Hi, I am coupling overland_flow and Richards_flow. However the computing speed is very slow even on a high performance cluster.
Is there any parameter in .num I can change to improve the computation efficiency? Thanks.
I am using the parameters from example: Wool_lines_coup, and I deleted the groundwater, since I don’t have groundwater.
Also, I found that $OVERALL_COUPLING can be removed without any impacts on the simulation results.
Xuan
GeoSys-NUM: Numerical Parameter ----------------------------------------
$OVERALL_COUPLING
;min iterations – max iterations
1 3
#NUMERICS
RICHARDS_FLOW
$ELE_UPWINDING
0.5
$ELE_MASS_LUMPING
1
$LINEAR_SOLVER
; method error_tolerance max_iterations theta precond storage
3 6 1.e-010 1000 1.0 101 4
$NON_LINEAR_SOLVER
; method error_tolerance max_iterations relaxation
PICARD .1 20 0.0
$ELE_GAUSS_POINTS
3
$COUPLING_CONTROL
;error method – tolerance list
LMAX 1.0e-12
#NUMERICS
OVERLAND_FLOW
$LINEAR_SOLVER
2 5 1.e-10 1000 1.0 100 4
$NON_LINEAR_SOLVER
; PICARD error_tolerance max_iterations relaxation
; NEWTON error_tolerance nls_error_tolerance_local max_iterations relaxation
NEWTON 1e-5 1e-8 100 0.0
$ELE_GAUSS_POINTS
2
$COUPLING_CONTROL
LMAX 1.0e-12
