggered_scheme_adaptive_dt.prj. !3331
New tools
Support for processing large meshes on envinf1. !3099
Raster2PointCloud: Converts raster data into point clouds with an intensity-based density of randomised points per pixel for visualisation in ParaView/Unity. !3077
Conversion of linear to quadratic mesh now supports Quad4 to Quad9 conversion. !3090
Raster2Mesh: Converts an ASCII raster file into 2D mesh. Pixel values can be interpreted as elevation of mesh nodes or as scalar values for mesh elements. !3109
AssignRasterDataToMesh: Adds raster information as a scalar array to an existing 2D mesh. !3174
ExtractMaterials: Splits a mesh with n material groups into n meshes, each containing only the elements of the same material. !3116
partmesh: Added optional-x-argument to specify metis input mesh. !3171 -
IntegrateBoreholesIntoMesh: Integrates boreholes/BHEs as line elements into pre-existing mesh. !3188
VerticalSliceExtraction: Constructs a vertical 2D slice out of a collection of horizontal 2D layers. !3273
AddElementQuality: Adds evaluation of element quality criterion as data array to the mesh. !3283
CI & Infrastructure
cppcheck-report. !3053. -
Package DataExplorer into container. !3105
Unified and local (in the build-dir) Python environment with Poetry. !3133
Install dependencies for redistributable packages. !3226
Publish to Docker container for serial configuration. !3271
CMake
Reduced CMake runtime by 2-3 s. !3084
Updated submodule MGIS for proper tfel finding. !3127
Added option
OGS_USE_XDMF(defaults toOFF) for enabling Xdmf output. !3295 -
Use generator expressions for target_link_libraries(). !3297
Move global preprocessor definitions to targets. !3330
Version info
Pandoc requirement for web site removed! !3076
PETSc 3.11.2. !3094
Update exprtk submodule to the most recent master commit (d312ba9
) dated 1 Jan. 2020. !3112
Apple Clang (Xcode) 11.0 required. !3115
