Output Flux through Boundary Surface
Dear All,
does anybody know how to output the mass flux through a boundary surface in OGS5?
Cheers
Wenjie
Setting $DAT_TYPE TOTAL_FLUX in OUT file might work, but I'm not sure. maybe someone from Kiel can help you.
best,
nori
On 04/08/2016 03:30 AM, Wenjie Xu wrote:
Dear All,
in OGS5?
Cheers
Wenjie
Groups "ogs-devs" group.
an email to [email protected]
<mailto:[email protected]>.
Norihiro Watanabe, Dr.-Ing.
Wissenschaftler
[email protected] / http://www.ufz.de
Telefon +49 341 235 1806
You can also use Paraview to slice a plane of your domain and then use a filter called “Surface Flow” (or similar, I don’t remember exactly).
Marc
Marc Walther
Hydrologist
JProf Dr. rer. nat.
Permoserstraße 15, 04318 Leipzig, Germany
Technische Universität Dresden
Faculty of Environmental Sciences
Department of Hydrosciences
Institute for Groundwater Management
01062 Dresden
Visiting Address UFZ
Building 7.2, Room E110
Visiting Address TUD
Bergstr. 66, 01069 Dresden
Neubau Chemie 2. Bauabschnitt, CHE-BA2, Room E60
Phone +49 341 235 10 54
Fax +49 341 235 19 39
Mobile +49 178 334 18 19
Email [email protected]
Web http:/​/​www​.​ufz​.​de
Personal http:/​/​www​.​ufz​.​de/​index​.​php​?​en=​32239
ResGate http:/​/​www​.​researchgate​.​net/​profile/​Marc_Walther
Registered Office: Leipzig
Registration Office: Amtsgericht Leipzig
Trade Register Nr. B 4703
Chairman of the Supervisory Board: MinR Wilfried Kraus
Scientific Director: Prof. Dr. Georg Teutsch
Administrative Director: Dr. Heike Graßmann
Sent from my mobile device, please excuse spelling mistakes.
On 8 April 2016 3:30:14 am Wenjie Xu [email protected] wrote:
Dear All,
Cheers
Wenjie
You received this message because you are subscribed to the Google Groups “ogs-devs” group.
Hi Wenjie,
as Nori said, you can use the TOTAL_FLUX output for fluxes across surfaces (or polylines in 2D):
#OUTPUT
   HEAT_TRANSPORT
  $GEO_TYPE
   SURFACE SURF1
  $DAT_TYPE
   TOTAL_FLUX
  $TIM_TYPE
   STEPS 1
This works for heat & mass transport, liquid & groundwater flow.
Just set the correct $PCS_TYPE. For some boundary element types (tri, tet), however, accuracy may not be perfect.
You can also print total heat, or mass stored in your model, e.g. for a particular material group (MatGroup 0 in this case):
#OUTPUT
   HEAT_TRANSPORT
  $DAT_TYPE
   CONTENT 0
  $TIM_TYPE
   STEPS 1
These functions are implemented in the KielTesting branch:
https://svn.ufz.de/svn/ogs/branches/kiel_testing
Jens Olaf Delfs can give you more information, as he implemented these routines.
Schönen Tag noch, Christof
Am 08.04.2016 um 03:30 schrieb Wenjie Xu:
Dear All,
in OGS5?
Cheers
Wenjie
Dr. Christof Beyer
Institute of Geosciences
Geohydromodelling
Ludewig-Meyn-Str. 10
24118 Kiel
Germany
phone: +49(0)431-8803172
fax: +49(0)431-8807606
mobile: +49(0)176-24297908
email: [email protected]
A desciption is available here: https://github.com/drjod/ogs_kb1/wiki/Balancing-toolkit
2016-04-08 3:30 GMT+02:00 Wenjie Xu [email protected]:
Dear All,
Cheers
Wenjie
I just tried today with triangle mesh, it did not work. And I found a webpage here http://tk-opengeosys.blogspot.com/2016/04/ says that “there seems to be a bug for trinagles and tetrahedra”
Dear All,
Cheers
Wenjie
Dear Xuan,
I suggest to use Paraview for getting a budget through any arbitrary planar surface. You can use the filters like this:
  1. ‘slice’ (define your area where you want to know the flux),
  2. if you have a 2d setup add ‘linear extrusion’ with length of unit 1 into the missing dimension here,
  3. ‘generate normals’ on the new surface,
  4. use a ‘calculator’ filter to compute the flux per node (type ‘velocity.normals’ to computer a scalar product, both variables should be vectors),
  5. and finally ‘integrate variables’ to get the total flux through the area
Marc
Marc Walther
Hydrologist
JProf. Dr. rer. nat.
01062 Dresden
Neubau Chemie 2. Bauabschnitt, CHE-BA2, Room P204
Chairman of the Supervisory Board: MinDirig Wilfried Kraus
Scientific Director: Prof. Dr. Dr. hc. Georg Teutsch
Administrative Director: Prof. Dr. Heike Graßmann
Dear All,
Cheers
Wenjie
