We are happy to announce the release of OpenGeoSys 6.5.2!
Highlights
Breaking changes
- !4919 Removes the
molar_fluxsecondary variable in favour of flux output for all chemical species. - !4971 THM and RM processes use current state for C_{\\text elastic} computation and no longer the “null”-state.
- !4984 renames the cell averaged stress output from
stress_avgtosigma_avgto be consistent withsigmaandsigma_ipoutputs.
Process’ changes
- !4982 Correct domain deactivation behaviour for multi-variable processes; Assembly is not run iff the element is deactivated for all variables.
- !4984 introduces generic cell averaged output for all processes using reflections for IP data I/O (ATM these are TRM, LD, SD, TH2M). This enables cell average output of all IP data (except material models’ internal state data) for these processes.
TH2M
- !4980 finalizes at large the extraction of the constitutive relations into individual models, similar to how it is done in ThermoRichardsMechanics.
- !4919 Adds flux output
<c>Fluxfor all chemical species<c>.
SmallDeformation
Generic features
- !5009 Enables using Python and volumetric source terms as nodal source terms.
Testing
- !5003 [ci] Fixes for win jupyter ctests
Bug fixes
- !4919 Fixes the flux output computation in the ComponentTransport process. (The FEM assembly was/is correct.)
CMake
- !4978 New CMake-preset
sanitizer. - !4990 Refactored Eigen / MKL / OpenMP setup: Introduced new CMake option
OGS_EIGEN_PARALLEL_BACKENDwhich isOpenMPby default. When usingOGS_USE_MKL=ONthen the backend isMKL. Also updated Eigen to a recent master.
Infrastructure
- !4973 Removed ogs-container-maker dependency. OGS user container are now generated with GNU Guix. Due to improvements in dependency management (CPM) third-party developer container (e.g. C++ VSCode Devcontainer) are sufficient to use for OGS development.
- !4974 Removed ThirdParty-folder.
- !5011 Provide MKL container on https://www.opengeosys.org/releases/.
File I/O
- !4989, !4996
ogsandpartmeshcreate output directory when invoked with-o-parameter. - !4997
ogs -m-switch: fallback to reading gml from.prj-file directory.
- !4992 Allow access of
deformation_gradient,mechanical_strain,stress,total_strain, andtotal_stressin the exprtk expressions of the MPL Function property.
Version info
- !4974 VTK 9.3.0
- !5014, !4992, gcc 11.3 is minimum tested version (guix). (5390a73f) · Commits · ogs / ogs · GitLab ~gcc 11.4~ gcc 11.3
